Got wrong stroker crank - What to do?
Page: Previous  1, 2
bartman
bartman is offline
PostPosted: Wed Apr 14, 2010 6:36 am    Post subject: Reply with quote
I'm building a 78x94 engine. With the B pistons, i have about .2"
deck. I'm in the process of trying to trade them for A pistons.
This deck is with a stock rod. A longer rod would get it closer to where it should be. I did a pretty thorough search and didn't find the info about 78mm cranks vs B pistons. Some sort of chart to get builders into the ballpark, at least, would be handy.
If you have the clearance and a decent rod ratio, i think you may be better off with the 82.
[email protected]
john@aircooled.net is offline
PostPosted: Wed Apr 14, 2010 6:42 am    Post subject: Reply with quote
this is why building with a 78 crank is such a mistake, my opinion.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Matthew
Matthew is offline
PostPosted: Wed Apr 14, 2010 8:40 am    Post subject: Reply with quote
If you use A pistons, you will have huge spacers and a wide engine. Why not face some material from the base of the cylinders to achieve the correct deck with the B pistons?
1965 Beetle sedan
Click to view image
grimace007
grimace007 is offline
PostPosted: Wed Apr 14, 2010 8:47 am    Post subject: Reply with quote
or for the same price, go 82 stroke and have a stock witdh engine with alot less deck height and easier to assemble
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
bugnut68
bugnut68 is offline
PostPosted: Wed Apr 14, 2010 8:52 am    Post subject: Reply with quote
jamestwo wrote:
No, they did you a favor. With the 78.4 you was heading for all kind of problems setting the deck.
Hp won't be less, it will just come at a lower RPM.
What kind of problems? That's what I'm working with for my 2017 build, as I was advised it was a good crank to go with due to less clearancing involved, etc.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Teeroy Premium Member
Teeroy is offline
PostPosted: Wed Apr 14, 2010 8:57 am    Post subject: Got wrong stroker crank - What to do? Reply with quote
With the 78 you end up with extra deck, not really a problem just an extra step. You need to machine the bottom of the cylinders or deck the case or both if running 94's. Or if you don't have all your parts yet, get longer rods.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Matthew
Matthew is offline
PostPosted: Wed Apr 14, 2010 8:57 am    Post subject: Reply with quote
grimace007 wrote:
Matthew wrote:
deck. ..
I agree, I was just working with the 78mm crank as a given. If I had the choice I would go 82 for sure.
1965 Beetle sedan
Click to view image
grimace007
PostPosted: Wed Apr 14, 2010 9:31 am    Post subject: Reply with quote
Matthew wrote:
grimace007 wrote:
Matthew wrote:
deck. ..
well if it was given to you then run it by all means Smile
sometimes you can get lucky in the classified and find someone wanting a shorter stroke in trade for their 82
Brian
68 sedan
Dallas Air Coolers
bugnut68
bugnut68 is offline
PostPosted: Wed Apr 14, 2010 10:20 am    Post subject: Re: Got wrong stroker crank - What to do? Reply with quote
No one mentioned this to me when I first started asking around for feedback on the build I've got coming together. I kept hearing that a 78.4mm build is a pretty trouble-free route to take, and a good option, but no one ever mentioned anything about deck difficulties. I'd heard about that problem with the 74 and 76mm cranks, but not 78.4 units.
I'm not terribly worried, as I know I can handle getting the deck where it needs to be, I'm just a little surprised this is the first I've heard about it.
bartman
bartman is offline
PostPosted: Wed Apr 14, 2010 6:36 pm    Post subject: Reply with quote
A 78mm crank (well, my 78mm crank with my case and stock rods) with A pistons results in a deck of about -.2". This requires about half an inch of shims, total.
My combo with B pistons has about .2" of deck. This is only a problem if one lives in a boonfuck town with one machine shop that has no idea what one is talking about when one takes them a jug and asks about taking material off the bottom.
The solution, as mentioned, is to change rod length or take a trip to the big city where machine shops know what the hell they're doing.
IMO, the 82 is a better and easier build. the 78 works if one gets the rod length right.
I have stock rods and I'm considering getting a longer rod and selling my 311b's. In my case, this would probably be cheaper than machine work. I do have a guy that might trade my B pistons for a set of A's. This is the cheapest fix, requiring shimming to dial in the deck.
slingblade
slingblade is offline
PostPosted: Wed Apr 14, 2010 7:06 pm    Post subject: Reply with quote
sweet mistake cb made,,you,ll love the torque
you had better brace yourself for whats on the other side,,evel knevil
bugnut68
bugnut68 is offline
PostPosted: Thu Apr 15, 2010 8:47 am    Post subject: Reply with quote
I'd forgotten to mention earlier that I have 'B' pistons... I haven't begun to put this engine together yet, so I guess I'll see where I'm at when the time comes.
Page: Previous  1, 2
Page 2 of 2
