jacob. Samba Member
Posted: Wed Dec 16, 2009 6:05 am Post subject: |
Shit! I hope thats not what I have to replace. Thats a high price for a little part. _________________
RCB wrote: |
jacob gets razzed a lot cause he has the only GEX engine thats lasted longer than half an oil change. |
Mikeyb Samba Member
Joined: April 02, 2007 Posts: 133 Location: Arcadia, CA
Posted: Wed Dec 16, 2009 6:17 am Post subject: |
Sounds like it to me. You have all the same symptoms I had only a couple weeks ago. Headlights mysteriously stop working; a pull on the high-beam arm turns them on; releasing the arm turns them off; heater and wipers still work. . . yep, sounds like the high beam switch. You might be able to find one at your local Westy cemetery. _________________ '82 1.9 TD Westy (Tortuga Veloce)
2014 Honda Pilot
2021 VW Atlas |
jacob. Samba Member
Posted: Wed Dec 16, 2009 7:15 am Post subject: |
Guess I'll make some calls. Theres a few dead vans around the area. _________________
RCB wrote: |
jacob. Samba Member
Posted: Wed Dec 16, 2009 7:59 am Post subject: |
My temporary fix for the drive to work tonight A pencil, a folded up piece of paper, some zip ties, and pure genius.
RCB wrote: |
youremyboyblue Samba Member
Joined: December 01, 2009 Posts: 38 Location: whereever my tdi syncro will take me!
Posted: Wed Dec 16, 2009 10:32 am Post subject: |
10) take a break and come back to it > beer
11) repeat steps 1-10
12) swap bulbs > realized bulb does not work on functional side
13) kick dirt that a day was wasted over a bad bulb > unwarranted bad feelings toward vendor and self
14) put old lower power bulbs in while wating for replacement > light from both headlights on low or high
so now that i have learned a bunch and have light, i have some poltergeist business going on ...
while driving, the driver's interior light flickers on accompanied by loss of power and dimmed headlights/interior. i'm troubleshooting a bit of a hunting idle but, the interior light flickering while in the light when door open position is not only new but, mysterious. i thought that i had read something about this issue with the flickering interior in another headlight thread but, am at a loss to find it currently.
any help is appreciated! |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Tue Dec 29, 2009 8:45 pm Post subject: |
Jacob, what finally resolved this for you? I currently have the same problem. Thanks. |
kevtherev Samba Member
Joined: December 23, 2007 Posts: 897 Location: the 51st state
Posted: Wed Dec 30, 2009 4:19 am Post subject: |
I too am interested in who the culprit was |
Posted: Wed Dec 30, 2009 7:19 am Post subject: |
OP indicates in a PM he has not resolved this issue yet. I just ordered new headlight AND high beam (wiper/washer assembly) switches from VC. I'll try the high beam first and will report back the results. It will be next week most likely before I report in. In the meantime, I'm tempted to wire the yellow and white wires back together, bypass the relays, to see if the problem persists. Has anyone done this already? |
jacob. Samba Member
Posted: Wed Dec 30, 2009 9:35 am Post subject: |
singler3360 wrote: |
Is bypassing the relays bad for the van at all? And no I haven't solved the problem. My van is being a piece of shit right now. Its draining the battery, so every morning when I go to start it, it doesn't work. With a full battery everything works fine (except the headlights of course). I ordered a new voltage regulator/brushes and hopefully that solves that. If not, I'll have my alternator rebuilt. _________________
RCB wrote: |
Posted: Wed Dec 30, 2009 9:57 am Post subject: |
jacob. wrote: |
Is bypassing the relays bad for the van at all? |
I was thinking that reconnecting the yellow and white wires back together would simply restore it back to the stock configuration. If nothing else, just to reestablish a baseline since I performed a lot of upgrades at the same time when the dash was out. However, I'd rather not clip out the butt splices and shorten those wires anymore than they are. For instance, could it be possible the Shoebox Electronic headlight buzzer I wired in some time ago (and has always worked) is somehow interfering with the headlight relay kit? |
jacob. Samba Member
Posted: Tue Jan 05, 2010 1:06 pm Post subject: |
I installed a used headlight switch I got at a wrecking yard for 20 bucks. Headlights came right back on. Now on to the relays. _________________
RCB wrote: |
Posted: Tue Jan 05, 2010 8:20 pm Post subject: |
Ok, the new high beam assembly and headlight switch arrived today. Didn't even need to take the headlight switch out of the package, the culprit was the high beam switch. Westapotamous finally has [brighter] lights again. Yessss! |
claytonic Samba Member
Joined: October 25, 2009 Posts: 32 Location: Vancouver B.C.
Posted: Thu Jan 07, 2010 8:09 am Post subject: Head light and fans |
I have the same thing going on after a relay install. Dam it nothing is simple!
I was wondering if this is normal
If you have
the key off
running lights on (not the head lights )
heater fan switched on
and flash the high beams
do your heater fans come on ?
Mine do, now at least don't know if this was the case before?
Thanks |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10389 Location: Orbiting San Diego
Posted: Thu Jan 07, 2010 8:36 am Post subject: Re: Head light and fans |
This is normal. With the key off but headlight switch all the way on, only the running lights are on. If you turn on the heater fan nothing happens. Then flash the high beams and the heater fan will spin. It has nothing to do with adding the relays.
Mark
claytonic wrote: |
If you have
the key off
Thanks |
Posted: Thu Jan 07, 2010 8:59 am Post subject: Thanks |
Thanks for the speedy replay
I was not looking for ward to chasing gremlins! |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Thu Jan 07, 2010 10:17 am Post subject: |
That's also a good way to raise or lower power windows without the ignition on too... _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
TUFF Samba Member
Posted: Sat Jan 16, 2010 2:09 pm Post subject: Left headlight out on Low beam |
My challenge is th left low-beam does not come on. Wipers work, and heater fans work. Fuse 10 good. Any suggetsion ? |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sat Jan 16, 2010 4:41 pm Post subject: |
Bad bulb? Start with the simple stuff. |
TUFF Samba Member
Posted: Sat Jan 16, 2010 5:26 pm Post subject: |
Bulb is OK, wondering if it is the Light switch - other posts say if wipers and hetaer fan work, it must be the light switch. Thanks |
jacob. Samba Member
Posted: Sat Jan 16, 2010 5:31 pm Post subject: |
TUFF wrote: |
If it was the headlight switch, both low beams would be out, and the high beams would still work. Perhaps the wire to that specific light fell off or is corroded? _________________
RCB wrote: |
