MJKBugsandbuggies Samba Member
Joined: December 29, 2004 Posts: 86 Location: Outer Banks, NC
Posted: Mon May 16, 2011 5:53 pm Post subject: Mexican Beetle Rescue - Hello Kitty |
Picked up this little beauty after finding it in a U Pull and Pay junkyard on blocks last weekend. It had been in the yard for about 15 minutes before I stumbled across it, I offered to buy the whole car on the spot. So it really is a rescue.
Its a 2001 mexi- beetle titled in FL, It was all there except the radio, no rust, solid pans, small dent in the rear passenger fender, and a mangled front bumper. It was allegedly driven into the yard under it's own power. The story was that someone traded it in at a local Kia dealer who kept it on their lot briefly then sold it to the junkyard. I had it towed home yesterday.
In the 15 minutes before I saw the car someone had taken all of the relays out of it, I bought a new ECU relay for it today, I had a spare fuel pump relay and plugged it in but still wasn't getting any power to the fuel pump. Jumped the relay and it fired right up and drove it around the yard.
Does anyone know what other relays this thing came with and may still be missing? Or a pic of then relay panel with the relay numbers?
It still has the immobilizer hooked up and I'm thinking that maybe that isn't sending the control signal to the fuel pump relay. I've built type 181s, type 2s, and early beetles, this is my first F/I , so I'm sure I'll have a lot of questions for you experts. The plan is to respray, new interior (it's pink and white right now), some wheels, tires, and maybe lowering spindles, then put it up here on the Samba for a new home. Thanks in advance for the help. |
dreadpiraterobert Samba Member
Joined: January 17, 2010 Posts: 269 Location: Richmond, VA
Posted: Mon May 16, 2011 8:18 pm Post subject: |
Just an idea, if that's a rattle can job, there might be good paint under there. Wouldn't hurt to find out!
Great find! |
Spanky57 Samba Member
Posted: Mon May 16, 2011 8:23 pm Post subject: |
You're not gonna get rid of that paint are ya?
j/k, hey nice find you got there! _________________ Current car:
1973 Standard Beetle project
Past:
1971 Beetle
1968 Beetle
1965 Beetle
1959 Sunroof Beetle
1971 Bus |
priss Samba Member
Joined: May 06, 2010 Posts: 348 Location: bradford MA
Posted: Tue May 17, 2011 3:55 am Post subject: |
Got any pictures of the interior?
I have a pinkish theme going on with my beetle. I may be interested if you are just going to toss it anyway. Pink is the new black you know. |
Posted: Tue May 17, 2011 6:47 am Post subject: |
Quote: |
priss Posted: Today 6:55 am Post subject:
I'll take more, but here is one, you are welcome to it. I'll get you an estimated weight, shipping will be from 33478. The interior is in great shape, no rips or tears.
Fe2O3 Samba Member
Posted: Tue May 17, 2011 6:58 am Post subject: |
OMG, my daughter must not be allowed to see this....
Haha, imagine driving that thing home and having to pass through a gang of bikers somewhere on the way  _________________ 74 Beetle |
priss Samba Member
Posted: Tue May 17, 2011 7:34 am Post subject: |
WOW!
Thank you thankyou thankyou. You are So full of AWESOME. |
Posted: Thu May 19, 2011 5:44 pm Post subject: |
Need a little help here, as I said earlier I jumped the fuel pump relay to get her running, had a little time tonight to trace things out a bit and here is what I found;
#30 on the fuel pump relay is the 12 volt feed from the battery (12 volts, no issue).
#86 is the signal from pin 22 on the ECU(getting appx 5 volts)
#87 is 12 volt feed for the Fuel pump, injectors, and lambda probe
#85 is ground (?) from the immobilizer?
When i jumper # 85 to a ground she performs as it should, fuel pump charges, engine fires right up. My immobilizer has been removed, I traced the wire (red/yellow) from #85 it goes to where the immobilizer was previously located and is spliced to the same color wire then goes to pin 03 (Fuel pump and alarm relay) on the ECU. I did a continuity test between
pin #03 and ground with the key on and no continuity.
So, if I am thinking this out right pin #03 provides the ground for the fuel pump relay and was connected through the immobilizer, with the immobilizer removed and the wires spliced together, I should get a ground to the relay as the key is turned on .
Any thoughts on why I'm not getting a ground on pin 3 from the ECU?
Also, when running I get a loud whistling from the ECU near the vacuum tube connection, thought it might have been the short piece of connector hose and replaced it but I'm still getting the loud whistle, any thoughts? |
cookrw Samba Member
Joined: June 09, 2009 Posts: 873 Location: Augusta, KY
Posted: Thu May 19, 2011 5:59 pm Post subject: |
I would so be rocking the pink. Shoot some rattlecan clear coat on it and call it good! _________________ '71 Super 'Vert
'84 Vanagon GL (w/ Sunroof!)
'96 Jeep Cherokee |
ravendarat Samba Member
Joined: March 09, 2011 Posts: 35 Location: Edmonton Alberta Canada
Posted: Thu May 19, 2011 7:18 pm Post subject: |
I have a 68 beetle painted the same color pink. Im in the process of making it a roadster and trying to decide if I should keep it pink or not. |
whobba Samba Member
mgamike Samba Member
Joined: August 07, 2010 Posts: 390 Location: Michigan
Posted: Fri May 20, 2011 4:53 am Post subject: |
I would buy it as is for my wife. She would love it. |
Posted: Fri May 20, 2011 5:13 am Post subject: |
Okay... its Pink and painted with a Hello Kitty theme, I should have titled this post, Mexican Beetle Resto-Mod to get some of the techys to look at it. Since everyone likes it so much it makes me think I should reconsider the build plan, screw that, she'll not be pink for long.
Does anyone have any comments or ideas on the below?
Quote: |
MJKBugsandbuggies Posted: Yesterday 8:44 pm Post subject:
Thanks in advance for your advice. |
priss Samba Member
Posted: Fri May 20, 2011 5:23 am Post subject: |
I think starting a seperate thread with a differant title for the tech questions is a good idea. I have noticed people get better replies to new questions when there is a new thead about the specific issue. Once someone opens this thread once they are not going to return if it didnt interest them in the first place.
new questions, new thread, new eyes looking at it, better replies. _________________ I live in a state where all citizens are required to provide proof of insurance, but no person need provide proof of citizenship. |
gore666 Samba Member
Joined: September 14, 2010 Posts: 533 Location: casper wyoming
Posted: Fri May 20, 2011 7:35 am Post subject: |
wow good find lol. i tried to buy a bug that had the fenders takin off but looked like everything else was still there from a pick a part and they said there was no way in hell i could buy the hole car.
at the time i had no knowledge of beetles it could have been 62 or a 75 lol |
don.ville  Samba YardMan
Joined: February 07, 2008 Posts: 2915 Location: West Palm Beach, FL
cookrw Samba Member
Posted: Tue Mar 13, 2012 3:28 pm Post subject: |
I'm jealous! It is essentially brand new, and plus it's HELLO KITTY!!! _________________ '71 Super 'Vert
'96 Jeep Cherokee |
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
cookrw Samba Member
Posted: Tue Mar 13, 2012 6:07 pm Post subject: |
Beetlebaum wrote: |
Where did the hood go? |
It looks like it's in the truckbed? _________________ '71 Super 'Vert
'96 Jeep Cherokee |
