jalopyjockey Samba Member
Posted: Fri Feb 11, 2011 12:22 pm Post subject: |
| Quote: |
| But if his are really new, I'd be willing to bet they're not KS. |
and from the impression i get of the guy; if he had ks or mahle mains for a t4, he woulda been one of them types that would put them up on ebay for 300+ and let the bidding frenzy commence.....
hope you wbxer guys are appreciative of your parts availability..... |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10163 Location: Abiquiu, NM, USA
Posted: Fri Feb 11, 2011 1:05 pm Post subject: |
| klucz wrote: |
| No way, reusing old mains over new? That's very good to know. I was going to use a new set of Mahle mains in my 1.9. I had also bought a set of new (nla) KS 1.9 mains still wrapped in plastic but they looked beat up. The babitt material was coming off so I returned them. The original KS mains definitely show some wear but they don't have any material flaking off like the new ones did. |
If you're putting them in the same places in the same case, the surface finish isn't eaten away (i.e. it's still all babbitt with minimal scoring) and they bore mic out with good oil clearances (which you had better do with every set, new or not), there's no reason not to use a good set of used mains, you save a good chunka-change doing that. Same goes for rods, and even cams, but fresh sets of those are so cheap there's just no point in it.
I'm running for 50k miles now in my daily on a used set of mains, reportedly with about 50k miles of use before me, but who knows how long they really went. The thing about hydrodynamic bearings is, if the oiling system were always doing its job, there would be zero bearing wear, zero, over any amount of mileage. Almost all the wear occurs on cold startups before the oil lubricates well. Because we don't run engines continuously that is unfortunately unavoidable, so there is accumulated wear over time even with a perfect oiling system, along with the occasional transient events where the ZDDP kicks in or the babbitt has to do its job.
But lest anyone get the wrong impression, all my customer engines get all new bearings, mains, rods, and cams.
| Quote: |
Well we're not as bad off as Type4 builders, but it ain't no walk in the park either. Std. 2.1 mains are still available, but offsizes are getting harder to find. I can get ten unders reliably, if I hunt around maybe I can find some twentys if I get lucky, but overs are scarce. That's 2.1's; full 1.9 sets in anything but std. are just as scarce as full Type4 sets. Sucks that the only unique 1.9 bearing is the thrust, it's not a Type1 nor a Type4, just slightly diferent than a 4, when the rest is Type1 exactly. Given that every single 1.9 case I have yet seen has a bad thrust, all those cases are officially junk where I live. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Please don't PM here, I will not reply. |
ryanj10 Samba Member
Joined: April 21, 2010 Posts: 43 Location: Kansas City
Posted: Fri Feb 11, 2011 1:12 pm Post subject: |
2.1
Manual
Unsure
Owned for 4 years
261,xxx miles
10k miles a year
Has never let me down...knock on wood..fingers crossed etc, etc. _________________ 89' Vanagon Carat 2.1WBX |
klucz Samba Member
Joined: February 14, 2006 Posts: 1062 Location: Chicago, IL
Posted: Fri Feb 11, 2011 4:40 pm Post subject: |
| tencentlife wrote: |
| Std. 2.1 mains are still available, but offsizes are getting harder to find. I can get ten unders reliably, if I hunt around maybe I can find some twentys if I get lucky, but overs are scarce. That's 2.1's; full 1.9 sets in anything but std. are just as scarce as full Type4 sets. Sucks that the only unique 1.9 bearing is the thrust, it's not a Type1 nor a Type4, just slightly diferent than a 4, when the rest is Type1 exactly. Given that every single 1.9 case I have yet seen has a bad thrust, all those cases are officially junk where I live. |
Regarding 1.9's. Can you use Type1 mains for #'s 2, 3, and 4, and IF you can get your hands on a custom cut thrust bearing, can you use those instead? I know nothing about Type1's or the quality of available parts but I do see that main bearings in different sizes are available. I realize that this would probably be a waste of time and money in most cases, because rebuilding a 2.1 might be easier and cheaper (and you'd have a little more power), but I was just wondering. Could you do it that way or is there more to it than that?
