Electric Buggy Conversion
Page: 1, 2, 3  Next
chris_parks
chris_parks is offline
PostPosted: Wed Jun 30, 2010 2:09 pm    Post subject: Electric Buggy Conversion Reply with quote
So I have read about a few people who have converted VW's for electric use, and even one notable fellow who did a buggy.
Link:http://bit.ly/bXgtlv
Since I have my Manx running reasonably well and am using it as a daily driver now, I have set my mind to phase two of my evil plan to reduce my dependence on foreign oil.
My goal is to take my El Lobo...
Photolink here:http://bit.ly/aleacJ
...and turn it into an Electric Vehicle that I can use as a daily driver
My early thinking is that it would
1) Be able to drive at freeway speeds (i.e. 65 MPH)
2) Have a range of 50-60 Miles
3) Need recharging on a weekly basis
I am just wondering if anyone here has ever tried EV conversion for their buggy, and what advice they would give.
As much as I love fixing my 1600 DP and cleaning out my idle jets in my duel webbers, I am just ready to go 21st century...
Your thoughts? Ideas? Snide comments or jokes? Mean spirited insults?
Idea
Here are some examples I found...
Just loving life. One buggy at a time.
JiI
JiI is offline
PostPosted: Wed Jun 30, 2010 2:32 pm    Post subject: Reply with quote
Unless you charge it from solar, windmill or water turbine, you're still using fossil fuels.
Jeff
Russ Wolfe
Russ Wolfe is offline
PostPosted: Wed Jun 30, 2010 3:20 pm    Post subject: Reply with quote
Here is the kits you need. Already to go onto a VW transmission.
http://www.ecosmotors.com/parts.html
Gary: OK. Ima poop.
73SpeedBuggy
73SpeedBuggy is offline
PostPosted: Wed Jun 30, 2010 3:40 pm    Post subject: Reply with quote
Jeff
This, gentlemen, is an outstanding example of what is known as 'thread-crapping'.
Dale M.
Dale M. is offline
PostPosted: Wed Jun 30, 2010 3:51 pm    Post subject: Reply with quote
Besides most kits are not economical to run... 50-60 miles round trip a day means you have to charge it every other day or so as kits go a range 100-150 mile is about all you can expect....
That aside there was a pretty cool buggy link a few years ago (now missing from web) about a electric buggy... IT has a pan extension on each side and had about 6, 12volt batteries down each side (under body lip between wheel wells)....
As it is the are many "green sites" the show buggies and all sorts of "other" vehicles converted to zapmobiles.... GOOGLE search turns up a ton of them....
here is some "starter" links...
http://energy.sourceguides.com/businesses/byP/ev/ecars/byN/byName.shtml
http://www.car-stuff.com/carlinks/future.htm
http://www.eaaev.org/
http://www.nedra.com/index.html
http://www.suckamps.com/
http://eaaev.org/eaachapters.html#CALIFORNIA
http://www.electroauto.com/gallery/vrabbit.shtml
http://www.megawattmotorworks.com/display.asp?dismode=article&artid=180
Dale
chris_parks
PostPosted: Wed Jun 30, 2010 4:07 pm    Post subject: Reply with quote
Jeff
I actually had thought of installing solar panels on my house but didn't want to make a thread about living "off the grid". Good point though.
I only drive a total of 8 miles/day currently, so 50-60 Miles is about a week's worth for me if I throw in lunches.
My plan is to keep the Jeep for the hauls that require long distance and not for work commute/grocery getting.
Thanks Dale for the link on EV stuff. They are a good starter.
I remember seeing the buggy with the side battery pods too.
So has anyone here actually done it?
Blue Bug Green Bug Orange Bug VW Logo Idea VW Logo Purple Bug Red Bug Yellow 181
BL3Manx
BL3Manx is offline
PostPosted: Wed Jun 30, 2010 4:39 pm    Post subject: Reply with quote
These guys near Santa Cruz have been doing conversions for a long time. They have a lot of information materiel and hold workshops.
I found a converted VW bus in a Pick n Pull a couple years ago and pulled the motor, adapter and controller. I'd like to do the same thing sometime.
One of the challenges of electric vehicle is getting the longest service life out of the batteries possible. The best type of EV lead acid batteries(6 volt golf cart) can last from 3 to 5 years. They're about $120 each. 12 volt batteries can go bad in 2 years. If you want to go highway speeds you'll need at least 96 volts. Bottom line is batteries are expensive(around $2,000) so you want them to last.
For maximum life, you should always try to maintain the batteries with a full charge when not in use. I don't think recharging the batteries once a week is a desirable/good/economic practice at all.
didget69
didget69 is offline
PostPosted: Wed Jun 30, 2010 4:55 pm    Post subject: Reply with quote
73SpeedBuggy wrote:
Jeff
Not an example of 'thread-crapping'... it's a reality check-point that needs to be addressed. And this should be an adult discussion...
It's called 'displaced emissions' if the source of power is generated via coal/nuke/natural gas/etc., and then 'downloaded' into a storage battery and run in the car.
I'd prefer a 'range-extender' type hybrid system that has a small gas turbine engine turning a generator to create the power the run hub motors in the wheels. If it's combustible, the turbine could potentially burn it for fuel -
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Russ Wolfe
PostPosted: Wed Jun 30, 2010 5:25 pm    Post subject: Reply with quote
Lithium-Ion are what are being used today, and they have more power to weight ratio, than a lead acid. And maintained properly, they will last longer than a lead acid.
Lithium Polymer is THE best for power and endurance, but they have their problems with overheating, if abused. They are just not perfected yet.
