Q: Nexen CP521 ???
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Aug 11, 2011 11:47 am    Post subject: Q: Nexen CP521 ??? Reply with quote
Anybody know about these tires?
In my quest for inexpensive tires, I came across the Nexen CP521. In a 215/65R16 102T it costs $73 in California via tirecrawler.com as of August 2011.
dhaavers
dhaavers is offline
PostPosted: Thu Aug 11, 2011 12:21 pm    Post subject: Reply with quote
Looks OK, but I assume it's a passenger car tire. Even so, (de-rated 9%) they look adequate at about 1680 lb. capacity.
Didn't see a spec for max pressure on the website. I'd feel better if we knew it's rated for over 50 psi...
Also: how tall? Find out & do the math so you'll know ahead of time about any negative effect on the "power-to-the-pavement" quotient.
Nice price, though!
"The WonderVan"
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Aug 11, 2011 12:43 pm    Post subject: Reply with quote
It is an XL tire so it is not derated. They classify the tire as an SUV tire rated to 50 psi. See:
http://int.nexentire.com/product/prod_view.asp?prod_id=P22
dhaavers
dhaavers is offline
PostPosted: Thu Aug 11, 2011 1:05 pm    Post subject: Reply with quote
In that case, looks really good! Go for it...
(Note to self: now must find some $73 16" rims...)
Probably have a better ride than what I'm running... Wink
"The WonderVan"
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Aug 11, 2011 1:15 pm    Post subject: Reply with quote
XLs are still passenger tires, so don't expect nice stiff sidewalls.
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Aug 11, 2011 2:10 pm    Post subject: Reply with quote
So do you consider an SUV tire in the same class as a Passenger tire, then?
I do not know what to expect, but with a 102 load rating you hope the sidewalls do not give out (crack?) from the loading.
Randy in Maine
PostPosted: Thu Aug 11, 2011 5:14 pm    Post subject: Reply with quote
I think they are still rated as a passenger tire, although a pretty beefy one. No "P" but no "LT" either. Arrow
Let us know what you think of them.
r39o
Samba Polizei
r39o is offline
PostPosted: Sat Aug 13, 2011 5:00 pm    Post subject: Reply with quote
I googled and did not come up with a great definition but did find something at tirerack:
tirerack wrote:
A SUV/truck tire is more ruggedly constructed in both sidewall and tread base than the typical car tire
http://blog.tirerack.com/blog/tire-sidewall
Randy in Maine
PostPosted: Sun Aug 14, 2011 5:54 am    Post subject: Reply with quote
Give it a shot and report back.
Lotek
Lotek is offline
PostPosted: Sun Aug 14, 2011 6:38 am    Post subject: Reply with quote
I'm rolling on some Nexen 14" tires that I bought under duress when I was driving back from purchasing my van in another state.
I hadn't planned on buying tires and they were not the brand I would have chosen, furthermore, I paid way too much.
That said, I have to admit that the Nexens are firm, wear like iron, and have been trouble free.
If I ever wear out my current set I'd try some CP521s on the CLK rims sitting in my garage.
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Aug 15, 2011 11:55 am    Post subject: Reply with quote
EXACTLY my situation!
r39o
Samba Polizei
r39o is offline
PostPosted: Wed Aug 17, 2011 12:28 pm    Post subject: Reply with quote
So anybody got any more ideas about these tires?
I have new 14 inch Hankooks on right now with factory alloys and am happy enough. But, I have stock brakes still and, well, I would feel better putting bigger brakes on with my new found need for speed with my Subaru.
a914622
a914622 is offline
PostPosted: Wed Aug 17, 2011 5:57 pm    Post subject: Reply with quote
The roadian - at has a 225-65-16 with a load ratig 106!! I have no idea how they would wear but the load rating looks right.
My 17s only have a 99 load rating and are ok for a tin top.
Good find!!
jcl
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
70coupyel
70coupyel is offline
PostPosted: Wed Aug 17, 2011 7:06 pm    Post subject: Reply with quote
Ok I went to the Nexen web site.
http://www.nexentireusa.com/tireoverview19-2/SUVLightTruck
There are 8 different Roadian tires. I could not find that size in any Roadian tire. Embarassed Sad Got linky??
P.S. That tire size is not even listed in that size in the size pull down menu.
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Nov 05, 2011 11:47 am    Post subject: Re: Q: Nexen CP521 ??? Reply with quote
Thanks for sharing this tire option. I recently bought 5 for $73 each plus tax, free shipping to a tire store not too far out of my way.
I installed them on an 87 2wd using Mercedes type steel 16" x 7" ET37. Everything clears fine. I was able to mount the spare under the van using the VanCafe oversize spare carrier plus a little bending down of the hinges.
The tires are Load 102, max 50 psi, 1874 lbs, Extra Load. I liked them right away and even more so during the recent rains. Previously I had Load D 195R14 "slicks" that were ok when fairly new but not for very long. Too slick in the wet, even with decent tread depth left.
No, I don't know where to get more of the rims I used. I wish.
It looks like this tire model may be dropped from the Nexen line soon if not already.
Mark
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Nov 05, 2011 2:29 pm    Post subject: Reply with quote
I like the tread pattern - a good combination of drainage and tread shapes. Looks like it would be stable on the road - something the Vans need IMHO.
DougM
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Nov 10, 2011 11:34 am    Post subject: Re: Q: Nexen CP521 ??? Reply with quote
Welcome
Me too
Closest drop I could figure out was in Mission Viejo. That is not "that" close to San Diego. It would be an hour drive each way for me to go to their drop point. All they seem to have listed is Alan Tire stores.
Where did you go?
What is the Merecedes part number on them?
Why?
They ARE hard to locate on the website. Under truck tires, I think, if I recall.
The CP621 seems quicker to find, but is underrated for the vans, I think.
So what do you base the availability issue on?
crazyvwvanman
PostPosted: Fri Nov 11, 2011 6:22 pm    Post subject: Re: Q: Nexen CP521 ??? Reply with quote
My rims are aftermarket Mercedes type, so no Mercedes part numbers on them.
I could not find listed them on the Nexen USA website. Various Nexen dealers I looked at did not show them either.
http://www.nexentireusa.com/tires/
Mark
Why?
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Nov 11, 2011 11:24 pm    Post subject: Re: Q: Nexen CP521 ??? Reply with quote
Under SUV tires:
What is even more interesting is that they have lots of tires with high load rating including a few 205/70-14 tires that may be worth looking into for those wishing to stick with the original 14 inchers....not that they will find this reference easily. Plus they have other tires in 215/65-16 but the CP521 is the only one I noticed with XL rating too. They may have more.....We'll see how this experiment plays out first....
crazyvwvanman
PostPosted: Sat Nov 12, 2011 7:39 am    Post subject: Re: Q: Nexen CP521 ??? Reply with quote
Yes, their international site has the CP521 as well as some other interesting tires but with these tires missing from the USA site it is hard to assume much lasting availability here. I hope I am wrong about that. About 6 months ago I put some Nexen XL tires on my wife's BMW wagon and am happy with those so trying Nexens on a van was an easy step.
Mark
Under SUV tires:
