Seat rebuild; cleaning, rebuilding foam, adding seat heaters
jsSyncro
jsSyncro is offline
PostPosted: Fri Nov 30, 2007 11:36 am    Post subject: Seat rebuild; cleaning, rebuilding foam, adding seat heaters Reply with quote
The '87 I bought a few months back was in pretty decent
shape but the carpets and upholstery were kinda nasty and
I could feel the wires coming thru the disintegrating cushions.
I called Sewfine to order new bottom cushions but the nice
lady there said they were still working on perfecting them.
So I decided to just BS my way through redoing them.
I went out and got some 2" thick upholstery foam and spray adhesive
from the local upholstery shop. I also ordered some seat heat elements from
http://www.heatedseatkits.com/heatedseatkits/index.html
I got the H3 model.
Went to work disassembling the seats per Bentley.
Check out Sewfine's excellent photos on disassembling the arm rests:
http://www.sewfineproducts.com/vanarm.html
I cut the upholstery rings with wire cutters, these will be replaced with
zip ties later.
On the seat backs you gently pry back these nasty little clips to get the
covers off:
Untie the wires from the seat frame. I kept them in the seat covers
and wrapped the ends in duct tape in order to throw the whole thing in
the washing machine.
the head rests are held in place with cotter pins:
pull (don't pry) the plastic mounts out like so:
All the upholstery got sprayed with a ton of "Shout" and were scrubbed
down pretty good. I washed on COLD. I then let everything air dry.
the covers (left) looked awesome after washing. the seat on the right had
just been shampooed by a local car wash but was still pretty funky:
Here we go. The tools of ignorance:
I decided to use as much of the original cushion as possible since
it is molded to the steel seat pan. I shaved off the foam on top
that had started tp disintegrate.
Paper templates of main pieces:
I shaped the new foam using the sharpest serrated bread knife I had and
glued it in pieces to the old foam. There was a lot of dry fitting and trial and error to get a shape and firmness that worked. I then did some final
shaping with a belt sander (clamp down the seat real good so you don't launch it across the room).
I used duct tape to clamp the foam while the adhesive dried.
The seat back cushions were in pretty good shape so I didn't do much to them.
At this point I installed the seat heaters. I neglected to take pics of this but
the instructions that came with mine were very clear. They are self adhesive so they just stick right to the cushion. I made holes through the
seat cushion to run the wires.
As mentioned earlier, I used zip ties to replace the upholstery rings.
here is a finished seat:
old on left, new on right:
Back in the van, I was installing sound damping and carpet so the seat wiring was easy.
I also put in an aux battery at this point and wired the seats up to it.
I believe the heaters draw a lot of amps and I didn't want them draining
the main battery.
I drilled a 1.5 inch hole in the swivel plates for the heater wiring:
I decided to mount them in the lower center console:
I'm really happy with the way the upholstery and heaters worked out.
It's getting cold here in Colorado and the van is much more pleasant
to drive with the heated seats.
regards,
john
87 Syncro Westy Hoth Patrol Unit
rockfish
rockfish is offline
PostPosted: Fri Nov 30, 2007 11:51 am    Post subject: Reply with quote
Wow. Fantastic job.
Christopher Schimke
PostPosted: Fri Nov 30, 2007 12:11 pm    Post subject: Reply with quote
Cool! One tip for future do-it-yourselfers, an electric turkey carving knive cuts foam like butter.
FNGRUVN
FNGRUVN is offline
PostPosted: Sat Dec 01, 2007 10:25 am    Post subject: Reply with quote
Where were you when I was doing this to mine. I could have used a play-by-play. I also installed seat heaters when I had mine apart and had Sewfine make some really nice seat covers. I like the tools you used too, however I prefer using a New Belgium Fat Tire or 1554 for those jobs. I'm up in Fort Collins so I might see you around.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Wed Mar 04, 2009 3:48 pm    Post subject: Reply with quote
Just found this. Nice photos JsSyncro!
JsSyncro:
how are they holding up and how do they feel?
Thanks!
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
JeffRobenolt
JeffRobenolt is offline
PostPosted: Wed Mar 04, 2009 4:16 pm    Post subject: Reply with quote
Not sure if zip ties is a good idea instead of the hog rings?
For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com
westylife
westylife is offline
PostPosted: Wed Mar 04, 2009 6:54 pm    Post subject: Reply with quote
This is awesome! I never would have thought to put in seat heaters Shocked
I second that on the Fat Tire! I cant get that up here in Alaska.
1983.5 Westfalia Bostig RG1
rockfish
rockfish is offline
PostPosted: Wed Mar 04, 2009 8:32 pm    Post subject: Reply with quote
Depending upon your budget: Instead of making your own seat cushions, you can purchase replacement seat & back cushions from Sewfine. Same goes for the bench seat, cargo/engine pad and the bunk bed.
89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden
Syncroincity
Syncroincity is offline
PostPosted: Wed Aug 18, 2010 8:11 pm    Post subject: Reply with quote
Nah, zip-ties are FTW. Not only are they easy to work with, they allow you to keep the upholstery loose while you've got your hands in there routing the other ties, then snug everything down progressively. I've done two Subaru seat sets with zip ties, after 6 years the oldest is in perfect shape. Hog-rings will leave you bloody and cursing your life.
