Power surplus
davidc68503
davidc68503 is offline
PostPosted: Sat Nov 28, 2009 10:57 pm    Post subject: Power surplus Reply with quote
Okay guys and gals, I have a 70 pop top, I have a speaker box with a couple of 12" woofers and a couple of amps hooked up. The issue I'm having is lose of power after running the stereo during the ride. The amps are about 100 watts. Does anyone know how to hook up an extra battery or a better solution. Thanks.
enjoispammy8
enjoispammy8 is offline
PostPosted: Sat Nov 28, 2009 11:03 pm    Post subject: Reply with quote
are you running a generator or an alternator?
1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote:
Is there a message here? Enjoy Spammy Ate
EZ Gruv wrote:
Way to fuck up some little kids riding in the car next to you.
hazetguy wrote:
you need to be doing better drugs.
View user's profile Send private message Send e-mail AIM Address Facebook Gallery Classifieds Feedback
davidc68503
PostPosted: Sun Nov 29, 2009 1:13 pm    Post subject: Reply with quote
It has the generator
david_594
david_594 is offline
PostPosted: Sun Nov 29, 2009 1:40 pm    Post subject: Reply with quote
Upgrade to an alternator then.
Or learn to turn down the volume. Adding a second battery isnt going to fix the problem.
1968 westy weekender
2000 jetta tdi
79 vespa p200e
peaceful warrior
peaceful warrior is offline
PostPosted: Sun Nov 29, 2009 2:18 pm    Post subject: Reply with quote
Ditto, too much amperage being used, and the generator cannot keep up. Purchase, at least, a 55 Amp alternator, though it might behoove you to check your amp draw. Wink
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
busboy25
busboy25 is offline
PostPosted: Sun Nov 29, 2009 2:29 pm    Post subject: Reply with quote
When the bus is running any battery will be a load on the system and would make the problem worst.
76 Bay - 2056 Type four
enjoispammy8
PostPosted: Sun Nov 29, 2009 2:44 pm    Post subject: Reply with quote
just search alternator conversion on here and youll find all the information you need.
SGKent Premium Member
SGKent is offline
PostPosted: Sun Nov 29, 2009 3:43 pm    Post subject: Reply with quote
There are two really good solutions that work well in a VW bus. They are:
1) turn the stereo down
2) If you want to be a bad a$$ deaf person buy an Escalante. I hear they are cheap these days.
George Carlin:
Skills@EuroCarsPlus:
davidc68503
PostPosted: Sun Nov 29, 2009 8:44 pm    Post subject: Reply with quote
Turning down the volume wouldn't be as much fun as going louder! But what is the escalante you speak of?
WestyPop
WestyPop is offline
PostPosted: Sun Nov 29, 2009 9:42 pm    Post subject: Reply with quote
Just guessing he meant "Escalade" (gas-guzzling Cadillac-ized Chevy Tahoe or Suburban). I hear Tiger Woods will give you a good deal on his short version with flow-thru ventilation.
Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others)
Desertbusman
Desertbusman is offline
PostPosted: Sun Nov 29, 2009 11:30 pm    Post subject: Reply with quote
You might want to put more batteries in it. Since you won't be listening for any wierd or unusual engine sounds you'll at least have your speaks to pass the time if you are broken down on the side of the road.
71 Superbug
71 Westy
davidc68503
PostPosted: Tue Dec 08, 2009 8:41 pm    Post subject: Reply with quote
The engine is mechanical sound, so that isn't an issue. The only solution I was dealing with was optimizing the stereo. Thanks for the posts that dealt with that and that only.
timo78
timo78 is offline
PostPosted: Tue Dec 08, 2009 9:12 pm    Post subject: Reply with quote
And once you get adequate power generated with an Alternator upgrade. Invest in an Auxiliary battery/kit as well http://www.busdepot.com/details.jsp?partnumber=1738
. So you don't get stranded after turning it up to 11 while parked. Smile http://www.youtube.com/watch?v=WwoM5fLITfk
Green Bay Bus > 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it?
SGKent is offline
PostPosted: Tue Dec 08, 2009 9:30 pm    Post subject: Reply with quote
I hear if you put one facing forward that pulls and one facing backwards that pushes you don't even need an engine. Have you considered mounting a honda generator and getting around that way. You could even get a small Ingersol Rand trailer generator and tow it around while it powers the speakers.
Really - don't you think your question is a little absurd. If the alternator in your bus, one that has worked well for everyone else for what now - 40 years - can't give you enough power for your stereo that maybe it's you who needs help and not the alternator? Do you think the people in the car next to you want to listen to your music? One day some who has had a bad day will hear that music next to you at a light and then only he and God will know what your last words really were.
George Carlin:
GusC2it
GusC2it is offline
PostPosted: Tue Dec 08, 2009 9:33 pm    Post subject: Reply with quote
I have a 200 watt amp powering 2 12s but it is a high eficientcy amp that doesnt draw much power, it hardly even gets warm, but it will blow your drums out. High wattage is over rated. Im running a Rabbit Bosch Alt. in my 75, but its not needed to run my amp.
75 type 2 http://gusc1.tripod.com/1975vwtype2
Old vices have now been upgraded to bad habits.
http://www.facebook.com/pages/VW-Wild-Weekend-2011-St-Pete-Fl/197064760336111
SGKent is offline
PostPosted: Tue Dec 08, 2009 9:44 pm    Post subject: Reply with quote
Gus - can you imagine if yours will blow eardrums out what the original author of this thread is thinking? It has nothing to do with sound quality but rather bragging rights. When I was young I had a very powerful stereo in my bus too but never enough that it would even come close to overwhelming a 38 amp generator - and we never bothered others with it. 55amps x 14.5V is is almost 800 watts. 70 amps times 14.5V is over 1000 watts. You could drive sound in a football stadium with that.
George Carlin:
GusC2it
GusC2it is offline
PostPosted: Wed Dec 09, 2009 7:13 am    Post subject: Reply with quote
You're right Merlin! Its all for braging rights, like how much HP your engine is! (torque is what really matters). My advice would be to use a smaller or more efficient Amp. Cool
ddwbeagles
ddwbeagles is offline
PostPosted: Wed Dec 09, 2009 9:25 am    Post subject: Merlin gets mad Reply with quote
[quote="SGKent"]
Wow, no often do you see Merlin mad. That quote was funny as crap! Laughing
David W - from Chesterfield, VA / Jefferson SD / Stephens City, VA in that order.
71 Ghia Coupe autostick
78 Westy
86 Vanagon Weekender
hazetguy wrote:
i'm going to stock up on search buttons
GusC2it
GusC2it is offline
PostPosted: Wed Dec 09, 2009 9:38 am    Post subject: Re: Merlin gets mad Reply with quote
[quote="ddwbeagles"]
LMAO 2 ! Very Happy
Runamuck Bus
Runamuck Bus is offline
PostPosted: Wed Dec 09, 2009 5:33 pm    Post subject: Reply with quote
Is this going to turn into one of those angry Samba threads? If so. I'll stop back more often! Meantime, I just gotta laugh when I read these 'modifications' threads (more stereo!, bus higher!, bus lower!, bus faster! and on and on and on..). I'm looking forward to the day when I actually have my technical issues worked out AND I actually get to drive my bus. On that day, I'll be motoring slow, at stock height with the 4-cyl symphony playing in the background.
Endeavor to persevere.
'72 Westy "Weekender"
