Remove diagnostic box?
Theloniousphere
Theloniousphere is offline
PostPosted: Thu Nov 26, 2009 1:12 pm    Post subject: Remove diagnostic box? Reply with quote
74 bay
Can someone tell me the process for removing the diagnostic test box (that box in the engine compartment with the mess of wires)? I tried searching and have read that it's basically useless, so I would like to get it out of there if possible.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Thu Nov 26, 2009 1:24 pm    Post subject: Reply with quote
The test plug? Just remove it. I took mine out and the engine bay looks much cleaner.
Pic from gallery
Trace the wires back and cut/cover them.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
Mr'72Special
Mr'72Special is offline
PostPosted: Thu Nov 26, 2009 1:45 pm    Post subject: Reply with quote
Agrree with EZ Gruv, but when you cut the wires you should remember to do each wire at adifferent length in the harness so as to aboid any shorting or back-feeding through the diagnostic circuits. Once all the wires are cut, wrap each wire end individually with thick electrical tape, preferably 3M or Scotch. With all wires properly taped off, gather them together and bundle them collectiely in the same electrical tape so that, when done, the harness looks somewhat like a bangaged amputated limb. Finally, secure the amputated harness branch to the main harness with more tape. Do it right, and you can barely notice the delete.
This procedure comes from an experience when I was restoring a '73 for a family member's significant other. He wanted the diagnostic plug gone since it's wires were cracked and corroded as well as it, frankly, being superfluous. Now that someone asked I sure do regret not taking photos of that part of the restoration.
Hope this helps!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Nov 26, 2009 3:39 pm    Post subject: Reply with quote
Works the same as on my Beetle....
Disconnect the battery, cut the wires and tape over the large one that supplies 12v+. The others you can just tuck away.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
busdaddy
busdaddy is offline
PostPosted: Thu Nov 26, 2009 4:46 pm    Post subject: Reply with quote
I'd tape or heat shrink all of them separately, the fat red one is just dangling from it on a bus and usually isn't connected to the battery but almost all of the rest of them get power when the lights, signals and a few other things are in use.
Слава Україні!
notchboy
notchboy is offline
PostPosted: Sat Jan 28, 2012 2:07 pm    Post subject: Reply with quote
What about using the fat red for a engine bay light? Is it hot all the time or when the key is on?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Mal evolent
Mal evolent is offline
PostPosted: Sat Jan 28, 2012 2:22 pm    Post subject: Reply with quote
an alternative to tape: stick each cut off wire into a tube of RTV. Seals it up, won't slide off.
I put a hot lead and a ground in a plastic block on my baja bug. gives me a connection for timing light, dwell meter, et cetera. 10-32 screws isolated from everything else
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
greenbus pilot
greenbus pilot is offline
PostPosted: Sat Jan 28, 2012 2:51 pm    Post subject: Reply with quote
Yes, it would work.
But the battery is, like, 16 inches away, so , yeah, not a lot of work either way. Wink
Sent from a white van down the street.
old DKP driver
old DKP driver is offline
PostPosted: Sat Jan 28, 2012 8:12 pm    Post subject: test socket Reply with quote
I like having the test socket in my 72 bus since the center terminal 50 and
the terminal 30 right upper connector operates the starter when jumped
Then i set the dwell & do a compression test
Built in remote starter. Cool[img][/img]
V.W.owner since 1967
Last edited by old DKP driver on Sat Jan 28, 2012 9:34 pm; edited 2 times in total
notchboy
notchboy is offline
PostPosted: Sat Jan 28, 2012 8:26 pm    Post subject: Reply with quote
greenbus pilot wrote:
Yes, it would work.
True enough d'oh!
1964 1500 S
