Joined: April 27, 2002 Posts: 6828 Location: Pentwater, Michigan
Posted: Sun Mar 27, 2011 7:03 pm Post subject: "VW" brand parts were actually made by Garbe Lahme |
I've seen it time and again and yet again. So maybe its time to share what I know and set the record straight. The following parts are frequently referred to as made by "VW" They were actually made by a firm: Garbe Lahmeyer that has been around almost as long as Bosch. Here is an interesting link to more information on G.L. Gmbh.
http://www.thesamba.com/vw/forum/viewtopic.php?t=382556&highlight=garbe+lahmeyer
The most popular opionion is that GL (Garbe Lahmeyer) filled in for Bosch in the mid sixties supplying parts for VW during a labor dispute. There are however various references in Progressive Refinements stating that GL was used in limited numbers as early as 1956 or so.
Below are some exanples of GL products that I have found:
The GL coil has an aluminum jacket and is a tad wider than the Bosch coils. The bracket is unusual and sought after because it has a VW logo and part number emblazend upon it.
The coil is 6v and has the GL logo on the bakelite.
Next is the GL distributor. It is interesting to note that the distributor has 211 part numbers all over it. It is generally agreed that this distributor was not used exclusively on the bus. It was common to find them on beetles too. The cap and rotor fit the flat top 383 distributors but they are not correct parts for that era.
The distributor is distinguishable by the bulbous protrusion at the base of the vacuum can pipe. It is a cast iron distributor which leads people to think it is older than it really is. I have seen one example of a mechnical advance GL distributor.
The voltage regulator is also quite sought after because of the VW logo found clearly stamped on the top of an unpainted aluminum lid. The regulator is rated at 180 amps and 6 volts.
The final GL product is a self supporting 12 volt starter motor. There is an interesting ground strap running from the solenoid to the motor and the bushing to support the shaft is installed on the shaft rather than in the transmission housing.
_________________ Roads Scholar
Member# 2059 |
Posted: Sun Mar 27, 2011 7:13 pm Post subject: |
I suspect that there are examples of 6 volt starters out there and I am also suspicious that there are generators hiding in barns and garages that are made by GL but I have none to share. GL specialized in generator manufacturing and if Bosch was on strike I would think that generators needed to be supplied too.
If you have something to add to this little mini lesson by all means attach it  _________________ Roads Scholar
Member# 2059 |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36103 Location: Conejo Valley, CA
Posted: Sun Mar 27, 2011 8:04 pm Post subject: |
All true and fascinating. But keep in mind that all parts the factory used were stamped or cast as "made by VW" even though they were from authorized suppliers... Bosch, Hella, SWF, Sekurit, etc. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Mon Mar 28, 2011 4:04 am Post subject: Re: "VW" brand parts were actually made by Garbe L |
tasb wrote: |
if true this starter is "self supporting",then why does the trans need a bushing on starter shaft or in trans ???? it is not being supported by itself.  _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Sat Aug 20, 2011 4:19 pm Post subject: |
Good point, I was just restating what the last owner claimed. So not self supporting in this case?
Here are a couple of pics of the non vacuum or mechnical advance distributor that Garbe Lahmeyer produced. The J likely came after the earlier vacuum versions but I am not sure yet what the advance curve looks like. I have been rebuilding distributors for a few years now and I have only seen two of these.
This is the GL generator that I suspected existed. It appears very similar to the Bosch counterpart. There are likely many more lurking about that are assumed to be Bosch. Note the VW symbol lower left and the GL symbol upper center in the bottom pic.
sorry for the blurry image it's the best I could get with the camera. _________________ Roads Scholar
Member# 2059
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sat Aug 20, 2011 6:44 pm Post subject: |
Chevrolet doesn't make cars either. They "build" cars. They simply take parts that come from hundreds or thousands of suppliers and screw them together to build a car.
Each component comes from some other manufacturer.
So it's no surprise that VW had other companies making parts for them.
