connella08 Samba Member
Joined: February 28, 2009 Posts: 833 Location: south central mass
Posted: Thu Dec 03, 2009 1:23 pm Post subject: Autostick vs Manual cam plug? |
there is a little circular plug on the back of the case directly behind the flywheel that's about the size of a quarter. my "how to rebuild your aircooled engine" book states that if you have an autostick transmission that this plug must be facing inward toward the cam, but if you have a manual it needs to be facing outward away from the cam. whats the difference?
i am in the process of converting my autostick to a manual, so do i have to crack the case open to turn this little plug around? if you need pics let me know, im pulling my autostick tranny off later tonight so i will try to get some pics then if necessary. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Dec 03, 2009 1:25 pm Post subject: |
I think it was a flexplate interference thing. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Thu Dec 03, 2009 1:28 pm Post subject: Re: Autostick vs Manual cam plug? |
connella08 wrote: |
No you don't need to. Like Miniman82 posted. It's the other way around. An autostick flex plate can rub a hole in the cam plug if it's in the "manual trans/normal" flywheel type configuration. You will not have any issues. |
Posted: Thu Dec 03, 2009 3:29 pm Post subject: |
great, thanks guys. i wasnt looking forward to cracking my case open again if there were going to be any problems. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79542 Location: Sneaking up behind you
Posted: Thu Dec 03, 2009 3:32 pm Post subject: |
Mine's in and I don't have a autostick.. never a problem.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Dec 03, 2009 3:53 pm Post subject: |
glenn, thats the same way i have it, thanks for the picture verification. i just wasnt sure if that was done for any other reason being internal or external. time to start the tranny swap! |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4941 Location: Raleigh, North Carolina
Posted: Fri Dec 04, 2009 9:44 pm Post subject: |
IIRC, you should be able to install it one direction that will work on either a manual or Auto Stick application?
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Glenn  Mr. 010
Posted: Fri Dec 04, 2009 9:46 pm Post subject: |
didget69 wrote: |
bnc |
Yes... with the plug in it will work with both.
So you can convert a autostick to a manual but not a manual to a autostick. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Dec 04, 2009 9:50 pm Post subject: |
Glenn wrote: |
didget69 wrote: |
bnc |
but not a manual to a autostick. |
unless you tear down the case and turn the cam plug around. |
Glenn  Mr. 010
connella08 wrote: |
Glenn wrote: |
didget69 wrote: |
bnc |
But who would want to  _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Dec 04, 2009 10:31 pm Post subject: |
Glenn wrote: |
connella08 wrote: |
Glenn wrote: |
didget69 wrote: |
bnc |
But who would want to  |
lol thats the whole reason i started this thread. i WAS going to if i HAD to...thankfully i dont. |
