njmedic3306 Samba Member
Joined: February 25, 2010 Posts: 43 Location: New Jersey
Posted: Thu Mar 18, 2010 7:04 am Post subject: Want advice on YOUR driving Technique |
Here is an argument I am having with my close misguided friend. Please help me with this simple question.
If you were driving down a hill covered in snow which technique would you use. Please explain why so I can help explain this one.
1. Put the car in Neutral and carefully use the brake. (his method)
2. Put the car in first and and use the brake as little as possible. (my method) |
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Thu Mar 18, 2010 7:30 am Post subject: |
there are no hills or snow where I live in florida. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
baja5 Samba Member
Joined: February 28, 2004 Posts: 4326 Location: Ramona,Ca.
Posted: Thu Mar 18, 2010 7:36 am Post subject: |
Putting a car in nuetral while going down a hill is always a bad idea, brakes heat up quickly and then stop working. _________________ http://www.wix.com/baja5s/nightrun |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12540 Location: Over 2002 posts deleted!
Posted: Thu Mar 18, 2010 7:44 am Post subject: |
my65vert wrote: |
there are no hills or snow where I live in florida. |
Well, it snowed there recently but there's DEFINITELY no hills whatsoever in Floriduh!
There may me a lump or some such but no hills!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
mlhsquared Samba Member
Joined: October 13, 2008 Posts: 1482 Location: Strasburg, VA
Posted: Thu Mar 18, 2010 7:46 am Post subject: |
Any time that you can select a lower gear and let the engine/transmission do the work, it's usually the best way to go. Brakes lock up, which means the car skids or slides... not good. Low gear (with an appropriate amount of braking) gives you a slow, controlled descent. Ask any die-hard four wheeler about using the gearing to accomplish ascents and descents. _________________ Mike
'67 Ghia Coupe |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Thu Mar 18, 2010 7:51 am Post subject: Re: Want advice on YOUR driving Technique |
njmedic3306 wrote: |
Correct. _________________ Greg
Model Citizen
johnnypan wrote: |
I digitize myself in the privacy of my own home. |
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
Posted: Thu Mar 18, 2010 9:29 am Post subject: |
Colorado we have both snow and hills. As a previous school bus driver, ALWAYS use your gearing to control your speed on hills and ice. _________________ and take the kids for instance "Are we going in the Volkswagen bus?" and they say "Yay!" and clap their hands and if it's a glorious day you can slide the sunroof back and let a little of the glory in and all of a sudden, it stops looking funny.
-Volkswagen ad |
90Doka_Guy Samba Member
Posted: Thu Mar 18, 2010 9:46 am Post subject: |
#2 on non icy pavement definitely. Although if the driver sucks at rev matching I would argue that #1 might be better on icy hills. I never coast in neutral though. Always in gear. |
rustfree1967bug Samba Member
Joined: November 16, 2006 Posts: 3440 Location: minnesota
Posted: Thu Mar 18, 2010 9:48 am Post subject: |
I pretty much always let my engine slow me down when im going down hills. Going down one hill in town this winter though I had the car in either 2nd or 3rd gear and i came to a ice patch the rear rear tires started sliding. So leaving it in gear is not always the best option. _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI |
iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9944 Location: Somewhere between Dubuque and Keokuk
Posted: Thu Mar 18, 2010 9:54 am Post subject: |
Rustfree is right.
There is no absolute answer to the question. On extreme glare ice on a steep down grade there are instances where the lowest gear might still propel you too fast at idle. Other factors---front wheel drive or rear wheel?
ABS or traditional brakes? Standard transmission or automatic?
The bottom line is this: if it is too slippery for a driver's skill level, he should stay home. |
GREG.M Samba Member
Posted: Thu Mar 18, 2010 12:32 pm Post subject: |
Having driven a wrecker for 5 years, and having leared from a guy that owned the business and drove wreckers for about 45 years. He taught me to stop at the top of the hill put the vehicle in neutral and slowly release the brake pressure (foot feed not handbrake) till the vehicle begins to roll. then hold that pressure till you get to the bottom of the hill. I have used this method for about 20 some odd years in wreckers,tractor trailers, and my own personal vehicles and have never had an accident (knock on wood). His reasoning behind using this metod is if you have the car in gear and apply the brake you are both pulling (going) and stopping at the same time so you don't have control over the vehicle.
Greg |
Fish Samba Member
Joined: December 05, 2000 Posts: 5902 Location: OB. It's beside the point.
kaiser Samba Member
Posted: Thu Mar 18, 2010 12:59 pm Post subject: |
hammer it 1/2 way down, when at the bottom pull the ebrake.
j/k |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Posted: Thu Mar 18, 2010 1:24 pm Post subject: |
Most cars do most of the braking with the front wheels. On the vast majority of cars, you steer with the front wheels.
On any slippery surface, be it ice, be it rain or snow, you MUST have the front wheels rotating. Non Rotating wheels do not steer a car. They just slide along straight ahead even if you have them turned at an angle.
Again, the steering wheels MUST rotate.
That being said if you are depending upon your brakes coming down a slippery hill, as soon as you touch them, the front wheels can stop rotating. No rotation, no control.
Leave the car in gear and allow the engine to brake you down.
The trouble with an automatic is that it is ALWAYS in gear and trying to go so things get a tad more difficult to control in slippery situations.
If I must slow down in a slippery situation I will take my foot off the gas and GENTLY apply the hand brake, don't lock up the wheels but drag them. This provides some braking action and also maintains steering control.
Your friend, well he is WRONG!!! and will someday regret his habit!
I'm in NJ, what's he drive so I can watch out for him?!? Then again, he isn't alone, these highways are COVERED with crazies!!!
Ghia
Vanagon
Beetle
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Mar 18, 2010 1:58 pm Post subject: |
With automatic's you can down shift manually.
OH, Wait, the new transmissions don't have a 2nd and low, only D N R P. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
Hellaslow Samba Member
Joined: September 08, 2009 Posts: 500 Location: Tampa, Fl
Posted: Thu Mar 18, 2010 2:17 pm Post subject: |
pyrOman wrote: |
my65vert wrote: |
There may me a lump or some such but no hills!  |
It didn't snow in central florida (tampa)... _________________ I ♣ Baby Seals
click to see local Tampa events: http://www.thesamba.com/vw/forum/viewtopic.php?t=427873
56 vacho
40yo fat chick
www.tamparacing.com
<--- non proper vw owner |
Posted: Thu Mar 18, 2010 3:26 pm Post subject: |
I have had rare occasions where I have put an automatic transmission in REVERSE and then held the vehicle back with a little throttle to keep the front wheels from locking (thus not steering). Extreme, I know, but in over fifty years as a licensed driver (some years driving upward of 75,000 miles)I have never had as much as a fender-bender.
Like I said before, there is no correct answer that fits every situation. |
Fish Samba Member
Posted: Thu Mar 18, 2010 3:36 pm Post subject: |
djkeev wrote: |
Dave |
Make good sense. No snow or icy driving for me here in sunny Southern California, but I have applied the same theory when driving off road on loose sand and gravel. I should have made the connection earlier.  _________________ Prosit!
# 303 and #156
stale air Samba Member
Joined: August 23, 2007 Posts: 5658 Location: Senoia Ga, formerly NorCal
Posted: Thu Mar 18, 2010 3:40 pm Post subject: |
Thats what I would do, use the compression of the motor as well as the brakes to help you keep a safe speed. _________________ WANTED: Henry Veale Santa Rosa plate frames
