Rubbing issues
Taylor623
Taylor623 is offline
PostPosted: Sat Jan 30, 2010 3:41 pm    Post subject: Rubbing issues Reply with quote
If I run a 4" Narrowed Beam will i have rubbing issues on the inner fender wall when i turn?
Bruce
Bruce is offline
PostPosted: Sat Jan 30, 2010 10:28 pm    Post subject: Reply with quote
yes
Robs '52s
Robs '52s is offline
PostPosted: Sat Jan 30, 2010 10:47 pm    Post subject: Reply with quote
no
Volumex
Volumex is offline
PostPosted: Sat Jan 30, 2010 11:02 pm    Post subject: Reply with quote
definite maybe
IN2VWS
IN2VWS is offline
PostPosted: Sat Jan 30, 2010 11:04 pm    Post subject: Reply with quote
I think so
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
50ate
50ate is offline
PostPosted: Sun Jan 31, 2010 12:11 am    Post subject: Reply with quote
no you wont.. but mostly it depends on what tires your gonna run.. i have a 6in beam and its low and i run 145 65 on 5 spokes and i dont rub.. tires make the difference..
sparkleplenty
sparkleplenty is offline
PostPosted: Mon Feb 01, 2010 10:07 pm    Post subject: Reply with quote
If your Chaffing try baby powder or corn starch... Laughing
'56 European Oval Ragtop-Stock
'56 Karmann Ghia Coupe-Stock
'59 Italian Series I Li150 Lambretta-Stock
"Give a man a fish, feed him for a day. Teach a man to fish, feed him for a lifetime."
"Only when the tide goes out do you discover who is swimming naked."
downsbs
downsbs is offline
PostPosted: Mon Feb 01, 2010 11:42 pm    Post subject: Reply with quote
Possible, depends on tire size, wheel diameter and width, and offset of the wheel.
1956 Rag W/ Semaphores
Almost Alive
Almost Alive is offline
PostPosted: Tue Feb 02, 2010 3:34 pm    Post subject: Reply with quote
I have a 4.5" narrowed beam with 135's on the front along with air shocks. When its at about 3/4" off the ground on the beam your turning radius is about 30 feet. Rubbing all over the place... with a tasty smell to go with it.
When I've got about 4" under the beam it rubs a hair but all in all it rides like stock.
Not Safari Izzy
Not Safari Izzy is offline
PostPosted: Tue Feb 02, 2010 4:01 pm    Post subject: Reply with quote
In my car I have a 4" narrowed bean adjusted all the way down with dropped spindles and 4.5 porsche fuchs in front ...When I had 135's, they rubbed on the headlight buckets occasionally when the wheel was cranked all the way in either direction or when Ethan was in the car Smile. Now I have 125's in front and there is no rubbing at all...
DBK Nor Cal
1952 Beetle 11G
1956 Beetle 151
Almost Alive
PostPosted: Wed Feb 03, 2010 7:23 am    Post subject: Reply with quote
Any stopping issues with those thin tires? I know with 135's if I need to stop quickly I get a little sliding every once in awhile.
Not Safari Izzy
PostPosted: Wed Feb 03, 2010 6:42 pm    Post subject: Reply with quote
I had 135's on before the 125's and I haven't noticed any difference between them
DBK Nor Cal
1952 Beetle 11G
1956 Beetle 151
