nize Samba Member
Joined: June 21, 2004 Posts: 537 Location: Sweden - Cheesy town
Posted: Fri Oct 23, 2009 6:28 am Post subject: Need some measurements... |
Does anyone out here know the distance from center to center between the rear torsion tube and the front torsion tubes? I found a 59 split bus mechanics book that states that it is 2148.5mm - 2149.5mm with tolerances but the question is if the barndoor has the same measurements?
Also measured from the center of the rear torsion tube, how much higher does the lower front torsion tube sit?
Hope that you can follow me. I am about to build a chassis jig for my 54 but I have nothing to measure on at the moment. _________________ ----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
barnduude Samba Member
Posted: Fri Oct 23, 2009 11:55 am Post subject: |
alo,
i have taken a look and it was lenght center to center 2140mm
and in hight front is 55mm lower.
grtz to all. _________________ www.everyoneweb.com/luftwaffenracing
'54 BD kombi.
'68 APAL samtrack.
hell is empty, all devils are here. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2368 Location: Graz, Austria, Europe
Posted: Fri Oct 23, 2009 2:47 pm Post subject: |
I took this from the 1956 book 'Querschnitt durch die Autotechnik 6, Volkswagen 1950-56'. The book is all 30hp up to 54 bug/bus except for a few additional tables so this should be Barndoor, especially when concerning the offset steering geometry.
A is backside of frontaxle flange ( where the bolts go through)
B is middle of rear torsion bars
C is the gauge made for measuring these dimensions
_________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
nize Samba Member
Posted: Sat Oct 24, 2009 6:59 am Post subject: |
Thanks alot... then the drawing I made should be ok. But what is the mesurement on the left most side? Looks like as if something is of centre? _________________ ----------(VW)----------
1954 Kombi
nize Samba Member
Posted: Sat Oct 24, 2009 7:02 am Post subject: |
djfordmanjack wrote: |
By the way... its definitely barndoor measurements in your picture... check out the steering wheel... _________________ ----------(VW)----------
1954 Kombi
Posted: Sat Oct 24, 2009 11:02 am Post subject: |
alo,
and off centre steering pin.
'54 BD kombi.
'68 APAL samtrack.
nize Samba Member
Posted: Mon Jan 11, 2010 6:35 am Post subject: |
In order to finish my chassis jig I need to do a support for the front beam.
However to do this I must know the CC-distance between the lower front axle tube and the rear axle tube in the vertical plane. I.e. how much lower does the lower front axle tube sit than the rear torsion tube?
Is there anyone out here who knows this distance? Judging from the picture from "djfordmanjack" above it should be something like 110 mm - 30mm (thickness of the 2148.5 mm rod) - 30mm (half the thickness of the front torsion tube) = 50 mm.
Can someone confirm this? _________________ ----------(VW)----------
1954 Kombi
nize Samba Member
Posted: Fri Jan 15, 2010 5:00 am Post subject: |
nize wrote: |
Can someone confirm this? |
Just posting this if someone else should need it... I have got 20 mm from two different independent sources. So the lower front axle tube sits 20mm lower than the rear axle measured center - center. _________________ ----------(VW)----------
1954 Kombi
sirairy Samba Member
Joined: September 07, 2006 Posts: 25 Location: Portland OR
Posted: Thu May 06, 2010 12:39 am Post subject: |
Is here somewhere dimension pictures of barndoor? I really appreciate if I will get the chassis dimensions: height in front/cargo/rear areas and distances |
RockStock Samba Member
Joined: November 26, 2004 Posts: 4222 Location: England
Posted: Thu May 06, 2010 5:00 am Post subject: |
_________________ -StockRocks- |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71619 Location: Phoenix 602