Gary: OK. Ima poop.
Lo Cash John
Lo Cash John is offline
PostPosted: Wed Jun 30, 2010 5:29 pm    Post subject: Reply with quote
Random thoughts from a guy who works in the DC Power/telecomm business:
1. For surface street driving an E-buggy would be great.
2. If you put the bats on the sides, you could make custom side pods to clean up the lines.
3. You could put controller under the front hood.
4. If you have the room, maybe a small gas generator mounted back near the electric motor? Sort of range extender if needed.
5. Bats should be held at "float voltage" as often as possible for max life. For lead-acid that's approx 2.20VDC per cell (6 cells per 12V battery).
6. If you need cables fabricated for this, let me know. Also I can hook you up with rectifier gear (battery chargers). We often junk old "48VDC" equipment and some of this stuff runs on 240VAC. I can show you how to charge a 96V string in halves with a 48V charger.
7. Yes it is a form of pollution displacement, however power plants in the US generally do NOT burn oil, therfore you are not directly giving money to foriegn countries.
Well, that's all I got for now.
www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
bedlab
bedlab is offline
PostPosted: Wed Jun 30, 2010 6:39 pm    Post subject: Reply with quote
Spend some time here: http://www.evalbum.com/
You will find plenty of ACVW conversions. Lead acid flooded golf cart batteries at 6 or 8 volts are still the easiest, least expensive and most bullet proof choice.
Don't pay any attention to anyone that does not drive an ev. Electric vehicles work within their well defined limits. I have over 5000 miles on a ghia conversion that I did 3 years ago with all used and scrounged parts (but for the battery pack). I have never been stranded away from home.
I can go fast or far but not fast and far. Freeway speeds are no problem. You will not save any money but you can have a ton of fun. Don't listen to the haters about just shifting the pollution around, evs are much cleaner.
EVO3
EVO3 is offline
PostPosted: Wed Jun 30, 2010 6:44 pm    Post subject: Reply with quote
Lithium-ions are the best answer we have for batteries at the moment. However, as a hobby shop manager we deal with those batteries on a daily basis and have seen them literally go off like a road flare during a charge cycle. Twice in our shop for no apparent reason. Luckily we have a fire extinguisher near by for those occasions. It would just make me mighty nervous knowing that the potential for a fire hazard is parked in my garage, capable of harming my family, pets and property.
Lithium battery failure..........
bedlab
bedlab is offline
PostPosted: Wed Jun 30, 2010 6:52 pm    Post subject: Reply with quote
Every internal combustion vehicle in the world has a tank full of highly explosive fuel in it at all times. Even when empty they can explode. That does stop me from parking two in my garage every night or driving my kids around all day. Again, unless you are really into this stuff stick with golf cart batteries and get you info from some one that has some experience.
Q-Dog
Q-Dog is offline
PostPosted: Wed Jun 30, 2010 7:03 pm    Post subject: Reply with quote
I've been thinking a lot about converting either my buggy or convertible to electric drive. How cool would it be to drive a nearly silent topless vehicle?
On top of the quiet driving, You never have to get gas, never need oil changes, and can charge it up at any electrical outlet. Who cares where the electricity comes from? I think the experience of driving a vehicle at highway speed, where all you hear are wind and tire noise, would be a great experience.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
bedlab
bedlab is offline
PostPosted: Wed Jun 30, 2010 7:25 pm    Post subject: Reply with quote
And your tranny and all the squeaks and rattles of a 42 year old VW. Very Happy
dan macmillan
dan macmillan is offline
PostPosted: Wed Jun 30, 2010 9:06 pm    Post subject: Reply with quote
The biggest difference being a gas powered car is less likely to self destruct when sitting in the garage turned off, unattended, than an EV running lithium ions on charge.
I use li-po's for radio controlled flying and they can and will self destruct when charging.
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
didget69
didget69 is offline
PostPosted: Wed Jun 30, 2010 9:07 pm    Post subject: Reply with quote
The 'battery car devotees' are a great bunch of folks; I sell cable & connectors to them... no problem. I'm a big proponent of alternative fuel / alternative powered vehicles -
However, it's a stretch to expect Joe & Sally Lunchbucket to pay attention to any requirements for increased maintenance on a hybrid or pure electric vehicle when they BARELY maintain their dino-fueled car... this is why I see the need in the market for a continuance in the production of a ICE/electric hybrid form of on-board power. My ideal would still be to use a diesel or gas turbine-type of engine (one that will burn multiple fuels) to run a generator & provide power for the hub motors.
Or run your air-cooled VW motor on alcohol... made from cellulose stock or plant matter -
bnc
didget69
didget69 is offline
PostPosted: Wed Jun 30, 2010 9:11 pm    Post subject: Reply with quote
And many battery technologies emit hydrogen or other harmful & explosive gases through their chemical process, which occurs when the battery is asked to provide power or hold a charge - so what's your point about explosive/combustible 'fuels' again? Smile
bnc
GTBRADLEY
GTBRADLEY is offline
PostPosted: Thu Jul 01, 2010 3:45 am    Post subject: Reply with quote
Hawkeye Buggy's built one a while back. There was a short thread about it over on the TexasManx Club site.
Thunderbug by Bugformance 1969
engineerorange
engineerorange is offline
PostPosted: Thu Jul 01, 2010 6:21 am    Post subject: Reply with quote
Diesel fuel is not explosive. You can use it to put out small fires.
Current VW Fleet
'69 beetle
Berrien Nostalgia on '68 swingaxle pan
'05 Passat TDI
'06 Jetta TDI
Page: 1, 2, 3  Next
