Smallcar bellhousing clutch options
Page: 1, 2, 3 ... 15, 16, 17  Next
Vango Conversions
Vango Conversions is offline
PostPosted: Tue Feb 01, 2011 12:03 am    Post subject: Smallcar bellhousing clutch options Reply with quote
All the previous Subaru swaps that I've done have used the KEP adapter plate and flywheel but I'm going to use the Smallcar bellhousing on my next subaru swap and I was wondering if anyone out there has had any experience with them, specifically the pressure plates. I'm installing an 07 Ej25 which I believe is rated at 173hp and SC says that the stock Subaru pressure plate is only good for 145hp and below Confused and I need a "stage 2" pressure plate. I know the Vanagon is heavier than a Forrester but the Subaru has AWD so the clutch should be strong enough to hold the power right?
Just wondering if anyone out there has any experience with this setup. I like to use as many stock parts as possible as the price tends to be lower and the reliability tends to be higher. Any thoughts?
Team WorldTour
Team WorldTour is offline
PostPosted: Tue Feb 01, 2011 12:09 am    Post subject: Reply with quote
The advice I got for my 3L convert was to use Turbo-rated Impreza parts.
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
iltis74
iltis74 is offline
PostPosted: Tue Feb 01, 2011 1:12 am    Post subject: Reply with quote
You must have gone with RJES then, pretty sure Smallcar won't take the turbo parts. I too went RJES Turbo, so I'm no real help, but I wonder if you could use the RJES input shaft with that to get away with a Subaru disk? Is there no factory 2.5L clutch setup that works here? Weird.
Worms
Worms is offline
PostPosted: Tue Feb 01, 2011 1:13 am    Post subject: Reply with quote
I should have kept the parts numbers...
I used a Subaru 2.5 pressure plate, which my local SUBlab dealer got for me. He searched the parts list for the highest clamping force, as they do vary. The clutch plate is the smallcar one with the VW centre and subaru disc.
My engine is 165hp, and I have NO issues whatsoever - even hard starts, and high speed gear changes. It breaks traction before the clutch slips.
The subaru pressure plate for the engine you have would work fine.
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Feb 01, 2011 1:38 am    Post subject: Reply with quote
RJES input shaft won't fit in Smallcar bellhousing and he won't sell it to you... Rolling Eyes
Bye!
SyncroGhia
SyncroGhia is offline
PostPosted: Tue Feb 01, 2011 2:34 am    Post subject: Reply with quote
The RJES input shaft may fit with the Smallcar bellhousing but, from what I've seen and read (and measured), the Smallcar bellhousing is deeper (longer, pushing the engine further away from the gearbox) than the RJES bellhousing so it wouldn't be long enough for any other application.
I would doubt that RJES would want to spend time working out if any of his products will or won't work with any products from a competitor.
I can't comment on whether RJES would sell you one of his input shafts or not, that's his call.
MG
T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Westendwulf
Westendwulf is offline
PostPosted: Tue Feb 01, 2011 3:22 am    Post subject: Reply with quote
Hi Vango,
Don't have an answer to your question but wanted to show you the set up from rjes ........
the input shaft makes it a very tidy kit.
85 1.9 with a 2.1 exhaust
86 Westfalia Weekender Wolfsburg Edition
EJ25 DOHC RJES Bellhousing Auto -> Manual
87 2.1 Wolfsburg Edition
Damn that syncro lust!
Christopher Schimke
PostPosted: Tue Feb 01, 2011 7:40 am    Post subject: Reply with quote
Bye!
I am 99% certain that the reason Richard (RJES) won't sell his input shaft for use with the Small Car bellhousing is because of the way the Small Car kit requires the repositioning of the input shaft via their spacer. This pushes the input shaft away from the mainshaft which reduces spline engagement. Richard and I have talked at length about this and and both of us agree that the reduced spline engagement that the spacer imparts is not all that wise. I'm sure that Richard simply does not want one of his shafts torn up because of this lack of engagement because inevitably, the blame will end up being put on RJES, not Small Car.
