Sambanista help needed in Colombia
Farf
Farf is offline
PostPosted: Sat Apr 17, 2010 12:12 pm    Post subject: Sambanista help needed in Colombia Reply with quote
Yes, that Colombia, we are traveling in an 86 Syncro Westy with a stock 2.1L motor. When we started the van would use about 1/2 quart of oil per 1000 miles. In the past couple of weeks cruising around Columbia the oil usage increased to 1/2 quart per tank of gas. With this increase came poor performance and #2 sparkplug fouling to the point that it would not fire. Performed compression test. Results #1- 125, #2 - 70, #3 - 123, #4 - 115 respectively. (It took 5 days to find someone with a compression gauge.)
Additional info:
1. New heads both sides 15K miles ago.
2. Small amount of smoke/vapor when cold, not noticeable when hot.
3. Coolant level decreases about 1 cup per tank.
4. No visible oil in coolant, no visible water in oil.
5. Very oily exhaust port #2 cylinder.
6. #2 exhaust valve spring top (disc where adjuster hits) slighty fouled.
7. Oil warning light/buzzer going off (not constantly)
8. On the flats no performance issues, slight hills 3rd gear, forget it.
9. 200k miles on vehicle. Don't know if bottom end has been touched.
Not sure what else to check or do to indentify parts needed for repair. Any helpful suggestions would be appreciated. Negative comments about Central/South America are not helpful at this time. I have an opportunity to have parts flown here quite quickly (brother visiting), hoping you guys can help.
Gracias, Mike
[/b]
Alaric.H
Alaric.H is offline
PostPosted: Sat Apr 17, 2010 2:20 pm    Post subject: Reply with quote
Sounds like the next step should be a leak down test.
http://www.thesamba.com/vw/forum/viewtopic.php?t=409450&highlight=
Farf
Farf is offline
PostPosted: Sat Apr 17, 2010 4:06 pm    Post subject: Reply with quote
Thanks for the reply. Not sure anyone around here has the test equipment. I'm in a fairly remote area about a 4 hour bus ride from Bogata. I don't want to risk driving the van that far as it is. I spoke with my brother, he's thinking he will fly down with all the stuff needed for a complete top-end rebuild. I know this sounds excessive but we still have another year or more put aside for our trip and don't want to end it because of this. I will keep you guys posted about the outcome. Suggestions and advise are still very welcome.
Mike
Farf
Farf is offline
PostPosted: Sat Apr 17, 2010 4:16 pm    Post subject: Reply with quote
Alaric H. I posted before I read your link about leak down testing. I do have a compressor with a gauge attached and I have a fitting that I think I can adapt to the sparkplug hole. I'll try pressurizing the cylinder tomorrow with the valve cover off and listen for leaks. It would be nice to narrow down the source of oil in the cylinder.
Thanks again, Mike
Californio
Californio is offline
PostPosted: Sat Apr 17, 2010 5:17 pm    Post subject: Reply with quote
Not sure if it helps given your distance from Bogota, but here's a link to mechanic listings: http://www.encolombia.com/CARROS/TALLERESDEMECANICA/Mecanicabogota.htm
¿Donde esta Larry Chase cuando necesitamos?
AND Parts and repair shops specializing in VWs in Colombia (all in Cali, Medellin, Bogota, though--where are you?)
Cl 72 A 20 C-71
Colombia - Distrito Capital, Bogotá
Teléfono(s) : (57) (1) 3476800
Fax : (57) (1) 3478900
Secciones
Agregar a mis páginas amarillas
... original de fabrica y mas de 12 marcas a nivel de taller general contiene funciones matematicas y funciones ... diagnostico original de fabrica oem 11 data scan especializado en vehiculos europeos equipo especializado para ... vehiculos comerciales diesel mercedes renault volkswagen y citroen entre otros gracias a su nueva tarjeta ...
AUTOTOOLS LTDA.
