Minimum working sensors?
Steve46038
Steve46038 is offline
PostPosted: Tue Jul 19, 2011 4:24 pm    Post subject: Minimum working sensors? Reply with quote
78 that PO converted to a carburetor.
Since there are no smog tests here and I don't have FI anymore, what sensors do I need for my rebuild?
Oil pressure, voltage, oil temp mechanical, fuel level...is that it?
No O2, EGR, nothing like that, right?
Any common add-ons?
Anything useful for monitoring proper carb performance?
I hope to go back to fuel injection someday, but first step is to get her running!
Thanks in advance!
Steve
1978 Westy
1997 Jeep Cherokee 4x4
2008 Infiniti G37S 6MT
Steve46038
PostPosted: Tue Jul 19, 2011 4:27 pm    Post subject: Reply with quote
Oh yeah, what is the red or green light that blinks occasionally that I read about? It has something to do with the health of the engine I recall. Do I need that sender?
1978 Westy
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jul 19, 2011 4:28 pm    Post subject: Reply with quote
just keep the green and pink lights Smile
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
RatCamper
RatCamper is offline
PostPosted: Tue Jul 19, 2011 5:02 pm    Post subject: Reply with quote
Pink?
I know there's:
indicators = green
High beam = blue
Alternator = red
Oil pressure = red
Dual circuit brake failure = ...I've heard they were red but mine is yellow now.
Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002.
Steve46038
PostPosted: Tue Jul 19, 2011 5:27 pm    Post subject: Reply with quote
LOL...Pink lights are on my short list of dream mods.
In the mean time, I think the light I remembered reading about had to have been the oil pressure. Further, it looks like CAT and EGR weren't even hooked up to anything on Canadian models. If Canadians are not worried about it, it must be for CA emissions, therefore, not an immediate concern.
Back on track, did I cover the required sensors?
1978 Westy
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Jul 19, 2011 5:42 pm    Post subject: Reply with quote
There is no oil temp mechanical sensor.
Steve46038
PostPosted: Tue Jul 19, 2011 5:49 pm    Post subject: Reply with quote
Thermostat I mean.
1978 Westy
old DKP driver
old DKP driver is offline
PostPosted: Tue Jul 19, 2011 7:55 pm    Post subject: lights Reply with quote
You do need and should have a thermostat
EGR counter box was connected to the speedo cable under the driver side kick panel
V.W.owner since 1967
SGKent is offline
PostPosted: Tue Jul 19, 2011 8:00 pm    Post subject: Reply with quote
I meant green and fuchia lights. Smile If you don't have those look for the one that looks like a whale o' tale.
You need all your factory lights that came with your year. Look it up here:
http://www.thesamba.com/vw/archives/manuals/type2.php
George Carlin:
1971 deluxe (sold)
1977 deluxe
Steve46038
PostPosted: Tue Jul 19, 2011 8:43 pm    Post subject: Reply with quote
Do I need the egr connector connected when just running a carb?
1978 Westy
SGKent is offline
PostPosted: Tue Jul 19, 2011 8:53 pm    Post subject: Reply with quote
you only need EGR if you are running stock smog. It had a sole purpose which was to remind the user that they needed to take it in to check the EGR valve and filter for operation.
George Carlin:
1971 deluxe (sold)
1977 deluxe
old DKP driver
PostPosted: Tue Jul 19, 2011 9:18 pm    Post subject: egr box Reply with quote
The EGR counter box has the cable that goes to the front Driver side wheel. the other end of the cable from the counter box then goes to the speedometer head.
So does your speedometer work?
you can use the egr light as a service indicator since it turns the light on @ 15k and 30k intervals
if you remove the box you must then install a longer cable from a 1972-1974 type2. Wink