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
jmranger
jmranger is offline
PostPosted: Fri Jan 18, 2013 11:25 am    Post subject: Re: Seat rebuild; cleaning, rebuilding foam, adding seat hea Reply with quote
Old thread revival warning...
Since this one is in the FAQ, I believe a little correction is warranted.
When removing the headrest mounts, just pulling them...
... seems unlikely to succeed, given the adversary:
I used a variant of the strategy proposed by Sewfine:
1) pre-compress from the top using a (reusable) zip-tie, so the tips are all close enough for step 2
2) compress even more and push out at the same time using the square end of a 1/4" socket
Done! And thanks jsSyncro for the tutorial.
JMR
vw7266
vw7266 is offline
PostPosted: Fri Jan 18, 2013 11:37 am    Post subject: Reply with quote
I just did this...I popped mine out just like the original poster did...and I do love my seat heaters
Remember there more than one way to skin a cat!
westyman71
westyman71 is offline
PostPosted: Fri Jan 18, 2013 9:10 pm    Post subject: Reply with quote
Brad??????
Seat heaters??????
KDI_CUSTOMS
KDI_CUSTOMS is offline
PostPosted: Thu May 23, 2013 6:27 pm    Post subject: Reply with quote
Looks good. Just some simple tips for you guys/girls.
Electric carving knife cuts foam.
Use a good contact cement for gluing things together.
Angle air grinder w a red sand disc will shape foam nicely.
Zipties can be used in place of hogrings.
You can put a small metal rod on backside of foam n tie to tiedown rod on front of foam if its broken loose from inside.
Put headliner over shaped foam to help hide rough edges.
Hope this helps someone w their project. Maybe we should have diy upholstery section sponsored by me. Wink
KDI CUSTOMS AUTOMOTIVE UPHOLSTERY
www.kdicustoms.com
Full interior services and sales of rare imported material.
View user's profile Send private message Visit poster's website Facebook Classifieds Feedback
tam_shops
tam_shops is offline
PostPosted: Thu May 23, 2013 7:18 pm    Post subject: Re: Seat rebuild; cleaning, rebuilding foam, adding seat hea Reply with quote
THANK YOU for the detailed point by point pictures! I'm not sure I need to re-foam mine, think I might swap mine right to left like someone else suggested. WOW, though, I sure do need to wash them!
tam
john
1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885
SyncroChrick
SyncroChrick is offline
PostPosted: Mon Feb 03, 2014 6:24 pm    Post subject: Reply with quote
I am also doing this job right now. My bottom foam is totally shot, I wasn't expecting that. Those vehicles are starting to be pretty old by now...everything needs replacement.
So now I need to either find another used foam, pay $300 for 2 bottom foam at Sewfine, carve one myself...or get another set of seats.
decision, decision...
smurfpike
smurfpike is offline
PostPosted: Mon Feb 03, 2014 7:55 pm    Post subject: Reply with quote
Where did you get your carpet kit from? It looks very nice! How is the quality?
1965 Ottinger Tribute Overland Bus
IG @otter.the.overland.bus
FB Ottertheoverlandbus
IG Westyrestorations
FB WestyRestorations, parts and accessories
1987 Syncro "Big Red", Full restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=606596
1978 Westy Camper, Full ground up restoration, restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=593413
Steve M.
Steve M. is offline
PostPosted: Mon Feb 03, 2014 8:37 pm    Post subject: Reply with quote
Great job! I wish you had posted before you started because then I would have told you to use an Electric Carving knife to cut the foam! That is so much easier and more accurate since it cuts instead of tearing at the foam while trying to hold it with one hand and cut with the other.
It looks like it turned out well enough though.
kguarnotta
kguarnotta is offline
PostPosted: Sat Oct 17, 2020 5:02 am    Post subject: Re: Seat rebuild; cleaning, rebuilding foam, adding seat heaters Reply with quote
reviving an old thread - this looks great. thansk for posting.
How is it holding up long term? I am wondering if the seat heaters do long term damage to the foam? My seats are in ok shape - but I'd love them to look as clean as yours. I also saw a video of a guy reviving old foam with a steamer - it looked amazing, no idea if it actually lasts, or if it just puffs up for a short time, then compresses again.
I've thought about heated seats - they have some covers you just put over your seat - pretty cheap. But your job looks so much nicer.! thanks for sharing.
-Kevin
Lincoln, MA
2001 Eurovan
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper
designer
designer is offline
PostPosted: Tue Aug 13, 2024 11:19 am    Post subject: Re: Seat rebuild; cleaning, rebuilding foam, adding seat heaters Reply with quote
Helpful post… I just completed this with the gowesty foam replacements. I only did the bottoms, not the backs. Whole process prob took me 45 mins or so. The new foam feels remarkable. Sits about two inches taller than my beat down 30 year old seats.
Only trouble I had was when the side round ‘pin’ things popped out so I couldn’t get the seat to slide back on the rails to mount to the swivel mounts. I used some bar clamps and will power to reseat them. Also mounting the zip ties first like the picture helped save some time on seat #2.
Could be the easiest most rewarding mod to date.
__________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013.