SERVICIO WOLKSWAGEN0
Cr14 21-31
Colombia - Valle del Cauca, Cali
Teléfono(s) : (57) (2) 8851330
Secciones
LA CLÍNICA AUTOMOTRIZ VOLKSWAGEN0
Cl 19 A 23-60
Teléfono(s) : (57) (2) 3345720
Secciones
VOLKSWAGEN EURO ALEMÁN0
Cr69 C 94 A-26
Teléfono(s) : (57) (1) 2532136
Secciones
EUROVOLKSWAGEN0
Cl 32 65 A-6
Colombia - Antioquia, Medellín
Teléfono(s) : (57) (4) 2659734
Secciones
SUPER VOLKSWAGEN0
Cl 130 45-63
Teléfono(s) : (57) (1) 6152867
Secciones
SERVICIO ESPECIALIZADO VOLKSWAGEN SANTIAGO ARAGÓN0
Cr28 B 66-56
Teléfono(s) : (57) (1) 2500987
Secciones
TALLER DISA VOLKSWAGEN - SKODA0
Cl 37 32-24
Colombia - Valle del Cauca, Palmira
Teléfono(s) : (57) (2) 2735537
Secciones
TALLERES SUPER VOLKSWAGEN0
Cl 70 72-80
Teléfono(s) : (57) (1) 4300855
Secciones
TALLER VOLKSWAGEN0
Cr64 B 74-37
Teléfono(s) : (57) (4) 2576985
Secciones
AUTOTEKA S.A.S920
Repuestos y accesorios para Volkswagen, Skoda, Seat, Audi, Peugeot, Citroen, Renault, Fiat, Chana, Chery y Hafey. Servicio a domicilio de repuestos sin costo adicional. Se aceptan todas las tarjetas.
Cl 23 3-07
Teléfono(s) : (57) (2) 8881282,(57) (2) 8881797
Fax : (57) (2) 6807324
Secciones
GERMANIA MOTORS620
Volkswagen, Automovíles nuevos, Autos Usados, Taller Volkswagen, Repuestos Volkswagen, Space Fox, Crossfox, Gli, Nuevo Gol, New Beetle, Jetta Europa, Jetta Trendline, Jetta Turbu, Bora Exclusive.
Cl 29 # 43A-29
Teléfono(s) : (57) (4) 3549797
Secciones
GERMANIA MOTORS S.A.
AUTO PARTES VOLKSWAGEN CÍA. LTDA.920
Repuestos Originales - Gol - Golf Polo - Jetta - Audi - Skoda - Accesorios y Partes Volkswagen.
Cr27 A 66-96
Teléfono(s) : (57) (1) 2256762
Fax : (57) (1) 3110712
Celular : (57) 3164735713
Secciones
EUROCARVAJAL S.A.S790
Mantenim. Audi Volkswagen Skoda Seat.
Cl 75 69 Q-66
Teléfono(s) : (57) (1) 3114887
Celular : (57) 3102458769
Secciones
EUROCARVAJAL S.A.S
VOLKSWAGEN R.W750
Importación directa - venta - reparación - accesorios - Volkswagen - audi - Escanersde servicio especializado - Sscane.- Aurutarizado.
Cr 17 # 18-69
Teléfono(s) : (57) (2) 8881475
Fax : (57) (2) 6833223
Secciones
VOLKSWAGEN R.W.
TALLER LUCHO VOLKSWAGEN0
Cr11 19-77
Teléfono(s) : (57) (2) 6804679
Secciones
¡Buena Suerte a usted!
thummmper
thummmper is offline
PostPosted: Sun Apr 18, 2010 12:38 am    Post subject: Reply with quote
amazing
Pascal
Pascal is offline
PostPosted: Sun Apr 18, 2010 5:57 am    Post subject: Re: Sambanista help needed in Colombia Reply with quote
Farf wrote:
Additional info:
[/b]
My comment on your points:
1. So your heads should be fine
2.seems normal to me. If you have a functional catalitic converter, then it should burn up the oil you are loosing.
3. check all your hose junctions for a leak, and check your water pump also for leaks. I don't think this is related to you other issues.
