Soda Blast case
Tyler9537
Tyler9537 is offline
PostPosted: Sun Feb 13, 2011 4:14 pm    Post subject: Soda Blast case Reply with quote
I tried power washing, oven cleaner, scotch bright, and the dish water with no luck.
So I bought this:
http://www.harborfreight.com/10-lb-portable-soda-blaster-65902.html
Its on clearance for ~$35
And turned this case:
into this:
I'm convinced that soda blasting is magic. Worked like a charm. Only complaints is that is gets everywhere and you have to shake the container occasionally to get it to flow. I went through about 6lbs total to do the entire case and a 4BBL carb for my friend. Baking soda is $1 for 2lbs at wally world.
I know that soda blasting has been mentioned time over again along with other methods. This is by far the best method in my opinion. Also will come in handy for cleaning up a couple more carbs, transmission, etc. I wouldn't even mess with power washing or any hand held cleaners again. I just placed it up on the shelve until i receive the rest of my parts and machining. When the time comes ill dip it in a bath of water to clean all the galleys and such. Then a quick dip in the parts cleaner to keep it from oxidizing before i assemble it.
66brm
66brm is offline
PostPosted: Sun Feb 13, 2011 4:57 pm    Post subject: Reply with quote
Nice job, I would give the case a coat of light oil for while its sitting on the shelf though as any moisture in the air will cause the corrosion to return, I had a case sit dry for two years and found light corrosion, a quick spray of CRC or WD40 killed it off
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
Dangermouse
Dangermouse is offline
PostPosted: Sun Feb 13, 2011 5:44 pm    Post subject: Reply with quote
It is pretty amazing and perfect for engine cases.
Mine went from this...
To this...
I gave it a liberal spray with this stuff afterwards -
I think it's just a penetrating oil but it soaked into the metal and seems to be protecting it well in the months it's been sat on the bench since it got the soda treatment. Gave it a nice sheen too.
http://www.roadsters.com/gibbs/
Because "Magnesium that's coated with Gibbs Brand is happy magnesium." Laughing
Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you.
2332turboSF
2332turboSF is offline
PostPosted: Sun Feb 13, 2011 6:51 pm    Post subject: Reply with quote
SWEET! Thanks for the tip I just called my local harbor freight and they have a couple in stock! You know what Ill be picking up in the morning Very Happy @ $34 Shocked Im ALL over that thing.
Tyler9537
PostPosted: Sun Feb 13, 2011 7:08 pm    Post subject: Reply with quote
where can one purchase Gibbs oil at? Or do i have to order it online?
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Feb 13, 2011 7:43 pm    Post subject: Reply with quote
That is the only place I have ever seen it.
gt1953
gt1953 is offline
PostPosted: Sun Feb 13, 2011 8:10 pm    Post subject: Reply with quote
Deffinetly coat the case with some sorta petroleum based something or other to keep is from exidizing. Man soda blasting is the way to go and safe too.
72 type 1
72 Squareback
BugMan114
BugMan114 is offline
PostPosted: Sun Feb 13, 2011 10:14 pm    Post subject: Reply with quote
the site says $99.99 Is it a store thing, or has the price gone up?
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
saw2
saw2 is offline
PostPosted: Mon Feb 14, 2011 9:49 am    Post subject: Reply with quote
I just talked to two harbor freight stores in Oregon and one had soda blasters on clearance for 35.00 the other store did not. So you may have to call around. For 35.00 bucks I think I will try one !
mark tucker
mark tucker is offline
PostPosted: Mon Feb 14, 2011 9:56 am    Post subject: Reply with quote
I saw one sunday and it was reg price (in alabama, why I was there is a mistry to me)
satcom80911
satcom80911 is offline
PostPosted: Mon Feb 14, 2011 10:20 am    Post subject: Reply with quote
It may seem obvious, but don't forget to flush your case out completely - air, then clean water and dry it out with compressed air. It doesn't take much residue to eat away your bearings. I've seen engines ruined on the test stand by some companies (I'm also an air-cooled aircraft engine mechanic / ignition specialist) because just a tiny bit of abrasive was hiding in an oil gallery and was missed during preassembly inspection.
Don't be jealous because the voices in your head only talk to me!!
1302s - the Ultimate go-kart with a windshield!
-'72 Super Beetle Mod "Maggie"
-'65 Standard Beetle Resto "Butthead"
-'65 Split Window Bus Resto "Mollie"
-'00 New Beetle "Mollie 2"
Bashr52
Bashr52 is offline
PostPosted: Mon Feb 14, 2011 12:11 pm    Post subject: Reply with quote
What about old engine cases that have a nice heavy coating of old grease/dirt on them? Do you have to pre-wash them before blasting?
satcom80911
PostPosted: Mon Feb 14, 2011 12:47 pm    Post subject: Reply with quote
It would be a good idea to wash it first so you don't have to waste your abrasive. Just a quick scrub with a brush (like one you would use on dirty pots/pans) and some water with liquid dish soap will save you time in the long run.
2332turboSF
PostPosted: Mon Feb 14, 2011 1:45 pm    Post subject: Reply with quote
Just finished putting mine together Wink Anyone out here the hesperia store has 5 left @ $34 a peice Very Happy I gotta say, Harbor freight seems to be stepping up the quality compared to the crap I used to get there back in the day.
ZiggyG
ZiggyG is offline
PostPosted: Mon Feb 14, 2011 6:12 pm    Post subject: Reply with quote
Don't forget, Harbor Frieght has coupons out all the time. I've used the 20% off coupon multiple times for the big stuff.
http://www.harborfreight.com/extra-savings.html
Life is Grand, treat it that way.
gtixpress
gtixpress is offline
PostPosted: Tue Feb 15, 2011 11:55 am    Post subject: Reply with quote
Thanks for the heads-up on the cheap soda blaster. My Harbor Freight only had 2 left @ $35. It will come in handy cleaning up my long block that has been sitting around a while and Dellorto carbs.
Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible
BugMan114
PostPosted: Thu Feb 17, 2011 8:33 pm    Post subject: Reply with quote
my local harbor frieght said they only had the display model left. i went up there, and it was just the tank, it was missing everything that goes attached to it Evil or Very Mad . the only other store near me (2 hrs away) was sold out Crying or Very sad .
If its any consolation to anyone else who couldn't find any, the 15lb model is on sale for $99 (the one on clearence for $35 was the 10lb version).
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
modok
modok is offline
PostPosted: Thu Feb 17, 2011 8:42 pm    Post subject: Reply with quote
Blasting works poorly on goop, so you must degrease the case as much as you can.
Otherwise the media just gets stuck in the goop and it LOOKS clean, but it isn't!
MURZI
MURZI is offline
PostPosted: Thu Feb 17, 2011 8:59 pm    Post subject: Reply with quote
Just bought this joker and used a 20% off coupon to boot!! I will post pics of my success/ failure tommorow... Gotta do my case and may spritz the outsides of my Idf's. Thanks for the tip guys!!!
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
BugMan114
PostPosted: Thu Feb 17, 2011 9:25 pm    Post subject: Reply with quote
where do yall see the 20% off coupon at?
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
