Jamesyboy Samba Member
Joined: September 04, 2010 Posts: 9 Location: Northampton , England
Posted: Wed Oct 13, 2010 10:47 am Post subject: 1960 Front transmission mount |
hi there im pretty new to the site as im struggling to find this mount for my beetle.. was wondering if anyone out there could help me out they seem super hard to find and a pain in the arse!!! hope someone out there can help me.. i just want to drive me bug |
Posted: Wed Oct 13, 2010 10:56 am Post subject: |
just a quick picture
hoping some of you guys out there know so i can get it off the axle stands!!  |
Posted: Wed Oct 13, 2010 11:27 am Post subject: |
picture of the mount needed  |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26548 Location: Douglas, WY
jays58s Samba Member
Joined: August 23, 2004 Posts: 2170 Location: Nor-Cal
Posted: Wed Oct 13, 2010 12:12 pm Post subject: |
| That's a hard one to find, it's a 1 year only item and your 60' is full of 1 year items. Check here, check Gene Berg Enterprises, and any other vw parts place. |
Posted: Thu Oct 14, 2010 9:07 am Post subject: |
thanks alot for the replys i should hopefully be able to find one and drive me beetle . |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71712 Location: Phoenix 602
Posted: Thu Oct 14, 2010 12:03 pm Post subject: |
thanks mate i am hopefully buying a couple will post pics of my bug asap  |
Snort Samba Member
Joined: April 02, 2005 Posts: 1975 Location: Seattle, WA
Posted: Thu Oct 14, 2010 12:16 pm Post subject: |
| Front transaxle mounts are discussed a lot for the earlier Bugs because of people changing from one style transaxle to another. Just to make sure, are you going to be installing a split case transaxle in your 1960, or a full syncro tunnel case transaxle? That one-year only front mount only fits a one-year only split case transaxle with matching nose cone. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Thu Oct 14, 2010 12:26 pm Post subject: |
| Snort wrote: |
if installing a tunnel case trans into a 1960 beetle you have to use a 1960 only front mount.
if installing a tunnel case trans into a 1959 and older then you use a 59-67 type2 bus front mount. also both 59 and older and 1960 use a bus nosecone and bus hockey stick. please keep this info in mind snort. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Thu Oct 14, 2010 4:24 pm Post subject: |
| ahh now this is interesting what you guys are saying.. i am putting a later gearbox in but i do have a split screen nose cone and stick fitted.. as the early box that was in it was broke. it looks ok from the old mount untill it broke |
Snort Samba Member
Posted: Fri Oct 15, 2010 9:31 am Post subject: |
thanks snort mate that is a really helpful thread im glad i registered on here now very helpful!! |
myvolks1 Samba Member
Joined: February 07, 2011 Posts: 183 Location: Modesto, CA
Posted: Thu Nov 01, 2012 6:03 pm Post subject: Re: 1960 Front transmission mount |
Try this place for $30.00
http://www.vintagepartsinc.com/300_transaxle.html
I hope this helps
| Jamesyboy wrote: |
_________________ 1959 L358 (Garnet Red)
Type-113 De Luxe Sedan
WANTED: DEET EICHEL (Modesto, CA), license plate frames and other Deet Eichel related items.
Wanted: Original VW |
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2051 Location: 41.77 | -83.56
Posted: Thu Nov 01, 2012 6:43 pm Post subject: Re: 1960 Front transmission mount |
| myvolks1 wrote: |
I hope this helps
| Jamesyboy wrote: |
I don't think he's still waiting after 2 years. |
Kafer59 Samba Member
Joined: June 25, 2008 Posts: 1 Location: Souther California
Posted: Wed Oct 23, 2013 12:32 am Post subject: |
| just did this myself. used a tunnel trans, with bus nose cone and hockey stick. Welded the front mount off a newer bug. Thats the easy part. Now the tricky part is lining up the hockey puck up right. if you just you the stock holes it wont work. |
