2-way windshield washer nozzles that fits - edited
Page: 1, 2, 3, 4, 5  Next
stevey88
stevey88 is offline
PostPosted: Sat May 08, 2010 12:09 pm    Post subject: 2-way windshield washer nozzles that fits - edited Reply with quote
I have tested the 2-way washer jets from a 76-85 Porsche 911 and they fit without mod. The jets of water can be adjusted to hit the middle of the windshield at the extreme position of the adjustment. You should really adjust it so they hit the top of the windshield at stationary and then the water jets will hit the middle of the wind shield when you are driving at speed.
Cost is $8.25 not cheap but worth it. I have tested only the ones from Pelican parts so nozzles from other vendors may be different. Part number is 914-628-203-11-M78
http://www.pelicanparts.com/cgi-bin/smart/more_inf...1976-85%29
Edit:
The Porsche nozzle stands 6mm above the body panel and the OE nozzle stands 18mm above. So the jets are shooting at the glass at a much lower angle than the OE jets. That make it difficult to adjust the jets as a little angle change will results a big movement of where the water land on the windshield. The van I put the Porsche jets on has the chrome plastic insert and it stick out above the rubber. The water jets just barely clear that molding. You need lots and lots of patience to adjust the jets but you only need to do it once.
Also, the Porsche jets has a smaller base than the OE jet, so it will not cover up the old markings made by the old jets. The ends that goes into the body is exactly the same as the OE jets.
Steve
87 Westfalia full camper 4 speed
j_dirge
j_dirge is offline
PostPosted: Sat May 08, 2010 6:30 pm    Post subject: Reply with quote
Oh NO!
Impulse buy!
Am now $23 poorer.
Hope they work... Laughing
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Rhinoculips
Rhinoculips is offline
PostPosted: Sat May 08, 2010 7:55 pm    Post subject: Reply with quote
How about some pics of them installed and in use? Thanks for the post. It's to late for me as I got the 3 jet washers from the UK. $$$$$, but really nice.
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
tripod808
tripod808 is offline
PostPosted: Sat May 08, 2010 9:55 pm    Post subject: Reply with quote
I was close to biting the bullet for the smart nozzles, I'm glad someone found a cheaper alternative.
Pictures please!
dobryan
dobryan is offline
PostPosted: Sun May 09, 2010 7:01 am    Post subject: Reply with quote
Thanks. Just ordered two! Very Happy
Dave O
The Western Syncro build
insyncro
Banned
insyncro is offline
PostPosted: Sun May 09, 2010 4:26 pm    Post subject: Reply with quote
Good lookin' out.
The whole Smart Car noozle deal seamed like a waste to me.
All that money for something that doesn't fit.
Thanks Porsche.
goffoz
goffoz is offline
PostPosted: Sun May 09, 2010 7:56 pm    Post subject: Reply with quote
just FYI the nozzles from a 1999 and earlier, mercury villagers work well.they stand 2" tall and have adjustable dual sqirters.
(2000 and later have smaller units)
The fit is different but an easy mod.
I snagged both nozzles, all the plumbing with check valves, for $7 from a P&P
insyncro
Banned
insyncro is offline
PostPosted: Mon May 10, 2010 5:22 am    Post subject: Reply with quote
pictures please.
Classicvibe
Classicvibe is offline
PostPosted: Mon May 10, 2010 8:09 am    Post subject: Reply with quote
Pictures people! Get out your cameras and snap some pics. "Fit" is a very relative term, as there are many interpretations on just what constitutes a good "fit." The are complicated little buggers...
On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter
kevinm
kevinm is offline
PostPosted: Mon May 10, 2010 6:51 pm    Post subject: Reply with quote
How does one remove the existing nozzles without scratching the paint? Do you just slip a thin piece of plastic under them to push in the tabs?
- Kevin
Rhinoculips
PostPosted: Mon May 10, 2010 9:22 pm    Post subject: Reply with quote
- Kevin
Clamp onto them with a pair of Vise-grips and twist a quarter of a turn. This will destroy the tabs on the nozzles, so make sure you have a replacement before removing the old ones.
Click to view image
syncrodoka
syncrodoka is online now
PostPosted: Mon May 10, 2010 9:29 pm    Post subject: Reply with quote
Have you driven the van at freeway speeds and verified that it still works? This is the reason why the cheap 2nd gen SMART car nozzles aren't a good solution.
j_dirge
j_dirge is offline
PostPosted: Tue Sep 28, 2010 9:46 am    Post subject: Reply with quote
Bump.
Yes.
I installed one on the driver's side. If anything these squirters spray too high and they have to be adjusted down almost to the limit.
Works nicely, though. 6 months or so now.
foodeater
foodeater is offline
PostPosted: Tue Sep 28, 2010 1:46 pm    Post subject: Reply with quote
but still no pictures.
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
j_dirge
j_dirge is offline
PostPosted: Tue Sep 28, 2010 2:19 pm    Post subject: Reply with quote
Sorry..
The van is kind dirty.
Classicvibe
PostPosted: Tue Sep 28, 2010 2:24 pm    Post subject: Reply with quote
So, it looks like a narrow window to clear the molding and still hit the windshield? Easy adjustment? The $60 ones sold by another Sambanista rise like 3/4" to clear that molding hurdle. Comments? Also, how do we find that squirter? Thanks for the update!
foodeater
Thanks.
jerrydog411
jerrydog411 is offline
PostPosted: Tue Sep 28, 2010 2:54 pm    Post subject: Reply with quote
Thanks a bunch ... I ordered a couple of pairs for my & my buddy's van.
Cheers,
John
j_dirge
j_dirge is offline
PostPosted: Tue Sep 28, 2010 4:33 pm    Post subject: Reply with quote
Exactly.
Yeah.. it takes a couple trial and error adjustments.. but you'll find the zone.
The particular part and the supplier is linked up in the first post. (Thanks Steve88!)
stevey88
stevey88 is offline
PostPosted: Tue Sep 28, 2010 6:06 pm    Post subject: Reply with quote
j dirge,
With only one dual jet installed, how can you stand it with one side of the windshield can be washed cleaner than the other side ?
BTW, what is ' Outer Sunset " ? I go to 30th X Ortega all the time.
Steve
Page 1 of 5
