earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Sat Jan 08, 2011 9:30 am Post subject: 36hp stream liner question |
OK
I have a question. If I built a stream liner for the 1 club with two 36hp motors, would it be legal for the class?
I finally finished my English wheel at work and want to build something unusual and I think this could be it.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Sat Jan 08, 2011 9:38 am Post subject: |
http://www.ultimateaircooled.com/landspeed.html
Everything in the rules refer to engine ... not engines. _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Sat Jan 08, 2011 10:52 am Post subject: Re: 36hp stream liner question |
earthquake wrote: |
OK
Casey |
Yes ! ! !
Take a look at http://www.ultimateaircooled.com/landspeed.html for "1" Club guidelines
Burly |
Posted: Sat Jan 08, 2011 1:09 pm Post subject: |
I need to clarify a little since ClearSurf referenced ' the engine' , not the engines.
The "1" Club is the wide open 36hp Challenge category. In esssence, attaching a second engine to the first engine is like adding a second supercharger or any other device to increase speed to the base 36hp and thats why it qualifies for "1" Club recognition(just get your car above 100 mph and take home the hat!).
That being said, a streamliner is NOT as street legal car and would have to be built to all the additional safety standards mandated by the USFRA and the SCTA/BNI, for the engine size streamliner class it would run in on the LONG course. Much more stringent rules and for good reason, as the speed potential is exponential to the aerodynamics a streamliner provides. A full fire suit(top to bottom) along with a full fire system would be needed as well.
So with extra power comes added weight. All must be factored in.
My VW streamliner concept circa the early seventies. With todays knowledge, the front wheels would no longer be in pontoons outside the body but tucked into the front nose section
Todays streamliners are slender and smooth. This is one of the Vesco families two record holding liners for comparison.
Personally, I hope you put that english wheel to good use and build the car. A 36hp based streamliner, how kool would that be.
Burly |
Posted: Sat Jan 08, 2011 5:37 pm Post subject: |
It would not be anything as fancy as that, I was thinking more like a old drop tank car but a little cleaner and flat bottomed. I would not be able to drive it because I'm too big [6'5" 340lbs] so I would have to find a driver.
I'm thinking about how I would make the connection between motors, one woodruff key on the crank snout would not be enough. Can you flip the ring gear and diff in a IRS trans like you can in a swing axle? or would I have to flip the trans up-side down and make a pump to lube the gears? I would like to stick with as many VW parts as possible.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Sat Jan 08, 2011 7:32 pm Post subject: |
Earthquake, if the IRS is an early one, with both sideplates removeable, then yes, you can flip the ring and pinion for mid-engine mounting. I don't have any ideas for the coupling but I have a friend who just mounted two alloy Buick V8's together for a rod and the coupler has proven to be the weak point. That said, go for a properly designed coupling method.
This is Dick Beiths 1963 lakester with a Pepco Supercharged 36hp motor.
This is a big block (late VW) lakester built by the late Ron Benham and driven by Burke LeSage in the late seventies.
Below is info on big fiberglass lakester bodies(in case you don't want to hammer out your own) and the supplier is located next door to you in Salinas, Utah, right alongside I-70 and just east of I-15.
Length-------12' 6"
Diameter----36"
Spacing at 1' increments:
0 / 1-18.5" / 2-25.5" / 3-31.0" / 4-34.5" / 5-35.5" / 6-35.5" / 7-34.0" / 8-30.5" / 9-25.0" / 10-18.0" / 11-12.5" / 12-7.5" / 12.5-0"
This is a larger belly tank body than used by Dick Beith back in 62 and 63 and two VW engines would be completely enclosed inside this body. Looking at photos of Dicks lakester, you will see the VW engines valve covers stick out and through the body. This body would be ideal for dual enclosed engines or a single of V-8 size.
The bodies sell for $2000.00 US each and can be "stacked" in multiples for reduced shipping costs.
Additional information on Waynes fiberglass lakester bodies can be found at:
www.p38-droptank.com or you can email Wayne at [email protected] .
http://www.rodnrace.com/index.cfm?fuseaction=category.display&category_id=99 2nd supplier
I hope this is helpful. In either case, you are close to the salt at Bonnenville. Come join us this year even if you don't have a car to race.
Burly |
Posted: Sat Jan 08, 2011 9:17 pm Post subject: |
Burly
For the coupler I was thinking about two rear U-joint yokes of a Ford 8.8 drive shaft, it has a four bolt pattern that will fit on one of the heavy steel pulleys and bolt it to a stock flywheel with the ring gear turned off, I don't think two 36hp motors will put too much stress on the U-joint, motors would not have more then about 50-60 horse power each at first. I would need to machine at least two more key ways in the crank snout and broach cut the pulley to match. Do you think one starter would start two motors? I have heard that a 6v starter with a 12v solenoid has a lot of torque.
Tell your friend with the Buick motors that there was two short blocks on craigslist here in Vegas pretty cheap recently.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Sat Jan 08, 2011 10:12 pm Post subject: |
It sounds like you have a lot more technical savvy than I so I would defer to your selection. Your idea appears to have a little 'wiggle' room which is a problem my friend does not have and is contending with.
Please keep up posted on how things are going. Your project is going to be very interesting.
May the Speed be with you..............
Burly |
Posted: Sun Jan 09, 2011 3:10 pm Post subject: |
Has any body ever done a flat bottom tear drop shape car before? I think it would be cool to build one with the drive wheels about two feet apart, totaly enclosed within the body, same with the fronts but further apart.
