Bigger Front Torsions
Clatter
Clatter is offline
PostPosted: Sun Feb 27, 2011 10:06 am    Post subject: Bigger Front Torsions Reply with quote
Sooo, were there any cars that had bigger front torsions than the others?
The square has bigger rears, but what about the front?
Do different years make any difference?
Was there ever a 'country' or 'severe duty' option?
Any other vehicles that use a similar bar, but thicker?
Maybe they could have a sleeve welded on to stiffen?
ANything but a T1 beam! LOL...
Bus Motor Build
It does not exist!
Critter1
Critter1 is offline
PostPosted: Sun Feb 27, 2011 10:37 am    Post subject: Reply with quote
Yes. There is a 10mm and a 13mm front tortion bar (left two in picture). I believe the 13mm came on late model squares.
Justin
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Feb 27, 2011 10:48 am    Post subject: Reply with quote
Can they be retrofitted? In other words, are the ends identical?
Also, do you have measurements for both the roll bar and the torsion bars?
flyinglow94
flyinglow94 is offline
PostPosted: Sun Feb 27, 2011 11:58 am    Post subject: Reply with quote
The two on the left of the picture are the upper sway bars of a type 3. both of them fit in the same beam the 13mm is from a late model and will fit in a early front beam. They have the same ends just a larger shaft in a late model.
"What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.."
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
supaninja
supaninja is offline
PostPosted: Sun Feb 27, 2011 1:08 pm    Post subject: Reply with quote
sweet, my front beam came out of a late square!
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
jimmynotch
jimmynotch is offline
PostPosted: Sun Feb 27, 2011 4:20 pm    Post subject: Reply with quote
So the 13mm can be swapped into an earlier beam and will work with any spindles? How much difference is there in ride between 10 and 13mm?
Jim in Sacto -
my wonderful loving supportive wife wrote:
You guys are dorks.
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2
KTPhil is offline
PostPosted: Sun Feb 27, 2011 6:16 pm    Post subject: Reply with quote
Should be almost no difference in ride, since it's just the sway bar. On hard cornering, it will be a little rougher since it is resisting body roll harder. A great trade-off.
vlad01
vlad01 is offline
PostPosted: Sun Feb 27, 2011 6:33 pm    Post subject: Reply with quote
I have a White Line prototype 24? mm swaybar kit Cool
vlad01
vlad01 is offline
PostPosted: Sun Feb 27, 2011 6:37 pm    Post subject: Reply with quote
No it's not a trade off. It improves cornering stability and reduces body roll. This was intended for payloads in squares.
Rougher ride??? Question with that small difference in bar diameter, I think not.
supaninja
PostPosted: Sun Feb 27, 2011 6:45 pm    Post subject: Reply with quote
Holy crap for the front dude, those are monsterous? I got a set of 24.5mm 944 S2 rear bars that around that size.
Nick
jimmynotch
PostPosted: Sun Feb 27, 2011 10:04 pm    Post subject: Reply with quote
So by "upgrading" to larger torsion bars, I can improve the way my notch handles on my favorite twisty roads?
Jim in Sacto -
You guys are dorks.
TOOB member #2
vlad01
vlad01 is offline
PostPosted: Sun Feb 27, 2011 10:10 pm    Post subject: Reply with quote
Twisted Evil
They are adjustable from 22-24-26? I think? or it might be 20-22-24mm?
The 22-24-26mm might be the rear now that I think about it.
vlad01
vlad01 is offline
PostPosted: Sun Feb 27, 2011 10:15 pm    Post subject: Reply with quote
yes and no.
torrions bars are the springs in VWs, swaybars is what I think you are talking about?
I stiffer swaybar will generally improve handling if selected properly. The car WILL need better and wider tyres. Both front and rear swaybars need to be added and need to be adjustable so you can tune over and under steer.
Having too stiff will cause crap handling as well as having none or too light.
supaninja
PostPosted: Mon Feb 28, 2011 7:41 am    Post subject: Reply with quote
on my old super i put a 3/4" rear bar while i was waiting for my new front strutsa and bigger front bar....oversteer city. after i installed the struts and a 7/8" front bar that old super became a go cart.
Nick
