Jacks – a general guide line
Page: 1, 2, 3, 4, 5, 6  Next
Suboval
Suboval is offline
PostPosted: Wed Sep 22, 2010 10:16 am    Post subject: Jacks – a general guide line Reply with quote
All dates are approximate.
There are several changeover years.
Some years have multiple types.
Beetle:
1950-53 There are two versions of the Split jack.
For jack crank handles - see This Thread
Jack bag dimensions thread
Early version - VIGOT/BILSTEIN, 3 prong:
Later version - VIGOT/BILSTEIN, fat base:
The bottom is the same as what is on early bus jacks - left and middle picture:
Do not confuse it with a Porsche 356 jack – arm pointing downward.
1953-55 Bilstein and Vigot on the base. No cupped end for rod.
1956-57 Bilstein only on the base. No cupped end for rod.
1957-65 Notice cupped end for rod. Two types.
Standard:
Dished:
1965-69 Two types.
Missing rubber piece.
1969-72 Two types.
1972-79 Base changed to the later style.
Bus:
55-57 Vigot
The head should be black also.
58-61 Bilstein
62-63 Bilstein. Base changed to the later style.
64-early Bay Bilstein, later design with square head
64-67 Split Bus on top, Early Bay window Bus on bottom
Bay Window jacks, late early Bay Window on top, earlier early Bay Window on bottom:
55 -57, 58-61, 62-63
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
john7
john7 is offline
PostPosted: Wed Sep 22, 2010 10:37 am    Post subject: Reply with quote
what about this jack that vw switched to in 1972 for bugs.
they even added a special bracket next to the battery to hold it that year
Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders.
virtanen
virtanen is offline
PostPosted: Wed Sep 22, 2010 10:58 am    Post subject: Reply with quote
Beetle factory progressive refinements says: 19.3.1952, chassis 1-0336561, new jack type "Klettermaxe".
Should this mean the first generation ended then?
splitjunkie
splitjunkie is offline
PostPosted: Wed Sep 22, 2010 11:38 am    Post subject: Reply with quote
I would have to disagree with you on the style of jack you listed as '74-'79.
This page from a '72 manual clearly shows what you refer to as a '74-'79 jack. It has the stamped foot.
Chris
johnshenry
johnshenry is offline
Good stuff Kurt, thanks...
John Henry
'57 Deluxe
'56 Single Cab
Suboval
Suboval is offline
PostPosted: Wed Sep 22, 2010 12:34 pm    Post subject: Reply with quote
Thanks for the info! Smile
Suboval
Suboval is offline
PostPosted: Wed Sep 22, 2010 12:41 pm    Post subject: Reply with quote
It means a new type was introduced. There would still be old stock to run thru, etc.
19 mar. 52 Tool kit
Now: jack. type "Klettermaxe "
1 Sept. 58 Tool kit
Now: Casting with hole for
tommy bar on load bracket
operating rod of vehicle jack .
Suboval
Suboval is offline
PostPosted: Wed Sep 22, 2010 12:51 pm    Post subject: Reply with quote
NP. This should help those get a start.
If anyone else has anything to share, please speak up.
Jeff (Spanish Flea), anything you want to add?
Suboval
Suboval is offline
PostPosted: Wed Sep 22, 2010 12:55 pm    Post subject: Reply with quote
Thanks! Added it to original post too. Smile
Spanish Flea
Spanish Flea is offline
PostPosted: Wed Sep 22, 2010 1:25 pm    Post subject: Reply with quote
Guys one thing to point out though, those manuals use the same pix over and over. So some of those pictures span over the change of a jack, so those pictures are not to be relied upon.
I found this doing my own research on jacks.
Spanish Flea
Alte Schule
"Mr. Ford, i don't think what we are being offered here is worth a damn!" - Ernest Breech (On buying VW, March 1948)
splitjunkie
PostPosted: Wed Sep 22, 2010 1:34 pm    Post subject: Reply with quote
Spanish Flea
Very true. That is why I always look for the first time something new shows up in a manual. Even that does not pin point to when it changed. It is just the first time it shows up in a manual. It is very unreliable to use a manual to determine when some detail changed since they kept reusing the same photo over and over again.
Chris
Lind
Lind is offline
PostPosted: Thu Sep 30, 2010 6:56 am    Post subject: Reply with quote
I have six styles of bus jacks. I don't know the exact cutoffs.
Wanted:
tb03830
tb03830 is offline
PostPosted: Thu Sep 30, 2010 7:06 am    Post subject: Reply with quote
I have a Jack similar to the toob style recommended in the origonal post for my 64 vert. I found that the jack mount in the spare tire well (passengers side) is square and looks likes it fits the above pictured jack. What is it called and were do you find one? Is this wrong or am I just a simpleton and can not figure out the holder for the jack correctly.
I also show these as being bus jacks Question
"Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower.
Flyngunny
Flyngunny is offline
PostPosted: Sun Aug 28, 2011 6:49 am    Post subject: Re: Jacks – a general guide line Reply with quote
Standard:
What do you mean by "cupped end for rod"? I am having a hard time telling the difference. Could you please show me what you mean so that I get the correct one for my 60.
There is no problem which cannot be solved with the proper application of high explosives.
60 L451 India Red Beetle "Alex"
64 L519 Bahama Blue Beetle w/metal sunroof "Dorinda"
77 L63H Sage Green Campmobile "moe."
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Sun Aug 28, 2011 7:25 am    Post subject: Reply with quote
He means the little rounded bulge above the area that goes into the jack point.
reporsche
Banned
reporsche is offline
PostPosted: Wed Sep 14, 2011 2:12 pm    Post subject: Reply with quote
Can anyone tell what this came from, it has a round jack point but looks different from the other round ones.
splitjunkie
PostPosted: Wed Sep 14, 2011 3:28 pm    Post subject: Reply with quote
not without a picture.
Chris
IN2VWS
IN2VWS is offline
PostPosted: Thu Sep 15, 2011 4:38 am    Post subject: Reply with quote
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
Kapt. Q
Kapt. Q is offline
PostPosted: Thu Sep 15, 2011 12:08 pm    Post subject: Reply with quote
Does anyone have any idea about these two? I don't think they are KDF/VW but I'm not sure. I think one may even be pre-war.
Cheers!
noheb
noheb is offline
PostPosted: Sat Sep 17, 2011 4:15 pm    Post subject: split jaks Reply with quote
Here are some more early split jacks...
1940 ? - 1946 (notice round arm). The arm is placed quite higt because it's for a Kübelwagen.
1947 - mid 1949 ?
Mid 1949 - mid 1950 ?
Ken.
Page 1 of 6
