Need some measurements...
nize
nize is offline
PostPosted: Fri Oct 23, 2009 6:28 am    Post subject: Need some measurements... Reply with quote
Does anyone out here know the distance from center to center between the rear torsion tube and the front torsion tubes? I found a 59 split bus mechanics book that states that it is 2148.5mm - 2149.5mm with tolerances but the question is if the barndoor has the same measurements?
Also measured from the center of the rear torsion tube, how much higher does the lower front torsion tube sit?
Hope that you can follow me. I am about to build a chassis jig for my 54 but I have nothing to measure on at the moment.
----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
barnduude
barnduude is offline
PostPosted: Fri Oct 23, 2009 11:55 am    Post subject: Reply with quote
alo,
i have taken a look and it was lenght center to center 2140mm
and in hight front is 55mm lower.
grtz to all.
www.everyoneweb.com/luftwaffenracing
'54 BD kombi.
'68 APAL samtrack.
hell is empty, all devils are here.
djfordmanjack
djfordmanjack is offline
PostPosted: Fri Oct 23, 2009 2:47 pm    Post subject: Reply with quote
I took this from the 1956 book 'Querschnitt durch die Autotechnik 6, Volkswagen 1950-56'. The book is all 30hp up to 54 bug/bus except for a few additional tables so this should be Barndoor, especially when concerning the offset steering geometry.
A is backside of frontaxle flange ( where the bolts go through)
B is middle of rear torsion bars
C is the gauge made for measuring these dimensions
54 Oval project
62 Dickholmer, Seeblau L360
nize
nize is offline
PostPosted: Sat Oct 24, 2009 6:59 am    Post subject: Reply with quote
Thanks alot... then the drawing I made should be ok. But what is the mesurement on the left most side? Looks like as if something is of centre?
1954 Kombi
nize
nize is offline
PostPosted: Sat Oct 24, 2009 7:02 am    Post subject: Reply with quote
By the way... its definitely barndoor measurements in your picture... check out the steering wheel...
1954 Kombi
barnduude
PostPosted: Sat Oct 24, 2009 11:02 am    Post subject: Reply with quote
alo,
and off centre steering pin.
grtz to all.
'54 BD kombi.
'68 APAL samtrack.
djfordmanjack
PostPosted: Sat Oct 24, 2009 11:07 am    Post subject: Reply with quote
I think that is only the frame beam the shifter and parking brake is located on. It should be offset the 50,...mm from the centerline of the vehicle.
54 Oval project
nize
nize is offline
PostPosted: Mon Jan 11, 2010 6:35 am    Post subject: Reply with quote
In order to finish my chassis jig I need to do a support for the front beam.
However to do this I must know the CC-distance between the lower front axle tube and the rear axle tube in the vertical plane. I.e. how much lower does the lower front axle tube sit than the rear torsion tube?
Is there anyone out here who knows this distance? Judging from the picture from "djfordmanjack" above it should be something like 110 mm - 30mm (thickness of the 2148.5 mm rod) - 30mm (half the thickness of the front torsion tube) = 50 mm.
Can someone confirm this?
1954 Kombi
nize
nize is offline
PostPosted: Fri Jan 15, 2010 5:00 am    Post subject: Reply with quote
Just posting this if someone else should need it... I have got 20 mm from two different independent sources. So the lower front axle tube sits 20mm lower than the rear axle measured center - center.
1954 Kombi
sirairy
sirairy is offline
PostPosted: Thu May 06, 2010 12:39 am    Post subject: Reply with quote
Is here somewhere dimension pictures of barndoor? I really appreciate if I will get the chassis dimensions: height in front/cargo/rear areas and distances
RockStock
RockStock is offline
PostPosted: Thu May 06, 2010 5:00 am    Post subject: Reply with quote
-StockRocks-
djfordmanjack
PostPosted: Thu May 06, 2010 6:08 am    Post subject: Reply with quote
wow ! Is that a card or a booklet ?
If so, are the inner drawings and pages also available ?
54 Oval project
RockStock
PostPosted: Thu May 06, 2010 6:32 am    Post subject: Reply with quote
Top interiors brochure
http://www.thesamba.com/vw/archives/lit/transporter_interiors_german.php
-StockRocks-
PostPosted: Thu May 06, 2010 9:34 am    Post subject: Reply with quote
I have larger versions of those scans too, if needed.
djfordmanjack
PostPosted: Fri May 07, 2010 12:28 am    Post subject: Reply with quote
That is one TERRIFIC brochure, I hadn't seen that before in the archives.
The resolution is very good, thanx a lot !
54 Oval project
