Spare tire racks
jfswesty
jfswesty is offline
PostPosted: Tue Feb 15, 2011 7:00 am    Post subject: Spare tire racks Reply with quote
Moderator note:
A thread exists for this topic:
http://www.thesamba.com/vw/forum/viewtopic.php?t=483486
Please use it for new posts
This thread locked
Rolling Eyes Hi folks. Cold morning here. Saw a syncro on here a week or so ago with the spare tire mounted on a rack that looked as thou it was fastened to the rear lift hatch. Since moving up to the 16" rims, the spare doesn't fit under the front. Anyone know about this rear rack with the tire set up over the left side of the rear window ?? Looked pretty good. Thanks.
Jm
J Charlton Premium Member
J Charlton is offline
PostPosted: Tue Feb 15, 2011 7:15 am    Post subject: racks Reply with quote
the best
http://www.telusplanet.net/public/gary2a/rack/vanagonrack.htm
NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024
VisPacem
VisPacem is offline
PostPosted: Tue Feb 15, 2011 7:28 am    Post subject: Re: Spare tire racks Reply with quote
Jm
garylee's basic tire carrier: give or take a few rupees, US1000 lock stock and barrel, sorry but Laughing Laughing Laughing
Ford Bronco II, at Pig A Part or Craiglist, US$40 Laughing Laughing Laughing
Well it goes on passenger side, but a little inconvenience (for you I guess) for US$960 ?
LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons)
Jon_slider
Jon_slider is offline
PostPosted: Tue Feb 15, 2011 10:24 am    Post subject: Rocky Mountain Westy has a $500 swing out, killer deal! Reply with quote
I think Gary's best bang for the buck is his ladder with tire and gas carrier
and this is the deluxe $etup
keep in mind that if you like to open your rear hatch often, you would be best served by his swing away tire carrier, not hatch mounted ladder.
as far as junkyard tire carriers, the pathfinder is also an option. more info here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=3626536#3626536
Rocky Mountain Westy makes some very nice stuff too:
The Rocky Mountain Westy tire and gas carrier is on Sale for $500.. But you have to buy their bumper too.
(imo, Gary is overpriced.)
http://www.rockymountainwesty.com/Single_Swing_Tire_Carrier_with_2_Can_holder_p/rmw-tcss01.htm
Van Cafe sells the Rocky Mountain Westy Heavy Duty bumper,
http://www.van-cafe.com/home/van/search?keywords=hdb&x=0&y=0
and a matching tire carrier (the combined cost is not much more than the Gary lee tire carrier alone).
Van Cafe also sells this inexpensive extended carrier, for the stock location
as well as Burleys steering shaft protector
see bottom of page
http://www.van-cafe.com/home/van/search?keywords=tire&x=0&y=0
and here is the link to Burleys site, and his current tire carrier
http://burleysmotorsports.com/index.php?main_page=...jlop6ni0a6
j_dirge
j_dirge is offline
PostPosted: Tue Feb 15, 2011 11:01 am    Post subject: Reply with quote
Burley should have one coming in the next couple of months or so, too.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
canasync
canasync is offline
PostPosted: Tue Feb 15, 2011 5:31 pm    Post subject: Reply with quote
Don't forget that the tire size is the deciding factor not the rims. So if you are getting 16's but keeping the stock tire diameter you will not have an issue.
1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Planar Coolant Heater
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift
ericos_bob
ericos_bob is offline
PostPosted: Wed Feb 16, 2011 5:39 pm    Post subject: Reply with quote
How do the ladder mounted carriers work? Difficult to open the rear door? Stronger struts used?
My bad I just found the answer in the link above. Surprising that all that all the weight does not make the door noticeably harder to open.
syncrodoka
syncrodoka is offline
PostPosted: Wed Feb 16, 2011 9:50 pm    Post subject: Reply with quote
I looked at a syncro that had a good size pair of matching dents on the top and bottom of the rear hatch. The owner said that the secret combination to get them was this rack combination w/spare and washboard roads.
About 45 LBS. for a full gas can, 30 lb. Hi-Lift, 50+ LBS. for the spare(depending on tire size and rim) and the weight of the rack holding onto sheetmetal is asking for a lot.
VWZigs
VWZigs is offline
PostPosted: Thu Feb 24, 2011 10:08 pm    Post subject: Reply with quote
VWZigs
VWZigs is offline
PostPosted: Thu Feb 24, 2011 10:11 pm    Post subject: Reply with quote
BoxsterGT
BoxsterGT is offline
PostPosted: Fri Feb 25, 2011 8:52 am    Post subject: Reply with quote
Smile
Does anyone know of a "Front" mounted spare carrier?
