Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3069 Location: Portland, Oregon
Posted: Sun Jan 10, 2010 4:48 pm Post subject: |
Okay, thanks to Timo78's investigation this fix seems to be a winner I finally got the parts together, tested it, and finalized on 17-ohms of resistance. Here's a pictorial of putting it together:
http://www.aircoolednut.com/cmgallery/index.php?cat=16
Click on the album titled "Bus fuel gauge vibrator replacement". It'll be the last album of the page in the lower right corner. Read the album description first before clicking it.
I'm not an electronics person so how I wired it all up and the exact resistors I used may not be electronically PC but since there wasn't much help, well, this is what you get until someone who knows more actually steps up and does it better. Assuming you already have wire and spade connectors then the total cost would be LESS THAN $6! That's pretty damn good in my book AND there are no moving parts.
<edit>BTW, if you click on the picture a window will open of just the picture and it will be much larger so you can see the details better. Click on the picture again to close the window and return to the album. _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Last edited by Air_Cooled_Nut on Sat Feb 06, 2010 8:33 pm; edited 1 time in total |
timo78 Samba Member
Joined: July 03, 2009 Posts: 931 Location: Overcast and Loving it
Posted: Mon Jan 11, 2010 8:04 pm Post subject: |
I like it! No moving parts is optimal. As a side note, I ran my tank into the reserve zone, and then filled up [yeah I'm chicken and, don't carry my plastic red can except on road trips ]. I put in 12.2g's, which means about 2g's reserve. Seems logical then that there's a direct correlation between visible Full and an accurate empty. If someone was inclined to add a pot/rheostat/ they would not need to empty the tank in order to set the adjustment and get accurate readings. Instead set the ohms at physical full and adjust to a visible full on the gauge. Or do the right thing and add the optimal AirCooledNut-resistor-pack, and adjust nothing. I may have to add one of those  _________________
> 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it? |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42791 Location: at the beach
Posted: Wed Jan 13, 2010 12:03 am Post subject: |
Really nice job.
There are many different kinds of these boxes but you might find a cheap small one that everything will fit in. That way you can build a box that is quickly and easily replaceable if the diode ever fails and keep a spare. All that would come out of the box would be three wires or connectors - in, out and ground. If one is small enough you could solder a tab on it and mount it in the same place as the original one.
_________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3627 Location: San Diego (Encinitas)
Posted: Sat Jan 16, 2010 11:39 pm Post subject: |
Here's an adjustable regulator regulator circuit to replace the vibrator. You can adjust the output voltage from around 7.5 vdc to around 10 vdc. Should make the gas gauge calibration easier.
If nowhere else, you can get all the parts from Mouser ( http://www.mouser.com ). The circuit's a little more complex than the fixed voltage regulator previously described, but flexibility costs a few more parts.
I used a 20 turn trimpot for the adjustable element, which makes setting the output voltage trivial. Tweek the adjustment until the gas gauge reads correctly.
The regulator chip (LM317T) will adjust its output to maintain 1.25 volts between the 'vout' pin and the 'adj' pin. Thus, the more resistance from 'adj' to ground, the higher the output voltage will be. If you want to tweek the design, remember that the output voltage = 1.25 volts x (total resistance / 240 ohms). The chip need about 2 volts drop across itself to function properly, so you can't get more than battery voltage - 2 volts out of it.
All resistors are 5% 1/4 watt; the bypass capacitor is a 50 volt ceramic (disc ceramic works fine.) All parts are non-critical, so use what you have. Build it in the nice box, shown above. Mount the regulator to the box using an insulating TO-220 mounting kit, and a little silicone grease, to keep the regulator cool (not that the gas gauge pulls much current...)
_________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Last edited by telford dorr on Sun Jan 17, 2010 12:06 pm; edited 1 time in total |
Posted: Sun Jan 17, 2010 9:19 am Post subject: |
Nice work, telford! Though I already did the leg work for the calibration  _________________ Toby http://www.aircoolednut.com/
The First Invasion |
Posted: Sun Feb 28, 2010 5:44 pm Post subject: |
Okay, it's official, this mod works great! At a full tank my gauge needle rests on the Full mark. When the needle is on the left white mark on the Reserve marking there is roughly just over 1 gallon of fuel left. Purposely ran out of gas and then filled up (without topping it off) and she holds 14.4 gallons.
I'm now back to driving with confidence with my gas gauge  _________________ Toby http://www.aircoolednut.com/
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5843 Location: Wamego, Kansas, USA
Posted: Sun Mar 14, 2010 6:41 pm Post subject: |
Telford Dorr,
Could you please write out the hookups "verbally" like someone did with the non-adjustable voltage regulator?
