Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 892 Location: Cornwall, UK
Posted: Fri Jan 28, 2011 1:21 pm Post subject: SA and IRS guys. How have you mounted your rear shocks? |
Would like some pics and descriptions of various setups to look at the options.
Cheers |
Concept1 Samba Member
Joined: September 07, 2004 Posts: 334 Location: Calgary, Canada
Posted: Fri Jan 28, 2011 4:36 pm Post subject: |
Dude that is a nice setup. Would be a shame to not use those old shock mounts.
Jacks Samba Member
Joined: July 15, 2006 Posts: 2464 Location: San Clemente, Ca.
Posted: Fri Jan 28, 2011 10:59 pm Post subject: |
| I really like the kwc mount but the shock travel looks to be about 1" to 1 1/2", while the spring plate range is 3" to 4". |
Franz Samba Member
Joined: March 31, 2005 Posts: 346 Location: Grand Junction
Posted: Sun Jan 30, 2011 2:13 am Post subject: |
Pics guys? You'd think there were only stock buses out there.
Here's another SA, not the best pic. It's from that super low Japanese bus.
The more usual method. Just weld on a mount to the chassis legs.
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5002 Location: Nor Cal 707
Posted: Tue Feb 08, 2011 12:43 pm Post subject: |
I just did a run of those upper shock mounts...I copied an original Split window bug piece.
That's what I use. |
Blauhaus Samba Member
Joined: June 18, 2003 Posts: 140 Location: Jacksonville, FL
Posted: Tue Feb 08, 2011 1:41 pm Post subject: |
Very sweet Greg! _________________ www.blau-haus.com
QUALITY CLOTHING. PRODUKTS. FÜR THE PEOPLE.
** WANTED **
Haines VW dealership (Sacramento) license frame |
Posted: Tue Feb 08, 2011 1:56 pm Post subject: |
| Blauhaus wrote: |
| Very sweet Greg! |
Thanks, I can make them longer for barndoors if needed. Also working on the lower mounts for non lower shock mounts trans (early split / pre-a / barndoor) I'll be making them "stock" and longer. |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3081 Location: The Bull City
Posted: Tue Feb 08, 2011 6:27 pm Post subject: |
| Those ends where the shocks mount don't seem very stout... They look good though |
Posted: Tue Feb 08, 2011 10:37 pm Post subject: |
| VWsArent4Hippies wrote: |
Copied from an original. Same dimensions same thickness metal, etc.
More on that in the split section here...
http://www.thesamba.com/vw/forum/viewtopic.php?t=449796 |
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Fri Feb 11, 2011 8:08 am Post subject: |
Will the new, longer ones enable me to replace my lever shocks on a stock barndoor setup with regular shocks? If so, I have a set of levers if someone wants them once these are on. _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
Posted: Fri Feb 11, 2011 11:20 am Post subject: |
| BulletBus wrote: |
| Will the new, longer ones enable me to replace my lever shocks on a stock barndoor setup with regular shocks? If so, I have a set of levers if someone wants them once these are on. |
If it's not lowered you don't need longer ones. The above upper mounts and a set of triangle mounts for the bottom will do the trick.
I should have the lower mounts done next week sometime. |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Fri Feb 11, 2011 2:46 pm Post subject: |
| joe56vw wrote: |
will those work on newer buses with narrowed rear end or those offset springplates?
and how much are they going to be sold for? |
With enough determination and fabrication anything can be made to work.
These however are made to bolt on through the existing lever shock holes and the triangles bolt on through the axle / spring plate holes.
I've used the upper mounts in early cars running later transaxle's that have lower shock mounts as well. Works very good.
As for a price, the uppers run $150 a set, not sure on the lowers. There will of course be a package price if they are bought together. |
barnduude Samba Member
Posted: Mon Feb 14, 2011 2:01 pm Post subject: |
alo,
here is how i did it
there are others pics in my gallery
grtz to all. _________________ www.everyoneweb.com/luftwaffenracing
'54 BD kombi.
'68 APAL samtrack.
hell is empty, all devils are here. |