4. which is why I'm guessing an external leak. Make sure to look at your front and rear heater valves for leaks.
5. I'm guessing a worn out or broken ring. Did they/you look at those when you replaced your heads?
6. no comment on that point.
7. With 200K, your 2.1 is tired. Rods are know to go on the 2.1 (some say at around 165K), and one sign of then starting to go is low oil pressure. If your planning on a top end rebuild, you might consider rebuilt rods and bearings. Some people have changed them without splitting the case. Ideally you would check the crankshaft for where the rods bolt on for wear and taper, but that's likely not an option for you in your situation.
You could also try a new oil piston and spring in the oil pressure release valve. Or you can try putting a washer under the spring to boost the pressure a bit. But...you engine is telling you it's tired.
8. Sound like your basically running on 3 cylinders
9. if you have 200K on original rings, rods/bearings, your engine is just telling you it's time to get some fresh parts and likely needs a complete rebuild.
You should be able to do a top end rebuild to address your #2 cylinder, and find and patch that coolant leak. Addressing the low oil pressure is a whole other issue IMO.
Best of luck!
'84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby
Farf
Farf is offline
PostPosted: Sun Apr 18, 2010 10:16 am    Post subject: Reply with quote
Was able to drive to Villa de Leyva last night. Nice town to be stuck in.
I was able to rig up a leak down tester using the rear spare tire pumped up to 70 psi as my constant pressure source, the hacked off end of a plastic clutch alignment tool, a red hot paper clip about .04¨ diameter to poke holes in plastic clutch tool piece for the orifice and gauge tap. Used an athletic ball inflation needle and the tubing from a can of fix a flat to back feed into compressor for my pressure readings, a whittled down wine cork and a tapered cap from a tube of sealant. I was lucky to have carried some spare vacuum and fuel line tubing.
Test Results:
#2 cylinder @ TDC and valve adjusters completely backed off.
70 psi in, 15 psi @ cylinder head. Not good. Repeat same results.
No bubbles in coolant tank. Lots of air out of crankcase breather hose. About 78% loss.
As a reference and verification of the apparatus I tested # 1 cyiinder.
Test Results:
70`psi in: piston rapidly went into a downstroke. Reset piston @ TDC locked motor in position and re-tested. Gauge approached 56 psi before my contraption blew apart. I am assuming # 1 is ok.
So, it looks like blown rings in # 2, if I'm not correct please let me know.
Thanks again, Mike
Pascal
Pascal is offline
PostPosted: Sun Apr 18, 2010 6:00 pm    Post subject: Reply with quote
It sounds like you found the cause of your # 2 combustion chamber problem.
'91 EA Cabby
dobryan Premium Member
dobryan is offline
PostPosted: Sun Apr 18, 2010 6:27 pm    Post subject: Reply with quote
Thanks again, Mike
Daaang. McGuyver has got NOTHING on you! Awesome job. Applause Applause Applause
Dave O
The Western Syncro build
tclark
tclark is offline
PostPosted: Sun Apr 18, 2010 8:58 pm    Post subject: Reply with quote
would it not be easier for brother to bring down a re-man short block rather take a chance on a mistake on rebuilding internals on the road ..
and those number are kinda sad..
r & r a motor is a day for regular vw mech maybe in you env might be 2 days but seems like it be fool proof & you got a nice broken in heads from your previous tear down ... and then you have no worries the rest of the trip
esp with the 2.1 rod know to have died at your mileage
seems like a no brainer to me
89 Westy with TDI AHU 1.9 manual lots of mods
85 GL 1.9, auto (for sold)
nomados
nomados is offline
PostPosted: Mon Apr 19, 2010 1:17 am    Post subject: Reply with quote
I don't see why you couldn't do a rebuild where you are. Core charge is something to think about too. Parts are easier for Bro to bring down/ bring back compared to a longblock/ core.
There's a lot of excellent rebuild threads here on the forum, if that's an option.
