1974 westfalia first car rebuild
Page: 1, 2, 3  Next
Isaacbmxer
Isaacbmxer is offline
PostPosted: Fri Jul 22, 2011 6:14 pm    Post subject: 1974 westfalia first car rebuild Reply with quote
hi im isaac. Im from roseville california im 15.
This is my first car and it is a 1974 orange westfalia
It is from the california gold country and sat there since 1992. It was brought in as scrap to my dads scrap yard. After 15 min of work and new spark plugs we drove it around. It has no rust except for the battery tray.
The inside was striped of the camping gear but had all the seats. There was a full carpet set for the front and back too. After we cleaning it and puting 17 inch eclipse wheels on (i kept the originals) it looked brand new
I wraped the complete panel set from bus depot and used air duct arm rests from scrap part busses at the yard.I put wood on the floor for vinyl flooring
after i put the floor in
Then we took it to kombi haus in sac they went throough it and fixed a lot of the more complicated electrical stuff
and here is where i am now
ill keep updating to show my progress
Wildthings
Wildthings is offline
PostPosted: Fri Jul 22, 2011 6:19 pm    Post subject: Reply with quote
Cool to see another bus saved. Very Happy
MalibuLX3
MalibuLX3 is offline
PostPosted: Fri Jul 22, 2011 6:38 pm    Post subject: Reply with quote
I'll be the first to say it. Check your tires, if they came on the Eclipse wheels, they are passenger tires and not suitable for your bus. Also, change your fuel lines before anything else. You can buy a complete fuel line kit from German Supply that includes everything you need, from the correct diameter and pressure rated fuel line, to the correct style clamps, to the fuel filter, and everything is pre-cut and the correct length to make it very simply.
Now that I've got that out of the way...how did you get those wheels to fit? Adapters?
Great looking bus, I know it would buff out and shine like new! Check out VDubTech's posts for what he uses to buff out his buses to make them shine!
1978 Westfalia
Isaacbmxer
PostPosted: Fri Jul 22, 2011 6:54 pm    Post subject: Reply with quote
I have changed all of that out already and the tires have held up fine for the past two or three months I've had them on and the wheels fit on no adapter just had to make room for the skrews on the rear drums
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Fri Jul 22, 2011 8:45 pm    Post subject: Reply with quote
Spectacular! You are one lucky 15 year old. So, am I safe to assume that the bus was free? Very nice indeed. You gotta LOVE that orange.
"I will gladly pay you Tuesday for a hamburger today."
BUSBOSS
BUSBOSS is offline
PostPosted: Fri Jul 22, 2011 9:50 pm    Post subject: Reply with quote
Very nice find! I like that you've kept what you found as original intact. Rare for a 15 year old!
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
bugger101
bugger101 is offline
PostPosted: Sat Jul 23, 2011 7:40 am    Post subject: Reply with quote
those tires are not meant for the weight of the bus they are fine now. But the sidewalls cannot take that much abuse and will blow out around a corner or possibly on the highway.
75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
Wildthings
PostPosted: Sat Jul 23, 2011 11:01 am    Post subject: Reply with quote
Since he hasn't given spec on the tires, how do you guys know they aren't rated properly? From the survey of Vanagons and Bays I did, it appears that over half of them run on passenger tires just fine. Mostly its only in the netherworld of the internet that passenger tires seem to give problems.
Westfabulous
PostPosted: Sat Jul 23, 2011 11:11 am    Post subject: Reply with quote
X2. Truer words were never spoken.
Same with AMC heads. They certainly aren't the best, but they don't perform nearly as poorly as all the rumor and innuendo would suggest. Maintenance is everything, and these are a viable option for those who can't afford better.
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Sun Jul 24, 2011 3:35 am    Post subject: Reply with quote
It sucks that every thread is a broken record here. It's always "you have the wrong tires, change your fuel lines, buy a Bentley".
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
Zelten
Zelten is offline
PostPosted: Sun Jul 24, 2011 4:23 am    Post subject: Reply with quote
Did you search? That has been said before.
Nice bus!
1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI
notchboy
notchboy is offline
PostPosted: Sun Jul 24, 2011 6:00 am    Post subject: Reply with quote
I just put a repop new Chinese oil cooler on my 1800. I cant wait for it to fail Laughing
Come on the raggin aint that bad. For the ammount of repetitive traffic this forum sees, just be thankful people do repeat some of the basics over and over. Otherwise no one would know better Wink
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
MalibuLX3
PostPosted: Sun Jul 24, 2011 10:03 am    Post subject: Reply with quote
Would you rather it not be said and instead read about a beautiful bus burning to the ground because someone didn't think fuel lines needed to be changed every 5 years...
1978 Westfalia
Isaacbmxer
PostPosted: Sun Jul 24, 2011 1:31 pm    Post subject: Reply with quote
The tires are rated up to 1 ton
Isaacbmxer
PostPosted: Sun Jul 24, 2011 1:32 pm    Post subject: Reply with quote
Desertbusman
Desertbusman is offline
PostPosted: Sun Jul 24, 2011 5:11 pm    Post subject: Reply with quote
Wow, that's wonderful.
So just for fun, give us the details in case we want to get some for ourselves. Tell us, brand, model, size, load range, max. pressure, max. load, ply ratings, and anything else of interest.
71 Superbug
71 Westy
Isaacbmxer
PostPosted: Sun Jul 24, 2011 8:45 pm    Post subject: Reply with quote
this weekend i repainted my pop top
at the start
after the cargo was done
after the main part was finished
after finishing it with new stickers
My first car 1974 westy http://www.thesamba.com/vw/forum/viewtopic.php?t=473768
[url=http://www.vw-mplate.com/mplate-8076.png]Click to view image[/URL]
Westfabulous
PostPosted: Sun Jul 24, 2011 9:12 pm    Post subject: Reply with quote
You are doing a great job, and should be very proud of your bus, and your work. Keep it up young fellar.
guanella74
guanella74 is offline
PostPosted: Sun Jul 24, 2011 9:32 pm    Post subject: Reply with quote
Gotta say, I'm a bit jealous! I've got an identical bus, but yours is looking wayyyyy better than mine! What a score.
ROLL that thang!!!
Can't beat the orange plaid - it's a source of secret power, which I'm sure you'll discover soon.
- Travis
1974 Westy CampMobile - the OG!
1979 Transporter
1979 Transporter
1977 Transporter
1974 Transporter
1973 Transporter
1971 Westy
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Mon Jul 25, 2011 7:07 am    Post subject: Reply with quote
Nice bus!
Laughing Laughing
Quite an impressive thread here, dude. Great job!
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
Page: 1, 2, 3  Next
