speedo face
vw_hank
vw_hank is offline
PostPosted: Fri Mar 26, 2010 2:45 am    Post subject: speedo face Reply with quote
I have A 1972 super, its A euro spec car but it has A MPH speedo, and I wont A KPH one, Is there anyone making/selling Just the face plate to do this? I did A search but didn't find anything..
DanKGMadrid
DanKGMadrid is offline
PostPosted: Fri Mar 26, 2010 4:54 am    Post subject: Reply with quote
I have exactly the same problem as of toady. I went for an MOT in Spain and failed because of the MPH speedo. I was thinking of buying a new speedo but the best option would be if some kind person is restoring their KPH speedo put in onto a scanner and took an image. Any help out there?
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Mar 26, 2010 5:00 am    Post subject: Reply with quote
Does it matter that your odometer will still read miles even if you change the faceplate? If so, then you might be better off getting a KPH speedometer. Or you could get a late-model (or replacement) Beetle speedo head that has both scales on the dial. (beware though of busted-odometer-gear syndrome, very common on the later model speedo heads due to the plastic odometer drive gear they went to)
-Andy
DanKGMadrid
PostPosted: Fri Mar 26, 2010 5:06 am    Post subject: Reply with quote
Thanks for your advice. I'm not bothered about the "miles" clocking up. Its just to pass the test. I can see your point though, could invalid any special "classic" car insurance that gives you a certain number of kilometres a year. I'd prefer to leave whats in there and just change the face.
The Android
PostPosted: Fri Mar 26, 2010 5:46 am    Post subject: Reply with quote
The needles in the speedo heads from the mid 70s up can be very hard to remove without destroying them. But earlier on they aren't as bad. But you do run into the problem of getting the needle pretension set up again once you're putting it back together (important if you want it to read accurately)
In the Gallery I found this photo of a later KPH speedo head, probably not a good enough image for what you were wanting though:
DanKGMadrid
PostPosted: Fri Mar 26, 2010 6:00 am    Post subject: Reply with quote
Thanks thats great. I'm probably going to take mine out and photograph it. A bit of photoshop to create a sort of "donut" shaped ring so that I don't have to remove the needle.
DanKGMadrid
PostPosted: Fri Mar 26, 2010 7:20 am    Post subject: Reply with quote
Just read this thread :
http://www.thesamba.com/vw/forum/viewtopic.php?t=393317&highlight=speedo+kph
Great idea the plastic clear sheet. That got to be the easiest option.
DanKGMadrid
PostPosted: Sun Mar 28, 2010 2:59 pm    Post subject: Tiff document. Reply with quote
Hope this helps. I'll try and print it out tommorow and let you know how it went.
The large image is here.
http://www.flickr.com/photos/48808081@N07/
The Android
PostPosted: Sun Mar 28, 2010 3:14 pm    Post subject: Reply with quote
Looks pretty good. So where did you come up with the photo or photos you used to draw that up?
-Andy
DanKGMadrid
PostPosted: Sun Mar 28, 2010 3:56 pm    Post subject: Reply with quote
Thanks. Will need some tweaking I'm sure. I took the speedo out of my beetle and photographed it. Here is the original.
I used a ruler to get the measurements straight on the photoshop document.
Joel
Joel is offline
PostPosted: Sun Mar 28, 2010 6:17 pm    Post subject: Reply with quote
you need to match the face with the type of speedo
ie a 100mph speedo needs a 160km/h face where as the 90mph would need a 145/km/h face
keep a look out on aus ebay and i think some of europe had KM/h speedos too
they come up on ebay a fair bit here
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
DrDarby
DrDarby is offline
PostPosted: Sun Mar 28, 2010 6:25 pm    Post subject: Reply with quote
I have several KPH speedometer face plates for 1972+ speedometers if anyone needs one. PM me.
Midwest Autosavers, Inc. Crystal Lake, IL
vw_hank
vw_hank is offline
PostPosted: Sun Mar 28, 2010 10:35 pm    Post subject: Reply with quote
DrDarby wrote:
I have several new KPH speedometer face plates for 1972+ speedometers if anyone needs one. PM me.
PM sent.. If you can wate tell the end of the weak? 1972 & up is what I need Very Happy
DanKGMadrid
PostPosted: Mon Mar 29, 2010 2:59 am    Post subject: Reply with quote
I hear what you are saying and thanks for the tip. I'll be changing the speedo as funds allow. Priority is to get this car through the test within a 10 days (or I'll be charged again!). It only failed on not having kph on the dial. Grrrr.
DanKGMadrid
PostPosted: Mon Mar 29, 2010 11:17 am    Post subject: Reply with quote
Well here is the first test version. I'll need to tweak it a little to fit at the top, but even if I do say so myself it looks pretty good. I'll do a decent matt colour print of the final version and if it works I'll send the post the image for whoever needs it.
Without glass in.
With glass.
I reckon it should fool the guys at the test station. I'll go rush hour. Wink
vw_hank
vw_hank is offline
PostPosted: Mon Mar 29, 2010 12:35 pm    Post subject: Reply with quote
Dude that came out grate!
Inane Cathode
Inane Cathode is offline
PostPosted: Mon Mar 29, 2010 1:09 pm    Post subject: Reply with quote
Without glass in.
With glass.
What kind of ink are you using to last long at all?
DanKGMadrid
PostPosted: Mon Mar 29, 2010 1:56 pm    Post subject: Reply with quote
I was thinking of getting the image processed by a photo lab. On matte paper. Not sure how long that could last though!
The Android
PostPosted: Mon Mar 29, 2010 2:24 pm    Post subject: Reply with quote
I wonder if you can get waterproof laser shipping labels in larger sizes anymore, I've made adhesive decals on that kind of thing before, went to Kinkos and rented a computer upload my images and sent them to their best laser machine which they had set up properly to print on the label sheets I supplied them.
pafree
pafree is offline
PostPosted: Mon Mar 29, 2010 3:18 pm    Post subject: Reply with quote
glutamodo wrote:
I wonder if you can get waterproof laser shipping labels in larger sizes anymore, .
Office Max or Depot carries the full page sticky page. just print it out with your home printer.
you could get creative. maybe the inspection guy would likey.
not a great picture but after you apply the sticker then you can cut out for the odometer and fuel gauge and warning lights.
demo. i know the needle broke.
