The enigma of the rear license plate bracket
chaosisme
chaosisme is offline
PostPosted: Mon Dec 27, 2010 2:03 am    Post subject: The enigma of the rear license plate bracket Reply with quote
I dont have a rear license plate bracket on my car, but what does the correct one look like for a '65 squareback? My plate sits right on the hatch, but looking underneath it and underneath my hatch panel, I only have two holes for the plate (where its actually bolted on) so it doesnt look like somebody hacked any extra holes in my car.
Im confused by the ones I see that would require me to drill extra holes in my hatch.
Is this the right one?
http://www.thesamba.com/vw/classifieds/detail.php?id=1006216
'65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's
vlad01
vlad01 is offline
PostPosted: Mon Dec 27, 2010 3:12 am    Post subject: Reply with quote
I don't know? My first car was a square and was that same as yours. Just screwed straight into the two holes with no brackets.
chaosisme
PostPosted: Mon Dec 27, 2010 3:17 am    Post subject: Reply with quote
Weird right? Of all the cars in our group, only two of us (out of 5) have rear brackets, and one of those rears is actually a front.
What happened to them?
'70 Westy
turbomicrowaves
turbomicrowaves is offline
PostPosted: Mon Dec 27, 2010 3:43 am    Post subject: Reply with quote
I think a lot of them disappeared when the plates were changed on the cars. For example, when an original CA car with black plates was taken out of state or re-registered years later, the plates may have been removed and the brackets lost. That's the only explanation I can come up with. It really doesn't make any sense, and I for one do not appreciate the extra holes drilled into my hatch. I am under the impression that there were at least two types of rear brackets and they differed in years, probably '67 and earlier and '68 and on because of the license plate light change.
'68 Sunroof Squareback
"There are no pieces"
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Mon Dec 27, 2010 4:02 am    Post subject: Reply with quote
two are for the Mounts holes
then the plate mounts to it
the ones that are to Skinny for regular plates
or Longer and skinnier
are for Different country plates
if you look into a thread about Australian bumpers i think
they have a pic of the bumper with a notch in it for the Square'ish license plate
the long ones are for european plates like Great Britain and the like.
there are a couple rear plate mounts
as well as light housings
not sure if the mounts changed specifically with the change of lights
there were 1s with 1 light and 1s with 2 lights
and the notch/fasty changed Where that housing was positioned
Not Sure about squares
One im used to seeing
and the middle one
Dont Remember which is wich
i think the adjustable one is for the front
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
turbomicrowaves
PostPosted: Mon Dec 27, 2010 12:53 pm    Post subject: Reply with quote
and the middle one
I have on of these on the front of my car.
And I have holes two holes that look to be for the top bracket on the rear hatch.
sharkskinman
Lateral Lunatic
PostPosted: Mon Dec 27, 2010 1:46 pm    Post subject: Reply with quote
i think the mounting holes for them are the same front and rear
the front (yours?)
has a mound for mounting
the adjustable one May be for the rear
but i always thought they were for the ront
but?
i dont have one on the front now
and the back one ifs the skinny one in the bottom pictures
it came from a classified ad so dont know what Type they are for
PS4 "NKOGNEATO"
Russ Wolfe
Russ Wolfe is offline
PostPosted: Mon Dec 27, 2010 1:56 pm    Post subject: Reply with quote
Rear license brackets were supplied by the DEALER!!.
Front ones on a T-3 came with the car.
So, it is hard say what your original bracket was.
BTW, the hole spacing on license plates in the USA, is standardized. No need to change the bracket when moving from state to state.
Gary: OK. Ima poop.
Bobnotch
Bobnotch is offline
PostPosted: Mon Dec 27, 2010 2:40 pm    Post subject: Reply with quote
The first one I think is a bug rear plate bracket.
The second one is used on both ends of a Notchback.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Aaron M265
Aaron M265 is offline
PostPosted: Mon Dec 27, 2010 7:52 pm    Post subject: Reply with quote
Agree With Russ- our plates were screwed directly to the tail gate on the squareback's here in Australia as well.
Only the front of the square had the bracket fitted (and both front and rear of the notchback).
It was sad that I drilled the tail gate of the black square to fit a number plate. One of those things I wish I had never done. I wonder why VW didn't supply a bracket for the rear?
Aaron
http://1500notchback.blogspot.com/
Need to contact me? Email is faster than a PM - [email protected]
For T3 Panel Van information:
http://www.thesamba.com/vw/forum/viewtopic.php?t=389465
Russ Wolfe
PostPosted: Mon Dec 27, 2010 10:12 pm    Post subject: Reply with quote
Because there were so many different license plates used around the world.
And most were used on the rear of the car. Many places do not use a front license.
Gary: OK. Ima poop.
turbomicrowaves
PostPosted: Tue Dec 28, 2010 12:35 am    Post subject: Reply with quote
I didn't mean that plates from out of state were different, I was only trying to provide an explanation as to how the brackets were lost. When a car was taken out of state and the plates were removed, the brackets may have been lost. I know that my hatch has two holes closely inset for a bracket, but I have no bracket. The previous owner drilled two extra holes because the bracket went missing at some point.