I stopped by Radio Shack this afternoon and picked up the capacitor, the adjustable regulator, and a 10k-Ohm 15-turn Cermet Potentiometer. I noticed that the potentiometer had three legs, one was the "wiper" leg. I measured the resistance between the wiper and each of the other two legs. I also measured the resistance between the two other legs. As I turned the dial, the resistance changed between the center and each of the two outer legs, and the total resistance was always the same. (So, if between the middle leg and the right leg was 4 ohms, then the left leg would be 6 ohms.)
Anyway, I figured that it didn't really matter which of the outside legs on the potentiometer I used.
So, here is how I hooked it up:
12V > capacitor > voltage in leg
ground > potentiometer > adjust leg
Gauge > voltage out let
However, when I hooked it up, I hooked up the new sender to the wires and expected to see the needle somewhere in the middle of the gauge.
Nope. Not even with the sender wires connected. No movement.
So I decided to try to hook the gauge to the 12v to see if the needle would do anything. It went up a bit then dropped and did this a couple times...
Did I wreck the gauge?
What did I do wrong hooking the VR up and such? |
Posted: Sun Mar 14, 2010 7:32 pm Post subject: |
Another Q:
I was looking around on other forums and found this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=400870&highlight=vibrator
which indicates that the vibrator is supposed to output 5v, not 10.
I wonder if all the resistors being used in this thread are, in effect, turning 10v into 5...
Anyone have thoughts on this? |
Posted: Sun Mar 14, 2010 8:58 pm Post subject: |
Well, we already worked out the kinks for a 10v VR, now it's your turn to do the same with a 5v VR...git!  _________________ Toby http://www.aircoolednut.com/
Posted: Mon Mar 15, 2010 10:20 am Post subject: |
Quote: |
I stopped by Radio Shack this afternoon and picked up the capacitor, the adjustable regulator, and a 10k-Ohm 15-turn Cermet Potentiometer. I noticed that the potentiometer had three legs, one was the "wiper" leg. I measured the resistance between the wiper and each of the other two legs. I also measured the resistance between the two other legs. As I turned the dial, the resistance changed between the center and each of the two outer legs, and the total resistance was always the same. (So, if between the middle leg and the right leg was 4 ohms, then the left leg would be 6 ohms.) |
Yup. But 10k-ohm? That will give you too much output voltage and make the adjustment 'touchy'. 500 ohm is ideal; 1 k-ohm will work in a pinch.
Quote: |
Anyway, I figured that it didn't really matter which of the outside legs on the potentiometer I used. |
The schematic has the labels on the pot 'ccw' and 'cw' (counter-clockwise and clockwise); hooking it up this way will cause the voltage to rise as you turn the pot clockwise, which seems 'natural', like a volume control.
Gauge > voltage out let |
Don't see a mention of the 240 ohm resistor from the chip's 'adj' leg to the 'output' leg. This component is critical, as it determines the current flow through the pot and, thus, the adjustment range. Without it, all you'll get is the chip's natural 1.25 volts output. Note: this value is specified by the chip manufacturer.
Also didn't see mention of the 1.2 k-ohm resistor from the bottom of the pot to ground. This resistor determines the lowest voltage output from the circuit. If you omit it, the voltage will adjust down to 1.25 volts; on the other hand, the maximum output voltage will be reduced quite a bit.
As long as the total resistance from ground to the 'adj' leg is around 1700 ohms, you'll get 10 volts out of the circuit.
Other than that, seems OK.
For reference: Vout = 1.25 + (0.00521 * R), where R is the resistance (in ohms) from ground to the 'adj' leg.
For example, if you want 7.2 volts out (to run a 6 volt gauge or something from 12 volts), then:
7.2 = 1.25 + (0.00521 * R)
5.95 = 0.00521 * R
thus
1142 ohms = R
Did I wreck the gauge? |
Probably not, unless it was already dead. I would have to assume that VW would figure that the regulator could fail, and as such, the gauge should be tough enough to take it (at least for a while.)
Probably best to 'bench test' the circuit before hooking it up to the bus. The circuit will operate fine with no load on it. You should be able to power it up by applying 12 volts to the input and ground to the bottom of the pot-resistor chain; you should see voltage on the output, and it should be adjustable. Set it to whatever voltage you want to run at. After you verify this, then install the unit in the bus and verify that the input voltage is 12 to 14 volts, and that the output voltage is still where you set it. If it is, and the gauge still doesn't indicate properly, then there is a problem with either the gauge itself, the sender in the tank, or the wiring between them. The Bentley says to ground the sender wire at the tank, and verify the gauge indicates 'full'; then open the wire to the sender and verify the gauge reads 'empty'. If this test fails, the wire or the gauge itself is bad; if it passes, then the gauge is OK and the sender is suspect.