Thanks _________________ 84 Westy 4spd sold |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Fri Feb 11, 2011 5:16 pm Post subject: |
 _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
Posted: Fri Feb 11, 2011 5:31 pm Post subject: |
| Quote: |
| Well we're not as bad off as Type4 builders, but it ain't no walk in the park either. Std. 2.1 mains are still available, but offsizes are getting harder to find. I can get ten unders reliably, if I hunt around maybe I can find some twentys if I get lucky, but overs are scarce. That's 2.1's; full 1.9 sets in anything but std. are just as scarce as full Type4 sets. Sucks that the only unique 1.9 bearing is the thrust, it's not a Type1 nor a Type4, just slightly diferent than a 4, when the rest is Type1 exactly. Given that every single 1.9 case I have yet seen has a bad thrust, all those cases are officially junk where I live |
ugh, you guys too, that sucks...im still kickin myself over the ones ive binned as a wear item in the past...already raided my circle file for the ~pseudo marginal ones...in the hope of something, anything...raby had made mention that there are bearing reconditioners but i got the impression its spendy....dont mean to be an ass but im glad i only build for myself, hope these five sets i have last me till im too incontinent to drive anywhere
iirc...fusername on stf sells various wbx thust bearings...not sure on anything beyond that....thought i heard rumor he 'inherited' boston bobs oddball bearing collection, take it for what it is though, just something i kinda remember seeing |
klucz Samba Member
Posted: Fri Feb 11, 2011 6:14 pm Post subject: |
Yeah I've heard of fusername's stash too. I don't know anything more about it either. He's also on thesamba btw. From what I've gathered a 1.9 case can be align-bored and thrust cut. So if you can get the right bearings together then it would be doable. Or so it seems. _________________ 84 Westy 4spd sold |
Posted: Fri Feb 11, 2011 7:11 pm Post subject: |
Yeah I bet fusername still has BB's stash of bearings.
| Quote: |
| Can you use Type1 mains for #'s 2, 3, and 4, and IF you can get your hands on a custom cut thrust bearing, can you use those instead? |
That's the deal. The drag is finding that #1 bearing. It's the same diameter as a Type4's, but the saddle width is different.
Then to align-bore you need both the Type1 and 4 cutters. But if the thrust bearing had been loose you probably (not always, but most times) need to shave the side of the saddles, too, and then you're looking at an oversize thrust bearing as well as overbore, that could be a real hard bearing to procure, never mind the crank size you have to match.
Gotta watch it with custom made bearings out of straight aluminum, too, making that work isn't as simple as it seems. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
klucz Samba Member
Posted: Sat Feb 12, 2011 2:13 am Post subject: |
Sounds like DH is the bastard of the Wolfsburg flat-4 fam. Tough luck I guess. _________________ 84 Westy 4spd sold |
Posted: Sat Feb 12, 2011 10:54 am Post subject: |
| klucz wrote: |
| Sounds like DH is the bastard of the Wolfsburg flat-4 fam. Tough luck I guess. |
I always thought I would make something of these DH's I have piling up here, little 1.9 turbos is what I had in mind, but seeing that every one has a loose thrust bearing and with the scarcity of the parts I would need to make these into anything...well let's just say anyone who wants six DH cases, they're here for the taking. Pickup only, I'm not going to spend my time packing and shipping scrap. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
SlalomVan Samba Member
Joined: March 28, 2006 Posts: 131 Location: Seattle, WA
Posted: Sat Feb 12, 2011 1:10 pm Post subject: http://www.importmotor.com |
Anybody have information on these guys? http://www.importmotor.com
I saw them advertising here on the samba for a 2.1 Waterboxer Longblock VW Engine Price: $1915
Just curious if anyone has any feedback on them. This price seems too low.
Thanks! _________________ 1989 Vanagon GL - 2.1 (White - "Northlake" Totaled/Gone)
1988 Vanagon GL Wolfsburg (Orly Blue - "Poulsbo" - Sold)
1989 Vanagon G - 2.1 (White - "Kingston") - Full rebuild underway - Last on the road in 1997 |
klucz Samba Member
Posted: Sat Feb 12, 2011 5:04 pm Post subject: |
| little 1.9 turbos is what I had in mind |
That's like awesome and cute, and brutal... in an evolutionary sort of way.
Nuthin wrong with big turbos though! _________________ 84 Westy 4spd sold |
Posted: Sun Feb 13, 2011 12:01 am Post subject: |
that's what I had in mind too, a nice little 1.9T. _________________ Tencentlife said,
bohurley Samba Member
Posted: Wed Jan 15, 2014 11:44 am Post subject: |
1983 Westy
1.9
stick
unknown, but PO switched to a carb
2 weeks
147000
hopefully 10-15 thou
runs strong but needs a radiator _________________ '68 Squareback
'83 Westy |
