retro fit a decel valve
pgtips
pgtips is offline
PostPosted: Tue Jan 11, 2011 11:04 am    Post subject: retro fit a decel valve Reply with quote
Hi,
I've got a 75 fi auto, didn't come with decel valve as standard. I have a 'spare' fi setup from a later model bus (unknown what year) and I have a decel valve in this box of bits.
While I'm rebuilding I'm just wondering if it would be worth fitting the decel valve into the plumbing.
I am concerned it might have a knock on effect elsewhere, i.e is the FI set up to work better on my bus without it, is there anything else I should consider. Looking at posts on this they seem quite bullet proof/low failure instances so I'm not sweating on adding another thing that can go wrong later.
It appears to be a passive device so I am wondering, VW wouldn't have started to fit them unless they felt it was a good idea. Will it help if I do?
thanks
Kevin
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Jan 11, 2011 11:22 am    Post subject: Re: retro fit a decel valve Reply with quote
pgtips wrote:
Hi,
are you sure? all injected type 4 bus have a decel valve except it was deleted in the automatic vanagon aircooled.
SL
mattcuddy
mattcuddy is offline
PostPosted: Tue Jan 11, 2011 11:27 am    Post subject: Re: retro fit a decel valve Reply with quote
pgtips wrote:
Hi,I have a 'spare' fi setup from a later model bus (unknown what year) and I have a decel valve in this box of bits.
Don;t know what your spares are, but remember that the decel valve for an auto bus is different from a manual bus.
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Tue Jan 11, 2011 11:47 am    Post subject: Reply with quote
I too have an automatic (79), and this is a picture of my engine. You should have something like this, as opposed to the round diaphragm that we are all so familiar with. Circled in red; double click to enlarge:
"I will gladly pay you Tuesday for a hamburger today."
germansupplyscott
PostPosted: Tue Jan 11, 2011 12:00 pm    Post subject: Reply with quote
'75 auto uses an completely different decel valve that that one, it's electric.
SL
busdaddy
busdaddy is offline
PostPosted: Tue Jan 11, 2011 12:28 pm    Post subject: Reply with quote
Ahhhhh.... the Samba gallery, it's amazing!:
Слава Україні!
ChinaRider022474
ChinaRider022474 is offline
PostPosted: Tue Jan 11, 2011 1:01 pm    Post subject: Reply with quote
What's even more amazing are the prices those auto decel valves (on the left in those pics) command these days. They's NLA for looong time. I grabbed one to rathole. If you have a late auto bus, you need to do the same.
Scott
Chugs the Intrepid Traveler - ('78 CE II sunroof transporter/camper mutt)
"..you know my uncle, he starts a friendly game..."
pgtips
pgtips is offline
PostPosted: Tue Jan 11, 2011 4:41 pm    Post subject: Reply with quote
well thats made me double take.
I've got the one on the rhs.
Per BD pic I clearly do have a decel valve but bentley said I didn't (FI section, 10 I think, page 24).
So after reading it didn't I assumed it was the aux air regulator (per bentley also section 10 page 12)
So if that is decel then I do have one. It connects into the air filter S housing.
Something else I have learnt today.
Thank you to all.
busdaddy
busdaddy is offline
PostPosted: Tue Jan 11, 2011 4:47 pm    Post subject: Reply with quote
Congratulations, the AAR is the dotty thing that #50 connects to in the diagram BTW Wink
Слава Україні!
germansupplyscott
PostPosted: Tue Jan 11, 2011 5:38 pm    Post subject: Reply with quote
i told you you had one about a week ago in your other thread...
SL
pgtips
pgtips is offline
PostPosted: Wed Jan 12, 2011 7:42 am    Post subject: Reply with quote
Yes you did, I hold my hands up,
I relied on Bentley.
Embarassed
Bentley was wrong. Thanks for your patience though, I've learnt quite a lot this week about my bus.
raygreenwood
raygreenwood is offline
PostPosted: Wed Jan 12, 2011 3:16 pm    Post subject: Reply with quote
In almost all cases, you can use the manual (vacuum decel valve) in place of the electric one. Its just a little trickier to adjust and plumb. Ray