Don't forget to heatsink the chip as needed to keep it cool. Shouldn't
need much with just a gas gauge; more load will require more heatsink.
Hope this helps. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Mon Mar 15, 2010 10:29 am Post subject: |
Quote: |
Well, we already worked out the kinks for a 10v VR, now it's your turn to do the same with a 5v VR...git! |
5.0 = 1.25 + (0.00521 * R)
3.75 = 0.00521 * R
720 ohms = R
where R is the resistance from ground to the regulator 'adj' leg. _________________ '71 panel, now with FI
Posted: Mon Mar 15, 2010 7:52 pm Post subject: |
Telford,
Thank you for the details. I had run into the Radio Shack actually after they closed. (The owner answered when I called yesterday to see when they closed, and he said "I'm just here doing paperwork, come on in.")
Anyway, he admitted that he wasn't real great with interpreting circuit drawings and such.
We ended up surmising that the adjuster is what determined the output of the VR, and it did so by the resistance to ground. We kinda thought that the resisters shown in the drawing were in lieu of the potentiometer.
So I guess I need to head back and get a couple resisters, and a different pot. They had a 10k and 1k ohm potentiometers.
I might also get a 5v VR just to see what happens. I know that it is no guarantee that VW used the same circuitry on other cars, but the rabbits and cabriolets used a 5v VR, and seeing the thread in the beetle forum makes me wonder... |
Posted: Thu Mar 18, 2010 8:16 pm Post subject: |
Air_Cooled_Nut wrote: |
So I picked up a 5v VR and pulled out the incomplete contraption that I had in there before. I hooked up the 5v VR just like someone had the 10v version earlier in the thread.
Starting out, the sender was uninstalled and sitting upside down, but the wires were connected to it. When I turned the key on, the gauge needle would go up to the R, and then quickly go back down and cycle.
So I went to the back and connected the two ground wires together and the needle went up to the top, just a little under the full mark. Then I installed the sender and hooked the wires up. The needle went just to the R but stayed. Not sure exactly why this is.
I have a couple theories on all this:
First, the used OEM sender I bought may be messed up. Maybe I can rebend the contact arm a little similar to the AFM to make it work.
Second, the factory thing really is supposed to be 5v. However, the 10v/Adjustable VR plus resistors kinda makes up for some resistance that is in the wiring. Remember, that the buses are 30+ years old and there are a few wiring connections for corrosion to build up in.
With the adjustable VR or correct resistors, you are compensating for the resistance in the wires by allowing a little more voltage to go into the gauge.
As I see it, the advantage to this for you guys is that you can fine-tune it to match the resistance in your particular system. The advantage of just sticking in a 5v VR is that it is simple and easy. |
Posted: Fri Mar 19, 2010 9:49 pm Post subject: |
vwwestyman wrote: |
Second, the factory thing really is supposed to be 5v. |
What proof for a Bus? I'd like to know your references.
vwwestyman wrote: |
I wonder if it truly is that easy. So far I've seen no proof. _________________ Toby http://www.aircoolednut.com/
Posted: Fri Mar 19, 2010 11:12 pm Post subject: |
I have no real proof that the vibrator in a late bay bus is supposed to be 5v instead of 10v. But my theory is based on some evidence.
First, this thread (which I posted earlier). Several people, including the last two, say that the vibrator in a Super Beetle is supposed to be 5v and is easily replaced with a 5v VR.
Of course, VW could have put a 10v in buses and 5v in beetles, but we all know that they always used the same parts in more than one car when possible. So if in fact it is true that beetles had 5v VRs, then probably buses did too. Newer watercooled cars used the exact 5v VR like from radio shack. Again, not proof but but evidence.
The fact that the gauge stayed too high when a 10v VR was installed (with no resister) makes me think that 10v is probably too much. Another piece of evidence.
This is the basis of my theory that the 10v VR with resistors is simply allowing you some adjust-ability of the current in the system through changing the resistance. I can't think of anywhere I've seen 10v shown as the proper voltage for this circuit other than here. The original idea was based off of a MGB's fuel gauge.
I'm not trying to be a punk or anything, just trying to contribute to the overall availability of information. |
Posted: Sat Mar 20, 2010 10:10 am Post subject: |
True and good observations. Sounds okay to me. But ya still gotta try it out  _________________ Toby http://www.aircoolednut.com/
Posted: Sat Mar 20, 2010 1:50 pm Post subject: |
Yeah, I'm pretty sure the stock setup from the factory was 5v, but the really good part about using the 10v regulator or adjustable regulator is that it allows you to compensate for whatever amount of resistance is in the system. One poster said that he used 17 ohms to make his gauge work right, but someone else may have more or less resistance in the system so 17 may not be anywhere close to the necessary amount.
