Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Tue Aug 04, 2009 4:09 pm Post subject: adding grease fittings to ball joints? |
I've got the ball joint beam out of the car and torn apart to add adjusters. I'm also replacing all of the ball joints and tie rod ends as well since they look to be original VW (and feel like it too).
I called my local VW shop and he said the ball joints they have don't come with grease fittings. Has anyone added grease fittings to sealed ball joints or tie rod ends? I searched and found that if they have the plastic cap on them you can pull that off and add the fitting, but what if they have a smooth metal top?
Also, are the typical VW shop tie rod ends and ball joints worth a crap? There is a European parts place that probably sells Beck Arnley or something like that. I don't mind spending money in the right places, and this is a daily driver, what brand should I go with? _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3389 Location: Dirty Jersey
Posted: Tue Nov 03, 2009 6:55 am Post subject: |
I have the same question, anyone add grease fittings to the flat top ball joints with no hole? I was thinking of drilling/tapping hole and then screwing in grease fittings? good idea? The BJs are new and already installed on torsion arms, thanks. _________________ 1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks! |
Posted: Tue Nov 03, 2009 7:50 am Post subject: |
I talked to a machinist friend of mine who's also worked on VW's for many years. He didn't think the risk of putting metal shavings in the ball joints was worth the gain of adding grease. Realistically, you can pop the joints off of the spindle, remove the grease boot, and add grease that way. That's what I decided to do. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
mjenner Samba Member
Joined: November 29, 2008 Posts: 268 Location: essex,on,canada
Posted: Tue Nov 03, 2009 8:13 am Post subject: |
Buy a need le at your local parts supply store to fit in the end of your grease gun. shouldn't cost more than a couple bucks - good tool to have |
Posted: Tue Nov 03, 2009 8:55 am Post subject: |
mjenner wrote: |
Your saying to slip the needle under the boot and shoot some grease in there that way? thx _________________ 1963 Ragtop Bug
1966 Vert Bug
Posted: Tue Nov 03, 2009 10:30 am Post subject: |
Yeah - and tthe water won't get in either. |
Viande Samba Member
Posted: Tue Nov 03, 2009 12:59 pm Post subject: |
How old are the factory units? 30+years? There was no need for a grease fitting. Only reason for a grease fitting is if you are using the cheap play-doh versions most sell. And even that will not correct for steel that is just too soft. Good luck _________________ Bobby
New Items In Stock, NOS & OEM Seals,Parts and Terminals
My Feedback Here
The bitter taste of poor quality lingers long after the joy of the cheap price fades away. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17573 Location: Left coast, Canada
Posted: Wed Nov 04, 2009 12:18 am Post subject: |
Your original ball joints were a steel ball in a steel socket. Grease was needed to prevent wear.
Modern ball joints are made the same, but have a teflon "bearing" between the two sliding steel parts. Any grease you put in there does nothing.
There isn't a problem with the ball joints that needs solving. _________________
