sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2681 Location: Phoenix AZ
Posted: Tue Mar 16, 2010 5:49 pm Post subject: E-brake for '58 with big nut rear end? I searched. |
ok so i have a big nut in my 58 what ebrake cables do i need yes i did a search with no luck _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Fish Samba Member
Joined: December 05, 2000 Posts: 5958 Location: OB. It's beside the point.
Posted: Tue Mar 16, 2010 6:09 pm Post subject: |
IRC you need 64-67 E cables so they will fit the backing plate hardware of the big nut trans, HOWEVER you will need to modify (shorten) the cables to fit the fronf E brake handle. _________________ Prosit!
# 303 and #156
Posted: Tue Mar 16, 2010 6:21 pm Post subject: |
and how is that done _________________ 58' pg/sg silo fridge westy
76 911S |
58deluxerag Samba Member
Posted: Tue Mar 16, 2010 6:27 pm Post subject: |
With a pair of cable cutters and some cable u-clamps from the hardware store, I think would do the trick. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
Posted: Tue Mar 16, 2010 6:32 pm Post subject: |
sounds kinda chincy _________________ 58' pg/sg silo fridge westy
76 911S |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26130 Location: Olympia Wash Rinse & Repeat
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Tue Mar 16, 2010 11:20 pm Post subject: |
Do a search for "emergency brake cables" in the forum: I have a thread in there on how to modify the later model rear brake plate so you can use the earlier emergency brake cable. It is easy to do. Put the old brake plate next to a newer one and you will see what you have to do. _________________ Don't worry; be happy. (Baba) |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Wed Mar 17, 2010 5:09 am Post subject: |
I modified the 58 ebrake cable to fit the later backing plates.
_________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20885 Location: Sandpoint, ID
Posted: Wed Mar 17, 2010 10:44 am Post subject: |
^^^ That looks like the best/easiest way to get this done. I like Cameron's idea, too. I will be doing this soon and have already bought new later cables since that was the only way I knew. Guess they will just go into the spare parts box now.
Going back to the idea of shortening the cable, does anyone know how much has to be cut off? I just figured that, for future reference, an actual length in inches (cm ?) should be posted. It would come in handy for a future search if someone is in a pinch for time/lack of proper parts. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2377 Location: Millwood, Wa
Posted: Wed Mar 17, 2010 12:09 pm Post subject: |
I have done this three times, I did my cables 11 5/8" shorter, at least thats what my notes say. I also do my adapters in the backing plates
2 1/2" _________________ ---
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
Campy Samba Member
Posted: Wed Mar 17, 2010 12:46 pm Post subject: |
Since it is easy to do, I think that fixing the brake plate so it looks like the older one is the way to go. The four spot welds holding the platform on the outside of the brake plate (the stop for the cable's housing) have to be ground down so it can be removed, the hole in the plate lengthened (look at the hole in the older brake plate), the axle end of the hole bent to the outside, then a hole drilled in the brake plate where a small bolt and nut will hold the cable stop that you use from the old brake plate in place. This method allows you to use the old style (shorter) emergency brake cables and it keeps the stock look.
Don't splice the cables. _________________ Don't worry; be happy. (Baba) |
Posted: Wed Mar 17, 2010 12:50 pm Post subject: |
thanks guys this is the must usefull info yet
if it came down to splicing the cables id stay with my tire chock method _________________ 58' pg/sg silo fridge westy
76 911S |
Mikee Samba A.D.D. Boy
Joined: March 22, 2004 Posts: 3513 Location: Puyallup WA
Posted: Wed Mar 17, 2010 2:23 pm Post subject: |
sub-hatchtim wrote: |
if it came down to splicing the cables id stay with my tire chock method |
Tire chocks dont help when you are driving and you blow a wheel cylinder going down a hill, and you have no ebrake to pull on and you almost flip your 23 window, not that i am talking from my past expierence. _________________
localboymark wrote: |
One man's "patina" is another man's cancer. |
bugnut68 wrote: |
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck. |
Posted: Wed Mar 17, 2010 2:27 pm Post subject: |
I like to approach these adaptations with an eye toward future repairs. If I am on the road and have to fix something, what can I do now to make that repair easier in the future?
I would think that Cameron's setup is tops for that issue. It just uses some extra hardware that will already be on the old cables so it's a simple (ish) swap if a cable breaks.
Jeremy's setup would be pretty simple to replicate on the roadside, too. Just need something to cut the steel housing with.
Modifying the backing plates is nice because it allows use of the later, and more readily availabe, e-brake cables.
The cable shortening kit would work in a pinch, but if I have the time, I would rather not use them. Maybe they could be handy in the emergency repair parts box under the seat, just in case.
Lastly, having the cables shortened and having the ends swedged on (or swaged) works great, but I would want to do a couple of sets so that if I break one on the road, I don't have to search out a wire rope supplier.
Great info in this thread. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Posted: Wed Mar 17, 2010 3:08 pm Post subject: |
dam mikee cant say ive ever had that problem
id love to have my cables swedged but cant find any one in the area to do so
and sorry but cable splicing seems dangerous these are buses not farm implaments _________________ 58' pg/sg silo fridge westy
76 911S |
Campy Samba Member
Posted: Wed Mar 17, 2010 4:27 pm Post subject: |
My method works great but I am beginning to think that I am the invisible man.  _________________ Don't worry; be happy. (Baba) |
Posted: Wed Mar 17, 2010 5:55 pm Post subject: |
id love to have my cables swedged but cant find any one in the area to do so |
Have heard that some motorcycle shops can do that for you. _________________ In Stereo, Where Available! |
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1066 Location: Gilbert,Arizona
Posted: Wed Mar 17, 2010 6:56 pm Post subject: |
Campy wrote: |
My method works great but I am beginning to think that I am the invisible man.  |
Maybe because your method would ruin a perfectly good late backing plate. I suppose if you could weld,you could put it back.
I am still on the fence with this topic,don't know which method is best. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
Posted: Wed Mar 17, 2010 7:08 pm Post subject: |
i havnt decided either _________________ 58' pg/sg silo fridge westy
76 911S |
Posted: Wed Mar 17, 2010 10:14 pm Post subject: |
Campy wrote: |
I mentioned your method, but not your name. Sorry. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