'86 Westy auto
'84 Westy 4 spd previous
'75 wing, watercooled boxer 4 motorcycle.
morymob
morymob is offline
PostPosted: Mon Apr 19, 2010 4:37 am    Post subject: Reply with quote
Lots o grey areas here , unknown eng internals at 200K, Trustworthy wrench ?.who will be doing work? Me, i would try to see if brother can fit a short block at least in his carry-on, minus heads and maybe an added new water pump, no flywheel.
Californio
PostPosted: Mon Apr 19, 2010 10:00 am    Post subject: Reply with quote
When you figure in the cost of an RT ticket from US to Bogota at the last minute, my guess is it would be cheaper to take it to a shop. You're really going to pull that engine in the central plaza of Villa de Leyva? Yes it's a nice place but...presuming your Spanish is fluent, I'd start making calls...
vwlovr
vwlovr is offline
PostPosted: Mon Apr 19, 2010 10:16 am    Post subject: Reply with quote
Thanks again, Mike
no shit, that is hand down the best description of a jerry-rigged tool i have ever heard in my entire life. wine cork for the win!
Farf
Farf is offline
PostPosted: Mon Apr 19, 2010 10:38 am    Post subject: Reply with quote
Thanks for all of the suggestions, I too am concerned about the bottom end. Balancing risk/cost is quite difficult with the unknowns that I have. The local mechanics are all very nice and helpful but large hammers and Sawz-alls are quite prominant at their shops. So with that in mind, I'm thinking that I will purchase a complete rebuild kit with enough extras to patch up #2 piston/cylinder drive South and enjoy, get to Bogata find a decent shop and I have them, with the parts I will provide take care of the re-build. Other than the motor disintegrating on the way down and because this is the plan I've come up with, I sense something is amiss, anyone want to take a stab at poking holes in this, and me if you want (ouch, wide open), a little humor helps in situations like this.
Thanks, Mike
Californio
PostPosted: Mon Apr 19, 2010 11:58 am    Post subject: Reply with quote
One question, you drove this from Colorado to Bogota? That's deserving of some kind of award right there.
My experience with mechanics in Latin America (not a lot) has been that they do improvise, but also that because VW's are so common there, you're likely to find someone who knows boxers inside and out. Compared with, even, mechanics in the midwestern states here.
Farf
Farf is offline
PostPosted: Mon Apr 19, 2010 1:51 pm    Post subject: Reply with quote
Californio, yes we left Colorado on Nov. 1 and drove down through Mex. and Central America. Shipped van from Colon, Panama to Cartagena, Colombia. We hope to make it to the southern tip of South America and return in one piece. We still have about 1.5 years to get this done. In reference to my last post, my brother poked big holes in my plan regarding rebuilding the bottom end, so I'm exploring having a rebuilt long block sent down. I hate to spend the money and not get the motor I really want but I would really hate to end up in a much worse situation. As some Canadian travellers we met said, 'things can deteriorate rapidly'.
Thanks, Mike
Rhinoculips
Rhinoculips is offline
PostPosted: Mon Apr 19, 2010 8:01 pm    Post subject: Reply with quote
Mike,
Do you have a blog or website on your travels? I always love reading about VW travels. A few years ago, I rode my motorcycle from Colorado to Tierra del Fuego. Many thought I was crazy for riding through Colombia, the so called kid-nap capital of the world. Colombia was one of my favorite countries. Very friendly folk.
You may want to check into the import restrictions. Importing car parts can be very difficult and/or costly. Used parts can be even more of a pain.
Fair winds and following seas,
Lobo Rojo
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
ranchero
ranchero is offline
PostPosted: Tue Apr 20, 2010 8:33 pm    Post subject: Reply with quote
Mikeguyver,
Sorry to hear about your misfortunes. If there there is any way I can assist from Salida I would be happy to. Too bad I sold my longblock awhile back.
Steve
PS. Tell Trish that the water coming into the pool is at 104!
'90 Westy Syncro EJ25 (money pit #1)
'96 FZJ80 (cheap by comparison^^)
'13 Golf R. Daily driver.