It's easy to see when it's bosch labeled ignition parts, or hella labeled lights. But most of the other parts marked VW actually came from other suppliers too. _________________ Mother Nature is a Mean Evil Bitch! |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sat Aug 20, 2011 7:11 pm Post subject: |
Yes,but their outsource rates were low,when designing Wolfsburg they spent time studying and copying Ford's Rouge complex, which is about as close as you could get to 'vertical integration'(all parts manufactured in house). |
Posted: Sat Aug 20, 2011 8:57 pm Post subject: |
All true. I guess I started the thread because so many call these parts VW made because of the often unusualy prominant VW logo when in reality they were made by some other firm. The GL logo is there it's just not recognized or understood. _________________ Roads Scholar
Member# 2059 |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17634 Location: Left coast, Canada
Posted: Sat Aug 20, 2011 11:12 pm Post subject: |
KTPhil wrote: |
all parts the factory used were stamped or cast as "made by VW" |
Not "made by VW", instead, they only had the VW logo. The presence of the logo doesn't mean "made by VW". _________________
KTPhil  Samba Member
Posted: Sat Aug 20, 2011 11:17 pm Post subject: |
That's my point! All those parts with the VW logo and part numbers were not necessarily manufactured by VW itself; in most cases they were approved subcontractors. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26139 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 21, 2011 4:05 pm Post subject: Re: "VW" brand parts were actually made by Garbe L |
bill may wrote: |
if true this starter is "self supporting",then why does the trans need a bushing on starter shaft or in trans ???? it is not being supported by itself.  |
Have a few of these starters and they are self supporting 6 volt units.
The "Damage Numbers" dealer manual for 1966 is a great resource for more info on manufactures that produced parts for VW. _________________ In Stereo, Where Available! |
Posted: Fri Sep 16, 2011 7:01 pm Post subject: |
Here is an interesting Garbe-Lahmeyer item:
This is a mechanical advance distributor manufactured by GL in December 1955. that should end the "VW used them in the mid 60's" assertions.
Interesting features include the badge which is gold in color. The cap clips which are a true spring with no hinge. The end of the spring sits in a small hole in the housing. The lack of a spring clip to hold the drive dog pin in place. It used the same cap, points and rotor throughout production. The condenser has changed periodicaly being mounted in different locations on the housing. _________________ Roads Scholar
Member# 2059 |
pupjoint Samba Member
Posted: Sun Nov 13, 2011 10:28 pm Post subject: Re: "VW" brand parts were actually made by Garbe L |
tasb wrote: |
tasb, what number is this distributor? |
Posted: Mon Nov 14, 2011 5:49 am Post subject: Re: "VW" brand parts were actually made by Garbe L |
Eric&Barb wrote: |
bill may wrote: |
The "Damage Numbers" dealer manual for 1966 is a great resource for more info on manufactures that produced parts for VW. |
i know it is a 6volt self supporting starter. my answer was given when poster asked about bushing. lots of guys would like to have a 6 volt self supporting starter. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 361 Location: Green Bay, WI
Posted: Sun Jul 15, 2012 10:17 am Post subject: Re: "VW" brand parts were actually made by Garbe L |
tasb wrote: |
How much is this coil worth? Couldn't find any for sale in the classifieds. One came on a used 40hp I picked up to stick in my '64 Beetle, but the car has already been converted to 12v. I was thinking about swapping over the bracket to a 12v coil. But if the coil and bracket are a matched set, I might be better off saving it for another project. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT
VeeDubability on YouTube |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3448 Location: Calgary, Canada
Posted: Sun Jul 15, 2012 8:53 pm Post subject: VW parts |
Another common supplier of "VW" parts was Beru.
In our family business, we ran a fleet of Beetles back in the '50's, '60's and 'early 70's and it was interesting how many parts were supplied by Beru (usually instead of Bosch and other traditional suppliers).
I still have some Beru ignition parts in my stash  _________________ Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Sun Jul 15, 2012 10:34 pm Post subject: |
The GL coil is probably not worth any more than its Bosch counterpart IMHO. The coil and bracket are a little wider diameter than Bosch so the bracket may not hold a Bosch coil tight enough.
Yeah I thnik at one time Beru plugs wer installed at the factory and I have seen Beru plugs in VW labeled boxes before. The other tune up items are a lot less common in my experience. _________________ Roads Scholar
Member# 2059 |
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
Posted: Mon Jul 16, 2012 5:46 am Post subject: Re: "VW" brand parts were actually made by Garbe L |
tasb wrote: |
I have one of those starters in my '65. It 6V and is indeed self supporting as I have no bushing in my transmission. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3481 Location: Vulcania
Posted: Mon Jul 16, 2012 10:27 am Post subject: |
drscope wrote: |
iers too. |
You are correct today, but GM cars of the 30's 40's 50's 60's and most of the 70's were built in house to control the quality and cost of manufacturing, only to be broken up by the government. So many divisions of G.M. most people don't even realize.
D. |
KTPhil  Samba Member
Posted: Mon Jul 16, 2012 12:14 pm Post subject: |
Helfen wrote: |
drscope wrote: |
iers too. |
D. |
Sort of... companies like Frigidaire, Delco, Saginaw, Fisher, and others started out independent, became captive to GM and served GM exclusively, but later branched out and I think were sold off or dissolved. |