I still need to figure out if I can make my new (used) sender work right. Since the needle goes to 1/1 when the two sender wires are connected, I can only surmise something is wacky to make the needle not go up there when hooked to the sender. If I can get that worked out, then I can see how closely the gauge works with the 5v resistor. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4659 Location: Oklahoma City, OK
Posted: Thu Dec 30, 2010 8:11 pm Post subject: Vibrator Test |
Brought this back to life due to some testing I have been doing.
The bench has 8 gauges, 8 vibrators, 3 senders, one of them new, plus a couple 5V Voltage Regulators, one NTE960 and a LM7805C ready for the fun to begin. First off was testing the senders, then ran voltage tests on all eight vibrators, two of them are extremely low mileage units, the vibrators do not put out 12V, in fact they do not even get to 5V, voltage ranges from 1.5 +/- .1V to a max of 3.8V, occassionaly there would be a spike to 4.2V. The norm was 2V to 3.5V. The vibrator does exactly that, pulses voltage, they are not a constant voltage devise which is what keeps the gauge needle from bouncing when the fuel gets sloshing in the tank.
The higher the voltage from the vibrator the higher the gauge will read at the full mark, the lowest vibrator at 1.5V will push the needle of the gauge even with the full line, the vibrators that has 2V as the lowest voltage will trip the needle 2mm past the full line. Did not matter which sender was hooked up, the two used and the new one gave the same reading. Tried numerous gauges including the two low mileage gauges, one with 54K and the other with 67K original miles, also installed different vibrators for testing with each gauge. Pretty much got the same readings, within 1mm spread across all the gauges and depending on which vibrator the empty was within 1mm and full 2mm max. Now this was all on an bench with good wire and a dedicated battery not powering anything else.
The 5V regulators also worked, slight movements with the sender did not cause the gauge to fluctuate. But have not done over the road thesting.
Now there are two adjuster holes on the gauge, one for empty and one for full, with a small screwdiver the max travel of the neddle can be set, now I have only bench adjusted based on the movement of the sender clamped in the vise. Suspect this would do the same thing as a Pot will do.
Now my bus which has always had goofy fuel readings, never would get to full and be in the red with five gallons still in the tank. For fun I ran a wire from the sender to the gauge, yes I do have a sender access hole and gained 2mm of needle movement up, so there is some resistance in the old sender wire. Something to consider when concerned about low or inaccurate gauge readings.
The above is not all conclusive or absolute, the use of a Voltage Regulator with resistors or a pot is probably a better solution than buying a vibrator, at least cost wise, as for constant 10V hitting the gauge I have no idea what it will do in the long run. Even with the VR/Res/Pot there is still the mechanical sender, gauge and ten to twelve feet of 30+ year old wire.
I do plan on putting the new sender in, best reading vibrator and run a new sender wire to the dash, then fill the tank and perform adjustments to either the gauge or sender to read dead on full, then start draining the tank to verify 1/2 tank, reserve and finally set dead on empty. |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Fri Dec 31, 2010 4:14 pm Post subject: |
THANK YOU!
I have been asking around for these numbers for years. because I had no functioning vibrator / zener and light bulb based voltage/current regulator I had to guess. And guess I did. On here or AVD or somewhere else I did a writeup of my findings.
The only info i could find was for a 6v beetle and it wasn't the most relevant.
Now my old calculations have disappeared into the aether and I needed the info again.
The best setup i had was running a truck fuel gauge with a parking light as a current limiter and a resistor between a couple of the terminals. I tried putting a smaller bulb on but the gauge pretty much just reads empty now. I've been hesitant to put the parking light bulb back on because a better solution had to be out there. Thank you
I have to read some of the posts here more closely still, but when the linear regulator is being used (the variable voltage type which is set using a resistor right?) what is being done about current limiting? If nothing, those little regs can push more than an amp if allowed to. Of course they burn up awfully quick that way. If it's a fixed voltage type and it is connected backwards by accident, absolute mayhem ensues. it's hard to explain and took me a lot of probing to figure out what happened on a piece of computer interface hardware i was developing. It seems counter intuitive but it was still trying to regulate the voltage but by dragging the ground plane up. Add to the mix a second regulator trying to do things the right way and things get very ugly very fast. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Fri Dec 31, 2010 6:34 pm Post subject: |
Suspect that the 5V for buses and 6V for bugs is nothing more than factory max volts, cause no vibrator I have tested reaches the 5V range.
Did some more testing with the 5V Regulators today, seems after a minute or so the voltage begins to climb, the LM7805 triped past 10V and the NTE climbed to 9V, so fixed regulators they are not. And with the voltage increase the needle rises on the gauge. |
