miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Earlybay Samba Member
Joined: June 15, 2007 Posts: 119 Location: United Kingdom
Posted: Wed May 26, 2010 6:37 am Post subject: |
mine being broken in.
piece of piss to setup and fired up first turn. _________________ |©¯¯©| & (Ө\ ! /Ө)
I'm on a whiskey diet!.... I've lost 3 days already - Tommy Cooper |
vwjim Samba Member
Joined: November 14, 2003 Posts: 135 Location: Hampshire, UK
Posted: Thu May 27, 2010 2:11 pm Post subject: |
Pat D wrote: |
74 Thing wrote: |
Pat,
Any plans to have a crank fire trigger to go along with your quicktune system so you will eliminate the distributor all together and the possible potential of timing scatter from play in the distributor/drive etc.. ? |
Yes, We are working on a stand alone coil on plug crank trigger kit at the moment. This system will be available some time near the end of the year. |
Hi Pat,
When this new crank trigger system is ready, are you planning on it being compatible with the current Quicktune ECU?
Thanks |
Pat D Samba Member
Posted: Fri May 28, 2010 7:50 am Post subject: |
vwjim wrote: |
Pat D wrote: |
74 Thing wrote: |
Pat,
Hi Pat,
Thanks |
The ignition is not crank triggered, it is a distributor with built in electronics and map sensor. You can program your own timing map and down load it to the distributor. The distributor also has a built in high end rev limmiter and 2-step rev limmiter. We will be coming out towards the end of the year/ early next year with a coil on plug crank trigger kit that will work with our EFI. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Fri May 28, 2010 7:53 am Post subject: |
Pat D wrote: |
We will be coming out next year with a coil on plug crank trigger kit that will work with our EFI. |
Pat, this interests me very much... I bought a quicktune early on in the release, will it be able to be updated to work with future doo-dads? (crossing my fingers!!) _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Fri May 28, 2010 9:26 am Post subject: |
Why wait, Ed and myself and converting his car right now. It's not hard to do, just think about it for a minute... _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
vwjim Samba Member
Posted: Thu Jun 10, 2010 5:11 am Post subject: |
Pat D wrote: |
vwjim wrote: |
Pat D wrote: |
74 Thing wrote: |
Pat,
Hi Pat,
Thanks |
Cool, that's what I meant. Look forward to seeing it. |
vwjim Samba Member
Posted: Thu Jun 10, 2010 5:21 am Post subject: |
Which type / heat range spark plug (long reach) is recommended for this system? Also, what spark plug gap works best on a non-turbo application?
Or does it not matter? Instructions only mention plug wires must be suppression type. Just wanted to check about the plug choice.
Thanks. |
auro Samba Member
Posted: Sat Jun 12, 2010 3:46 pm Post subject: |
Hi Pat,
does the EFI software work under MAC osx with the parallel-desktop+winXP installed inside ? I`m allergic to Bill Gates !
BTW, if I have a brand new engine, can I use the EFI to fire it up the 1st time for the 30 mins break in ?
I just finished a 1776 for my SB and I`m considering one of your kits+EFI for my bus.
Thanks
Stefano |
scourtaud Samba Member
Joined: October 15, 2009 Posts: 46 Location: Geneve, Switzerland
Posted: Sat Jun 12, 2010 4:21 pm Post subject: |
auro wrote: |
Hi Pat,
Thanks
Stefano |
Hi,
I can't answer for the break in of your engine but as for the apple part, I'm using a Macbook Pro 13" with VMware Fusion + win XP Pro and it works great.
The picture was taken under windows 7 but its just too slow... Switched to XP, its much faster now.
I would not recommend it on a macbook air since the lack of power would probably be an issue with realtime monitoring of the EFI.
Seb |
auro Samba Member
Posted: Sat Jun 12, 2010 4:34 pm Post subject: |
Hi Seb, awesome. I`ve a macbookpro 15. But I can take one of my old windows laptops, although I would prefer not.
stefano |
Posted: Sat Jun 12, 2010 4:50 pm Post subject: |
Hi,
You don't need to take out a dreadfull windows machine, just set up VMware fusion and windows XP and be on your way... The plus side being that you can enjoy the battery life...
Just think to switch of energy saving on the screen or it will turn black every 2 min... Which is annoying...
Seb |
Posted: Tue Jun 15, 2010 2:02 am Post subject: |
auro wrote: |
Hi Pat,
Thanks
Stefano |
i have it running in Snow leopard 10.6 using 'Parallels'. I havent tried Bootcamp as its antiquated in comparison. Also have it running on VMware on a yellow dog linux so does ok on that platform.
Personally i wouldnt use my good macbook as its going to be lying in the van or in the garage  _________________ |©¯¯©| & (Ө\ ! /Ө)
orb666 Samba Member
Joined: December 21, 2005 Posts: 55 Location: New Malden UK
Posted: Tue Nov 23, 2010 5:38 am Post subject: |
Does anyone know if they plan to make the software iPad compatable?
I'd love to be able to mount the iPad on the dash to monitor head temps, a/f ratio etc - much easier than having a laptop rolling around on the seat.
Orb |
scs2003 Samba Member
Posted: Sat Jul 09, 2011 2:03 am Post subject: cb performance quick tune efi |
Hi all can anyone help
i bought a cb performance quick tune efi kit and fitted it my 2276 type4 engine. the problem i am having since i dont know much about efi tuning is that it is runing to rich and the fumes leaved you teary eyed, when ever i try to increase throttle it stalls. Here are some figures from the setup.
CE% 0
TPS 0
BPW 1.4
INJPW 1.61
ZONE 33
ZLF 15
CL% 0
A/F TGT 20
IACP 58
IACT 57
VOLT 11.9
CLEN 17
HEAD TEMP 176
VACCUM -6
A/F 15.3
FP 45.9
i dont know what to change to bring down the zone down that i think is way to high or anything else that would help. or
can any one suggest anything would greatly appreciate
Fatin |
Posted: Sat Jul 09, 2011 8:04 am Post subject: |
Your injector PW figures are meaningless without knowing the injector size... _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Mon Jul 11, 2011 6:18 am Post subject: |
if it helps here are the specs
Quicktune efi kit with 52lb injectors, 2 bar map sensor, , 52lb T04 profile, SP ignition input |
Posted: Mon Jul 11, 2011 9:59 am Post subject: |
52lb are huge injectors, get something smaller. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Mon Jul 11, 2011 2:12 pm Post subject: |
I am running 51 lb injectors and idle just fine. I think he should be fine with 52's. If he's a turbo motor going for over 200 hp, he'll need them. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Posted: Mon Jul 11, 2011 8:50 pm Post subject: |
miniman82 wrote: |
52lb are huge injectors, get something smaller. |
I believe CB supplied 63lb injectors for my turbo/EFI.... it's what Pat decided was necessary... _________________
