Shift rod bushing installation
Page: 1, 2, 3, 4, 5, 6  Next
phipplet
phipplet is offline
PostPosted: Thu Jan 28, 2010 1:54 pm    Post subject: Shift rod bushing installation Reply with quote
Hi everyone,
Does anyone have a picture of the shift rod bushing actually installed. I don't need the diagram, I need to see it installed. My '64 bus came without one. This is the bushing on the front under the shifter.
Thanks
Moderator edit:
Here's a shop manual and a real photo of a new one installed:
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Jan 28, 2010 2:23 pm    Post subject: Reply with quote
From a "Search" of the "Gallery" for "Shifter Bushing" in "Categories" "Parts/Accessories 49-67 Bus" :
http://www.thesamba.com/vw/forum/album_search.php?search_keywords=shifter+bushing
In Stereo, Where Available!
phipplet
phipplet is offline
PostPosted: Thu Jan 28, 2010 2:32 pm    Post subject: Reply with quote
Thanks, You guys rock! Very Happy
Eric&Barb
PostPosted: Thu Jan 28, 2010 6:28 pm    Post subject: Reply with quote
Glad to help!!
See you at Vintage. Very Happy
phipplet
phipplet is offline
PostPosted: Fri Jan 29, 2010 7:31 am    Post subject: Reply with quote
Now on to the other shift rod bushings? Does anyone have a pic of the middle bushing and does it have a clip somewhere? Also, not sure but does a '64 bus have a rear shift rod bushing also?
Thanks. Very Happy
hazetguy
hazetguy is offline
PostPosted: Fri Jan 29, 2010 8:21 am    Post subject: Reply with quote
in this pic found in the search above, the bushing is installed incorrectly (a quick look at the diagram would show this).
the snap ring end is supposed to face forward and the slot in the bushing is supposed to face to the side.
also, this area needs to be greased liberally.
correct:
Eric&Barb
PostPosted: Fri Jan 29, 2010 8:40 am    Post subject: Reply with quote
The back one has no clip.
You can check out the parts manuals @
http://oacdp.org/
phipplet
phipplet is offline
PostPosted: Fri Jan 29, 2010 4:02 pm    Post subject: Reply with quote
Thanks Hazetguy! Very Happy You saved me. I was about to put the shift rod back in and the bushing would have been on backwards. There's got to be a way to delete that gallery pic to save other people from future problems.
Thanks again.
PostPosted: Fri Jan 29, 2010 11:05 pm    Post subject: Reply with quote
I edited the gallery entry above with a little note and a direction to this thread for the correct orientation.
bugcollections
bugcollections is offline
PostPosted: Sat Mar 13, 2010 2:28 pm    Post subject: shift rod bushing Reply with quote
Here is the one that I am replacing in my 65 westy. Hopefully installed correctly. And, yes, I had to cut off the coupler between the front and rear rod with a cut off tool. It was too rusted to budge with anything. It's going back together as soon as I get a new coupler.
sventinker
sventinker is offline
PostPosted: Sat Mar 13, 2010 4:02 pm    Post subject: Reply with quote
http://oacdp.org/5867part/359.png
I want to rebuild my shifting system. I see on this I need #17 and #21 which comes with #22 but what is part #19 in the diagram?
April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote:
Perfection only comes with delusion.
http://www.oacdp.org/
bugcollections
PostPosted: Sat Mar 13, 2010 4:59 pm    Post subject: shift rod build Reply with quote
You might want to go to wolfsburg west and do some searching. Can start here:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211711155C
And I think the part 19 you are referencing is the bushing for the front of the shift rod on a late 66-67 which are different than the 62. Assume you are asking for your 62 bus.
sventinker
PostPosted: Sat Mar 13, 2010 11:04 pm    Post subject: Re: shift rod build Reply with quote
yes thanks
Includes 6 popouts
025 Safety belts
Clara Premium Member
Clara is offline
PostPosted: Sun Mar 14, 2010 8:44 am    Post subject: Re: shift rod build Reply with quote
yes thanks
If you go to the next page, and find the entry next to #19, it describes what that part is for, you will see that it is used from ch 216 028 112. So it does not apply to an earlier bus like a '62
If you look at the same page next to #17, you will see how many it takes, and that there was a different version from VIN 835 088, so make sure you get the right kind.
http://oacdp.org/5867part/361.png
sventinker
PostPosted: Sun Mar 14, 2010 9:39 am    Post subject: Reply with quote
Thanks for the Clarafication Laughing
ok so I have read that I need two of that #17 bushing and two rubber boots but the diagram only shows one of each. I am not talking about the one bushing with the clip for up front. So where do the extra ones go?
Includes 6 popouts
025 Safety belts
BarryL Premium Member
BarryL is offline
PostPosted: Sun Mar 14, 2010 1:55 pm    Post subject: Reply with quote
If you're talking about the shuttlecock things and the bellows type boots, they go on the shift rod under the cargo floor. You have to pull the rod out the back. Two bushings suspend the rod inside the tube and the boots go on each end. I put worm clamps on the boots, too.
65Busstop
65Busstop is offline
PostPosted: Sun Mar 21, 2010 3:29 pm    Post subject: Reply with quote
My front bushing is missing. Can the front bushing be replaced without removing shift rod? Looks like bushing is split? Am I correct ? My Bus is a 65 is that the year they changed or 66?
420GOAT
Location: Wilmington, CA on a nice quiet street but still in the 'hood
420GOAT is offline
PostPosted: Sun Mar 21, 2010 5:04 pm    Post subject: Reply with quote
that bushing can be changed without removing the shift rod. i did remove the shifter and rear shift coupler from trans and rod. that thing is a bitch to get between the bracket and rod. i pulled on the edge of the bushing and pulled it through rotating the bushing while getting it to sit in the groove. clean any rust from the rod to get an easier fit and lightly grease it so it doesnt move too much.i just opened the snap ring and then closed it back when done. good luck
once you realize im not impressed we will get along just fine
Pistinbroke
Pistinbroke is offline
PostPosted: Tue Nov 09, 2010 9:33 am    Post subject: Reply with quote
Thanks for this thread and in particular to Hazetguy, solved a problem that had been bugging me for days. I had purchased a bush kit that included the later type front bush. I had a look at installing the correct bush earlier, but it didn't look right. However the photographs relieved me of my ignorance! Gear change now sweet...
Solan
Solan is offline
PostPosted: Wed Dec 01, 2010 7:32 am    Post subject: Shift rod problems... Reply with quote
Hi
I'm having a similar problem with my '65 11W Bus that I'm assembling now (sorry if I'm messing up the thread...).
It seems like my stickshifter is too short, or the bracket which the front shift rod goes through is too far down,
because the bottom of the shifter tends to slip out of the front shift rod "seat". Any hints?
Is it possible to mount a "short shifter" kit on a bus? (I think this will pull the shifter downwards?)
As I understand, the '65 doesn't have the "guiding pin" in the front of the shift rod to hold it in the right position vertically.
Cheers from Bergen, Norway
Svein
'65 11W Microbus
'52 Beetle ragtop
Page 1 of 6
