1960 Front transmission mount
Jamesyboy
Jamesyboy is offline
PostPosted: Wed Oct 13, 2010 10:47 am    Post subject: 1960 Front transmission mount Reply with quote
hi there im pretty new to the site as im struggling to find this mount for my beetle.. was wondering if anyone out there could help me out Sad they seem super hard to find and a pain in the arse!!! hope someone out there can help me.. i just want to drive me bug
Jamesyboy
PostPosted: Wed Oct 13, 2010 10:56 am    Post subject: Reply with quote
just a quick picture
hoping some of you guys out there know so i can get it off the axle stands!! Razz
Jamesyboy
PostPosted: Wed Oct 13, 2010 11:27 am    Post subject: Reply with quote
picture of the mount needed Sad
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Wed Oct 13, 2010 11:38 am    Post subject: Reply with quote
Not sure where you might get one in England. Did you consider trying to post an "Items Wanted - AUTO" over the vZi Classifieds? Someone did a few months ago and got an answer:
http://www.volkszone.com/VZi/showthread.php?t=647540&highlight=transmission+mount
The part number is 111301265C - I Googled it and came up with this match from the UK - I know nothing more than you see on the page though:
http://www.oempartfinder.co.uk/viewlisting.php?view=4024
If you want to deal with shipping from the USA, here's a match from TheSamba Classifieds:
http://www.thesamba.com/vw/classifieds/detail.php?id=1011319
-Andy
jays58s
jays58s is offline
PostPosted: Wed Oct 13, 2010 12:12 pm    Post subject: Reply with quote
That's a hard one to find, it's a 1 year only item and your 60' is full of 1 year items. Check here, check Gene Berg Enterprises, and any other vw parts place.
Jamesyboy
PostPosted: Thu Oct 14, 2010 9:07 am    Post subject: Reply with quote
thanks alot for the replys Smile i should hopefully be able to find one and drive me beetle Smile.
PostPosted: Thu Oct 14, 2010 11:17 am    Post subject: Reply with quote
Did you search the classifieds, I found these ads instantly
http://www.thesamba.com/vw/classifieds/detail.php?id=1025634
http://www.thesamba.com/vw/classifieds/detail.php?id=1005517
Jamesyboy
PostPosted: Thu Oct 14, 2010 12:03 pm    Post subject: Reply with quote
thanks mate i am hopefully buying a couple Smile will post pics of my bug asap Smile
Snort
Snort is offline
PostPosted: Thu Oct 14, 2010 12:16 pm    Post subject: Reply with quote
Front transaxle mounts are discussed a lot for the earlier Bugs because of people changing from one style transaxle to another. Just to make sure, are you going to be installing a split case transaxle in your 1960, or a full syncro tunnel case transaxle? That one-year only front mount only fits a one-year only split case transaxle with matching nose cone.
bill may
bill may is offline
PostPosted: Thu Oct 14, 2010 12:26 pm    Post subject: Reply with quote
if installing a tunnel case trans into a 1960 beetle you have to use a 1960 only front mount.
if installing a tunnel case trans into a 1959 and older then you use a 59-67 type2 bus front mount. also both 59 and older and 1960 use a bus nosecone and bus hockey stick. please keep this info in mind snort.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
Jamesyboy
PostPosted: Thu Oct 14, 2010 4:24 pm    Post subject: Reply with quote
ahh now this is interesting what you guys are saying.. i am putting a later gearbox in but i do have a split screen nose cone and stick fitted.. as the early box that was in it was broke. it looks ok from the old mount untill it broke
Snort
Snort is offline
PostPosted: Fri Oct 15, 2010 7:48 am    Post subject: Reply with quote
Here's a good thread for you to read on the 1960 transaxle swap.
http://www.thesamba.com/vw/forum/viewtopic.php?t=219118
Jamesyboy
PostPosted: Fri Oct 15, 2010 9:31 am    Post subject: Reply with quote
thanks snort mate that is a really helpful thread Smile im glad i registered on here now very helpful!!
myvolks1
myvolks1 is offline
PostPosted: Thu Nov 01, 2012 6:03 pm    Post subject: Re: 1960 Front transmission mount Reply with quote
Try this place for $30.00
http://www.vintagepartsinc.com/300_transaxle.html
I hope this helps
1959 L358 (Garnet Red)
Type-113 De Luxe Sedan
WANTED: DEET EICHEL (Modesto, CA), license plate frames and other Deet Eichel related items.
Wanted: Original VW
Lidpainter
Samba Anti-Hero
Lidpainter is offline
PostPosted: Thu Nov 01, 2012 6:43 pm    Post subject: Re: 1960 Front transmission mount Reply with quote
I hope this helps
I don't think he's still waiting after 2 years.
Thanks, time to bulk up on meat!
Kafer59
Kafer59 is offline
PostPosted: Wed Oct 23, 2013 12:32 am    Post subject: Reply with quote
just did this myself. used a tunnel trans, with bus nose cone and hockey stick. Welded the front mount off a newer bug. Thats the easy part. Now the tricky part is lining up the hockey puck up right. if you just you the stock holes it wont work.