Are motorcycle tires legal on the salt on four wheel vehicles? Can you use Goodyear "Drag Fronts" on the salt? they go over 200MPH on the drag strip? I have never been involved with land speed type racing, I have been involved in off road, Auto X, and a little drag racing so this is all new to me. Sorry for all the questions.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Sun Jan 09, 2011 6:47 pm Post subject: |
Casey
I would caution on a flat bottom, teardrop shaped car(like a Bug). The result is a wing and a wing provides 'lift' which makes the car fly. Not good! Square streamliners with the wheels tucked inside as you describe are how most liners are built today and have proven very aero efficient.
Front wheels can be covered in liners ! This I believe would qualify as a lakester since both front and rear wheels are exposed.
Also, Good Year front runners are common on both front AND rear on many Bonneville racers including 36hp Challenge bugs. Avoid motorcycle tires on cars.
You seem serious in your interest so I would reccommend you go to:
www.saltflats.com
and follow the the USFRA and SCTA/BNI links to threads that can give you more specific answers to your questions. And please PM me with your email address and I will get you on the 36hp Challenge newsletter mailing list.
And I will continue trying to answer any questions I can.
Thanx for your interest..............
Burly |
Posted: Sun Jan 09, 2011 7:29 pm Post subject: |
Casey,here is an example of the 'home style' engineering you see at Bonneville. This is on a Hayabusa powered streamliner.
Home made wheels and front steering, off set for more slender air penetration.
Burly |
Dave Samba Elder
Joined: July 11, 2002 Posts: 2717 Location: The Forest Moon of Endor, in the Redwoods
Posted: Sun Jan 09, 2011 7:58 pm Post subject: |
I remember that blue streamliner well, reminded me of a Bugatti with that color and wheels, like a Type 35B on steroids.. I think it was called "Team Smoke It" or something like that...
There was also a severely choopped Ghia, lite blue and orange, that made runs at Bonneville way back when... and the old Green Ghia of Larry Monreal, of Larry's Old Volks Home... I think that one might have ended up with a rabbit engine in it, IIRC _________________ 2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter" |
Posted: Sun Jan 09, 2011 8:08 pm Post subject: |
Correct on all accounts. The Team Smoke It lakester and the chopped blue/orange Ghia were from the same folks, the Benham family.
Burly |
Posted: Sun Jan 09, 2011 10:55 pm Post subject: |
That square body design might be the place to start for a first time build, the body would sure be easier to make. Do S-Liners have any suspension or are they ridged mount? do you need a chute for cars under a certain speed? I guess I should get a rule book.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Sun Jan 09, 2011 11:05 pm Post subject: |
Most liners have some sort of suspension, a few do not but thats a rough ride and jiggles the eyeballs.
If the class you are building for has a record of 175 mph or higher you will need to have at least one chute(yes, get a rulebook), even if your car never goes that fast.
The SCTA will help you build the car correctly by providing you with a single experienced inspector/builder to call regarding any questions that come up. They are extremely helpful because they want you to be safe and have success.
Tootaloo
Burly |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14219 Location: Southampton U.K.
TomSimon Samba Member
Posted: Mon Jan 10, 2011 1:53 pm Post subject: |
earthquake wrote: |
It would not be anything as fancy as that, I was thinking more like a old drop tank car but a little cleaner and flat bottomed. |
Hi Casey, any Steamliner (wheels inside bodywork) or Lakester (wheels outside bodywork) is likely to be pretty fancy and give you something to practice your english wheel skills on.
Dick Beith built a very narrow flat bottom, flat topped, but tear drop shaped streamliner back in the 1990's (Big Block Chevy powered). The metal work on that car was incredible, pictures didn't do it justice!
check out the following links:
http://www.landracing.com/
several streamiliner build threads w/pics that I highly recommend: http://purplesagetradingpost.com/sumner/bvillecar/bonneville-Index.html |
spectre6000 Samba Member
Joined: April 19, 2009 Posts: 2014 Location: Broomfield, CO
Posted: Mon Jan 10, 2011 3:41 pm Post subject: |
Coupler idea:
"Plug" the engines into where the axels come out of the tranny (wouldn't be too hard to make something that would bolt up to an IRS CV axel joint). One would have to be driven by the flywheel side and one by the crank pulley side (so they're going in the same direction). Then you just have to plug what was the input shaft (now output) into the input shaft of a second tranny via another relatively simple coupler.
The VW engine is much wider than it is deep, so you're not adding a lot to the stock width. Additionally, you go from a 4 gear tranny to a bicycle-like 16 speed tranny. It would require a standard-style shifter setup and a mid-engine style shifter setup.
Does that make sense? Here's an ultra-crappy paint sketch.
_________________ Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me |
Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Mon Jan 10, 2011 5:15 pm Post subject: |
The World is not yet prepared for such awesomeness  _________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
Posted: Mon Jan 10, 2011 7:10 pm Post subject: |
I'm chatting about this with a friend and he suggests that having the flywheels like that would cause balance issues. It would also make the car (not a wide wheel base) lean to one side slightly (only enough to be an issue in the event of a turn). His suggestion is to reverse the cam have the engine fire backwards. It would also create a more natural balance (in the same way the four opposed cylinders naturally balance each other) and make for a relatively smooth running car as a bonus. It also brings the flywheels inboard to focus the center of gravity for a better handling car (given the narrow wheel base).
Additionally, this setup would require making a new weight setup for the reverse firing distributor, running both off the same (v distributor, or some fancy electronic ignition setup (I'm not even remotely familiar with whatever rule set we're dealing or not dealing with here so that may be out of bounds). _________________ Jason Hopper
-'84 M1009 CUCV
-'81 K10