From a hydraulic/clutch actuation standpoint, I would suggest driving a van equipped with a SC bellhousing before making a decision.
svxcarat
svxcarat is offline
PostPosted: Tue Feb 01, 2011 9:20 am    Post subject: Reply with quote
I did an SVX conversion with the small car bellhousing. The clutch does not feel as smooth as the adapter plate one in my eyes. It is very springy and releases more abrupt. (With a high torque pressure plate in both) If you ever have problems with the clutch slave you would have to take the tranny or engine out.
j_dirge
j_dirge is offline
PostPosted: Tue Feb 01, 2011 9:51 am    Post subject: Reply with quote
Have you guys done an RJES bellhousing, yet?
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Feb 01, 2011 9:57 am    Post subject: Reply with quote
Splines diameter is bigger,doesn't go through the bellhousing. Wink
Christopher Schimke
PostPosted: Tue Feb 01, 2011 10:03 am    Post subject: Reply with quote
I'm not taking about the splines for the clutch disk, I am talking about the splines on the other end of the input shaft that go into the spacer between the input shaft and the main shaft.
The way that Small Car is able to keep the same distance at the bellhousing as with an adapter is by adding a spacer in between the input shaft and the main shaft. This reduces the amount of spline engagement in that area (as well as at the clutch disk if I'm not mistaken). It is for that reason (the potential lack of durability) that I think Richard will not sell his input shaft for use with the Small Car bellhousing.
svxcarat
svxcarat is offline
PostPosted: Tue Feb 01, 2011 10:05 am    Post subject: Reply with quote
No I have not used that one yet
J Charlton Premium Member
J Charlton is offline
PostPosted: Tue Feb 01, 2011 10:07 am    Post subject: small car bellhousing and clutch Reply with quote
I put a Subaru pressure plate in when I installed my 2.5 2 years ago with the smallcar bellhousing. It broke this past summer. Smallcar expressed me the replacement clutch disk, pressure plate and flywheel overnight. They now recommend a heavier pressure plate, I found that the replacement parts were competitively priced and I couldn't have asked for better service. I was back on the road 36 hours after the clutch disintegrated - not bad considering I was in Amarillo Texas, a long way from Tacoma Wa.
NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024
insyncro
Banned
insyncro is offline
PostPosted: Tue Feb 01, 2011 10:15 am    Post subject: Reply with quote
I have experience with both the SC bellhousing and the RJES.
I prefer the RJES for a few different reasons.
dylan
SyncroGhia
PostPosted: Tue Feb 01, 2011 10:30 am    Post subject: Reply with quote
As far I know, the splines are a larger diameter but they pass through the stock seal without problem. I've no idea what the smallcar bellhousing uses so can't comment whether it would fit through.
MG
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Vango Conversions
PostPosted: Tue Feb 01, 2011 1:21 pm    Post subject: Reply with quote
Wow, thanks for all the replies everyone. I didn't mean for this to turn into a discussion about what adapter/bell housing was best but it has raised some interesting questions.
I've always had good luck with the KEP adapter plate and the stock VW clutch, no slipping issues. I was just going to try the Small car route due to the heavier Subaru flywheel and the Subaru starter being stronger than the stock VW unit. It sounds like the SC unit has some durability issues which I wasn't aware of. I always want to put reliability before anything else so maybe I won't go this route. I was planning on picking up the parts tomorrow morning.
RJES units seem to look nice but the price seems a bit too steep and seems like shipping would take a while to the states, unless there is a US distributer. Looks like I may just do another KEP adapter, still thinking about it though.
Team WorldTour
PostPosted: Tue Feb 01, 2011 1:44 pm    Post subject: Reply with quote
In auto parts, you get what you pay for. Richards bellhousing IS top-notch. I highly reccomend you look at them again. Shipping should only be a week. I had mine shipped to me through the APO system (military mail), and it took a week and a half. You will need the stock Subi stuff, but its easier to get to and change out than the SC. Look at it again before you make up your mind....
Click to view image
914 mike
914 mike is offline
PostPosted: Tue Feb 01, 2011 2:24 pm    Post subject: Reply with quote
I used Outfront Motor Sports stuff on mine. Although its a 2.2 set up, I have been very happy. I know they build some high horsepower stuff for offroad applications....you might consider them...
http://www.outfrontmotorsports.com/clutch_flywheel.htm
Mike
84 Westy
2.2 Suby
In a world full of ponies it's a thoroughbred horse....
Can ≠ Should
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Feb 01, 2011 2:39 pm    Post subject: Reply with quote
Which one of the items in the Small Car kit picture is the above referenced spacer?
Page 1 of 17
