phipplet Samba Member
Joined: September 03, 2006 Posts: 147 Location: Eatonville, Wa-USA
Posted: Thu Jan 28, 2010 1:54 pm Post subject: Shift rod bushing installation |
Hi everyone,
Does anyone have a picture of the shift rod bushing actually installed. I don't need the diagram, I need to see it installed. My '64 bus came without one. This is the bushing on the front under the shifter.
Thanks
Moderator edit:
Here's a shop manual and a real photo of a new one installed:
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26158 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jan 28, 2010 2:32 pm Post subject: |
Thanks, You guys rock!  |
Posted: Thu Jan 28, 2010 6:28 pm Post subject: |
Glad to help!!
See you at Vintage.  _________________ In Stereo, Where Available! |
Posted: Fri Jan 29, 2010 7:31 am Post subject: |
Now on to the other shift rod bushings? Does anyone have a pic of the middle bushing and does it have a clip somewhere? Also, not sure but does a '64 bus have a rear shift rod bushing also?
Thanks.  |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10803 Location: the past
Posted: Fri Jan 29, 2010 8:21 am Post subject: |
phipplet wrote: |
in this pic found in the search above, the bushing is installed incorrectly (a quick look at the diagram would show this).
the snap ring end is supposed to face forward and the slot in the bushing is supposed to face to the side.
also, this area needs to be greased liberally.
correct:
Posted: Fri Jan 29, 2010 8:40 am Post subject: |
The back one has no clip.
You can check out the parts manuals @
http://oacdp.org/ _________________ In Stereo, Where Available! |
Posted: Fri Jan 29, 2010 4:02 pm Post subject: |
Thanks Hazetguy! You saved me. I was about to put the shift rod back in and the bushing would have been on backwards. There's got to be a way to delete that gallery pic to save other people from future problems.
Thanks again. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71707 Location: Phoenix 602
Posted: Fri Jan 29, 2010 11:05 pm Post subject: |
phipplet wrote: |
Thanks Hazetguy! You saved me. I was about to put the shift rod back in and the bushing would have been on backwards. There's got to be a way to delete that gallery pic to save other people from future problems. |
I edited the gallery entry above with a little note and a direction to this thread for the correct orientation. _________________ How to Post Photos
bugcollections Samba Member
Posted: Sat Mar 13, 2010 2:28 pm Post subject: shift rod bushing |
Here is the one that I am replacing in my 65 westy. Hopefully installed correctly. And, yes, I had to cut off the coupler between the front and rear rod with a cut off tool. It was too rusted to budge with anything. It's going back together as soon as I get a new coupler.
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Sat Mar 13, 2010 4:02 pm Post subject: |
http://oacdp.org/5867part/359.png
I want to rebuild my shifting system. I see on this I need #17 and #21 which comes with #22 but what is part #19 in the diagram? _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote: |
Perfection only comes with delusion. |
http://www.oacdp.org/ |
Posted: Sat Mar 13, 2010 4:59 pm Post subject: shift rod build |
You might want to go to wolfsburg west and do some searching. Can start here:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211711155C
And I think the part 19 you are referencing is the bushing for the front of the shift rod on a late 66-67 which are different than the 62. Assume you are asking for your 62 bus. |
Posted: Sat Mar 13, 2010 11:04 pm Post subject: Re: shift rod build |
bugcollections wrote: |
yes thanks _________________ April 3rd 62 standard mgr/pw
Includes 6 popouts
025 Safety belts
dawerks wrote: |
Clara  Samba Member
Posted: Sun Mar 14, 2010 8:44 am Post subject: Re: shift rod build |
sventinker wrote: |
yes thanks |
If you go to the next page, and find the entry next to #19, it describes what that part is for, you will see that it is used from ch 216 028 112. So it does not apply to an earlier bus like a '62
If you look at the same page next to #17, you will see how many it takes, and that there was a different version from VIN 835 088, so make sure you get the right kind.
http://oacdp.org/5867part/361.png
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Mar 14, 2010 9:39 am Post subject: |
Thanks for the Clarafication
ok so I have read that I need two of that #17 bushing and two rubber boots but the diagram only shows one of each. I am not talking about the one bushing with the clip for up front. So where do the extra ones go? _________________ April 3rd 62 standard mgr/pw
Includes 6 popouts
025 Safety belts
dawerks wrote: |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15362 Location: Casa de Oro, California
Posted: Sun Mar 14, 2010 1:55 pm Post subject: |
sventinker wrote: |
So where do the extra ones go? |
If you're talking about the shuttlecock things and the bellows type boots, they go on the shift rod under the cargo floor. You have to pull the rod out the back. Two bushings suspend the rod inside the tube and the boots go on each end. I put worm clamps on the boots, too. |
65Busstop Samba Member
Joined: January 06, 2004 Posts: 312 Location: Akron Ohio
Posted: Sun Mar 21, 2010 3:29 pm Post subject: |
My front bushing is missing. Can the front bushing be replaced without removing shift rod? Looks like bushing is split? Am I correct ? My Bus is a 65 is that the year they changed or 66? |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Sun Mar 21, 2010 5:04 pm Post subject: |
that bushing can be changed without removing the shift rod. i did remove the shifter and rear shift coupler from trans and rod. that thing is a bitch to get between the bracket and rod. i pulled on the edge of the bushing and pulled it through rotating the bushing while getting it to sit in the groove. clean any rust from the rod to get an easier fit and lightly grease it so it doesnt move too much.i just opened the snap ring and then closed it back when done. good luck _________________ once you realize im not impressed we will get along just fine |
Pistinbroke Samba Member
Posted: Tue Nov 09, 2010 9:33 am Post subject: |
Thanks for this thread and in particular to Hazetguy, solved a problem that had been bugging me for days. I had purchased a bush kit that included the later type front bush. I had a look at installing the correct bush earlier, but it didn't look right. However the photographs relieved me of my ignorance! Gear change now sweet... |
Solan Samba Member
Joined: March 26, 2009 Posts: 41 Location: Bergen, Norway
Posted: Wed Dec 01, 2010 7:32 am Post subject: Shift rod problems... |
Hi
I'm having a similar problem with my '65 11W Bus that I'm assembling now (sorry if I'm messing up the thread...).
It seems like my stickshifter is too short, or the bracket which the front shift rod goes through is too far down,
because the bottom of the shifter tends to slip out of the front shift rod "seat". Any hints?
Is it possible to mount a "short shifter" kit on a bus? (I think this will pull the shifter downwards?)
As I understand, the '65 doesn't have the "guiding pin" in the front of the shift rod to hold it in the right position vertically.
Cheers from Bergen, Norway
Svein _________________ '65 11W Microbus
'52 Beetle ragtop |