I have a Doka and don't want it in the way. Perhaps a mount at the back of the cab would work.
Len
Smile
stclair411
stclair411 is offline
PostPosted: Fri Feb 25, 2011 9:08 am    Post subject: Reply with quote
BoxsterGT wrote:
Smile
Len
Smile
Could you just use a Yakima Load Warrior basket with the spare tire attachment? Could be a good way to keep a Hi-Lift, shovel, and a few other things out of the way as well. Not real fancy, but might be all you need.
1987 Syncro Westy "June"
jbell
jbell is offline
PostPosted: Fri Feb 25, 2011 9:44 am    Post subject: Reply with quote
This is how I carry an extra spare for remote trips. It mounts to the tow bar which might come in handy also.
To answer some questions posed :
1. It doesn't make the temperature run hotter.
2. Since this is in addition to the normal spare in the clamshell I think
it would actually help a lot in a front collision by distributing the
force to a wider area.
jbell
1984 Westy Joker 1.6 NA Diesel, 5 sp
FrankenSubySyncro
FrankenSubySyncro is offline
PostPosted: Fri Feb 25, 2011 12:13 pm    Post subject: Reply with quote
Here is my version of the pathfinder carrier:
[img]http://www.flickr.com/photos/subyvanagon/4902692558/in/set-72157624747893200 [/img]
$10 from pick n pull plus $50 for heim joints and steel post plus some scrap metal pieces. Flipped to open from the drivers side and extended about a foot. I reused the latching mechanism from the pathfinder. No connection to the hatch.
Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/
Witless Joe
Witless Joe is offline
PostPosted: Fri Feb 25, 2011 12:48 pm    Post subject: Re: Rocky Mountain Westy has a $500 swing out, killer deal! Reply with quote
see bottom of page
I'm pretty sure both of those would be most help for a Syncro, not a 2wd. The cross member on a 2wd is closer to the undercarriage, and since the rear part of the spare tire has to rest on the top of the cross member, it ends up setting the pinch point (and fulcrum), regardless of what you do with the clamshell or wire hinges.
A link to a previous post of mine with a photo of my own solution to this issue:
http://www.thesamba.com/vw/forum/viewtopic.php?p=4432968&highlight=#4432968
It's interesting to read all this concern with the steering shaft interference, which was not my problem with a 2wd install. Maybe the Syncro crossmember makes that more problematic. My 1985's 2wd steering shaft was completely clear, but shifting into reverse (pushing down on the shifter) would contact the tire sidewall on the shifter rod. I had to lower the tire pressure to about 30 psi to accomodate that, and rotate the tire periodically by a couple of inches to avoid chafe in the same area. The chafe is pretty trivial, relative to the curb rash the tire is doubtless designed to take, but I'm fussy like that. Smile
ddye
ddye is offline
PostPosted: Fri Feb 25, 2011 1:05 pm    Post subject: Reply with quote
Like it
1988 Westy
2.1 Boston Bob Rebuild
"Nelly"
ddye
ddye is offline
PostPosted: Fri Feb 25, 2011 1:07 pm    Post subject: Reply with quote
toomanyveedubs wrote:
Fixed it 4 u
I was thinking about this. Wouldn't this block the radiator thus wouldn't the van run hotter?
1988 Westy
"Nelly"
chimivee
chimivee is offline
PostPosted: Fri Feb 25, 2011 1:37 pm    Post subject: Reply with quote
Hatch is definitely harder to open with a loaded GL rack on back. Additional support is needed if you want to keep the hatch open on its own.
-James
86 Syncro Westy, etc
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
chimivee
chimivee is offline
PostPosted: Fri Feb 25, 2011 1:45 pm    Post subject: Reply with quote
Ouch. I've driven a bit of washboard roads with about 100+ lbs loaded on my G.L. full-size rack, with no ill-effect. (except for lots of loose interior screws!) I wonder if that owner's rack was loose, causing it to hammer down on the hatch?
-James
Rocky Mountain Westy is offline
PostPosted: Fri Feb 25, 2011 2:36 pm    Post subject: Reply with quote
So here is a new prototype we have been working on. These swings will work with basically any bumper, ie: GoWesty, All our RMW bumpers, Stock fiberglass or metal. They will be available soon.
Van Cafe & Rocky Mountain Westy Inc.
970-310-3441
[email protected]
The Splitzgauer build (when I have time to work on it and update the thread)
http://www.thesamba.com/vw/forum/viewtopic.php?t=497133
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Vanagon All times are Mountain Standard Time/Pacific Daylight Savings Time
