74 Thing
Crash-n-Byrne
Crash-n-Byrne is offline
PostPosted: Mon Jan 24, 2011 6:33 pm    Post subject: 74 Thing Reply with quote
74 Thing is 1 inch lower on front left than front right. What's up? Crying or Very sad
Semper_Dad
Semper_Dad is offline
PostPosted: Mon Jan 24, 2011 6:37 pm    Post subject: Reply with quote
Driver with a penchant for hamburgers, french fries, and chocolate shakes Laughing
kubelmann
kubelmann is offline
PostPosted: Mon Jan 24, 2011 7:38 pm    Post subject: Reply with quote
broken ball joint. Blown shock, front torsion leaves loose or worn or sprung You might have a suspension issue. after 35 years the front end needs to be rebuilt...
uberautowerks
uberautowerks is offline
PostPosted: Mon Jan 24, 2011 11:20 pm    Post subject: Reply with quote
I would definitely "lean" towards a broken torsion leaf.
Pun intended Rolling Eyes
Keep in mind, Thing front torsion packs are different than the Beetle's. They are a bit stiffer.
So... Beetle spring packs will lower the front about an inch.
Sway-A-Way still has a 15% stiffer kit that is (in my opinion) just a bit stiffer than the Thing only units. Sway A Way part number 6002.
http://www.swayaway.com/VW_2.php#TORSIONLEAVES
--- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black)
