qbini Samba Member
Joined: October 01, 2009 Posts: 45 Location: Pacifica, CA
Posted: Tue Jun 14, 2011 10:36 am Post subject: |
| kevinm wrote: |
qbini, did you have any fitment problems with the Rheins on the G60s? I've heard some light grinding may be required. Did you have to do this?
- Kevin |
My rheins did rub on the G60s a bit. I choose to use a T3 Tech 5mm spacer to offset rather then grind - i really didn't like the idea of grinding brake components. The hub-centric spacers are fantastic... they just slip on and the rub went away. The rheins have an offset of ET30, so the 5mm spacer brings them to an offset of 25 - still within original tolerances to not mess up your steering geometry. I did need to buy longer lug bolts to compensate for the additional thickness. |
pyite20v Samba Member
Joined: June 13, 2010 Posts: 29 Location: San Francisco, CA
Posted: Tue Jul 19, 2011 6:04 pm Post subject: does the VC / Eurospec kit for the 2wd come with syncro hubs |
It looks like it comes with a different hub set up, is this the case? I am asking because I am trying to find wheels that will fit the VC kit, an I found a set of syncro wheels, wondering if once I have the kit installed if I only have to clearance my wheel to syncro specs or if I still have to bore out the fronts for 2wd?
Thanks |
Ryan Keating Samba Member
Posted: Wed Jul 20, 2011 6:30 am Post subject: |
| I went with a set of 16in mercedes wheels. Check out the ultimate wheel post. Then www.t3technique.com will get you all the lugs and studs to set it up. Plus powerflex bushings. |
Posted: Wed Jul 20, 2011 7:50 am Post subject: |
| Getting the right size wheels, I am wondering if offset changes, an if my hub center / dust cap changes so I dont have to clearance the centerbore on my 17" audi rims as much |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Wed Jul 20, 2011 11:36 am Post subject: |
| pyite20v wrote: |
The Van Cafe/Eurospec kit makes the wheel mounting surface sit 1.5mm further inboard compared to the stock brakes.
To the best of my knowledge, the Small Car kit makes the wheels sit 7.2mm further outboard compared to the stock brakes.
In other words, with the VC/Eurospec kit, you don't have much to be concerned with unless you are already running really tight clearances. The Small Car kit would be the same as running a 7.2mm spacer on top of the stock brakes, so that would have to be taken into account when figuring wheel offsets. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Jul 20, 2011 1:35 pm Post subject: |
| loogy wrote: |
| pyite20v wrote: |
In other words, with the VC/Eurospec kit, you don't have much to be concerned with unless you are already running really tight clearances. The Small Car kit would be the same as running a 7.2mm spacer on top of the stock brakes, so that would have to be taken into account when figuring wheel offsets. |
Hey Chris, are talking about the SA brakes from Van Cafe or the Audi brakes? _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Wed Jul 20, 2011 2:05 pm Post subject: |
| Jake de Villiers wrote: |
Hey Chris, are talking about the SA brakes from Van Cafe or the Audi brakes? |
The Audi-based, Eurospec sourced kit, not the OE VW SA kit. I have never seen one of the OE VW SA kits in person, so I don't know if there any offset change or not. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Jul 20, 2011 3:25 pm Post subject: |
| loogy wrote: |
The Audi-based, Eurospec sourced kit, not the OE VW SA kit. I have never seen one of the OE VW SA kits in person, so I don't know if there any offset change or not. |
I just wanted to be clear - thanks!  _________________ '84 Vanagon GL 1.9 WBX
Posted: Wed Jul 20, 2011 4:23 pm Post subject: |
And I appreciate that! Sometimes it's easy to get in a rush and forget some details. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Jon_slider Samba Member
Posted: Wed Jul 20, 2011 6:16 pm Post subject: |
I have VC front brakes, from over 4 years ago.
I've used Mefro 16x6 ET 30, Rhein 15x6.5 ET 30, and CLK 16x7 ET 37, they all fit without any front big brake interference on my syncro, with no spacer. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3168 Location: Vancouver Island, B.C.
stclair411 Samba Member
Joined: July 12, 2009 Posts: 222 Location: working on it
Posted: Wed Jul 20, 2011 6:47 pm Post subject: |
| photogdave wrote: |
Can I ask a real simple question here? If there was already a straight answer to this I missed it.
I have the Van Cafe 15" steel wheels. Can I use the Small Car big brake kit or not?
Thanks! |
I asked SmallCar, and they said no. I went with the VC kit, and also have 15" Mefro wheels. Anyone out there running this combo? Pictures? Thanks! _________________ 1987 Syncro Westy "June" |
Posted: Wed Jul 20, 2011 7:41 pm Post subject: |
| stclair411 wrote: |
| photogdave wrote: |
Thanks! |
I asked SmallCar, and they said no. I went with the VC kit, and also have 15" Mefro wheels. Anyone out there running this combo? Pictures? Thanks! |
Thanks! I was going to get the VC brakes when I was down there but I ran out of $$, so I was hoping the SC kit would work.
Guess it will have to wait awhile. _________________ 89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
Posted: Tue Jul 26, 2011 7:37 pm Post subject: |
Having a real hard time getting the VC kit to work with my 15x6 Mefros. Going back to stock for now so I can get back on the road. Can anyone recommend a kit that works well with these wheels with no modifications? Thanks! _________________ 1987 Syncro Westy "June" |
NorthbyNorthWesty Samba Member
Posted: Tue Jul 09, 2013 6:42 pm Post subject: Brakes for 17" tires |
| We have a syncro with 17" tires and want bigger brakes. Anything we need to consider when comparing? |
Posted: Tue Jul 09, 2013 8:14 pm Post subject: |
| stclair411 wrote: |
| Having a real hard time getting the VC kit to work with my 15x6 Mefros. Going back to stock for now so I can get back on the road. Can anyone recommend a kit that works well with these wheels with no modifications? Thanks! |
Are you working with the later Audi-based kit or the South African brakes? According to Van cafe, the Audi brakes fit the Mefro wheels fine.
I know they fit inside 15" Mercedes wheels, my 15" spare clears just fine. _________________ '84 Vanagon GL 1.9 WBX
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4624 Location: East Kootenay, British Columbia
Posted: Sun Aug 04, 2013 3:39 pm Post subject: |
Hi everyone who has VC Big Brakes.
What did you do about the hose support where the flex line meets the hard line at the caliper? _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
insyncro Banned
Posted: Sun Aug 04, 2013 4:13 pm Post subject: |
| MsTaboo wrote: |
What did you do about the hose support where the flex line meets the hard line at the caliper? |
I fabricate a mount.
GW uses zip ties. |
Posted: Sun Aug 04, 2013 4:28 pm Post subject: |
| insyncro wrote: |
| MsTaboo wrote: |
GW uses zip ties. |
Yep, kinda what I figured. Zip ties just don't seem good enough.
I've got the knowhow, but not the equipment, to fab up something nice looking. Guess I'll have to do what I can with a bench vise, pliers, and a drill.
Insyncro- any photos of your mounts for inspiration? _________________ Currently:
