Seeking New/Used 80-83.5 Shift Linkage Bushings
Mark.Ingoglia
Mark.Ingoglia is offline
PostPosted: Tue Dec 21, 2010 12:27 pm    Post subject: Seeking New/Used 80-83.5 Shift Linkage Bushings Reply with quote
Anybody out there have new or used shift linkage bushings for an air cooled - 80 to 83.5 Vanagon? I had great luck with Van Again (856) 327-4936 for most of the parts including bushings but I still need:
1. Center Shift Bushing #251711207
2. Front Shift Rod/bottom ball bushing
These are apparently "NLA"
For the center rod bushing, I've read some interesting options for 2 above, like using pieces from a Golf bushing kit, using a PVC pipe, plastic hose of JB welding a new tab and custom fitting an available VW bushing on to the tab.
Thanks,
mi
reluctantartist
reluctantartist is offline
PostPosted: Tue Dec 21, 2010 8:48 pm    Post subject: Reply with quote
Mark,
We are already in the process of trying to get the bushings. I can see if one more can be added but I am making no promises. We are just getting the center shift bushing. The other two , we are still trying to work out a solution. We may have something for the bottom ball bushing since that is basically a nylon sleeve. But the top ball bushing is going to be tougher to figure out. I got one of the Golf shifter kits and though it is close it is not going to work.
-Andy
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
Mark.Ingoglia
PostPosted: Fri Dec 24, 2010 5:18 pm    Post subject: Air Cooled shifter linkage bushings Reply with quote
Very Happy
Aloha Reluctant Artist,
Please do put me on the list; let me know where to send you the funds. Many thanks and Mele Kalikimaka from Hawaii.
Mark
Ben Tetzner
Ben Tetzner is offline
PostPosted: Wed May 11, 2011 6:06 am    Post subject: Re: Seeking New/Used 80-83.5 Shift Linkage Bushings Reply with quote
Thanks,
mi
Hi Guys,
I am new to the forum,but would be interested in these vanagon shifter bushings also. The one above the tank I am going to try to make from delrin, but the ball bushing that connects the 2 shift rods cannot be made in my estimation. I would love to be included if anyone can find these.
Ben
windnsea
windnsea is offline
PostPosted: Wed May 11, 2011 7:39 am    Post subject: Reply with quote
check out busdepot.com
tetzner
tetzner is offline
PostPosted: Sun Sep 04, 2011 2:21 pm    Post subject: vangon 1980 shift linkage Reply with quote
Hi,
I am new to the list. I am retired from VW and have a 1980 vanagon. I have made my own bushings for these models. I can repair your linkage but need to have the car here to check it at my house. I will do these repairs to nicely maintained vanagons, not junk,but will not sell kits as these bushings need to be "hand fitted".
Please contact me privately.
Ben
Fishguy
Fishguy is offline
PostPosted: Sat Sep 10, 2011 10:32 pm    Post subject: Reply with quote
Found this site. Sounds like the whole kit.
http://www.germansupply.com/xcart/customer/product.php?productid=17869&cat=328&page=1
subter
subter is offline
PostPosted: Sun Sep 11, 2011 7:07 am    Post subject: Reply with quote
One of the members of this fourm sells some shift linkage bushings. You might want to contact him-link below. My local mechanic uses Porche bushings and alters them to fit.
http://community-2.webtv.net/VanStuff/VanagonWestfalia/
1981 Westfalia
WAgrower
WAgrower is offline
PostPosted: Sun Sep 11, 2011 12:24 pm    Post subject: Reply with quote
Anyone find the bushings for an 80-83.5? All the white ones shown are for post 83 vans. I've got a UHMW blank to machine one but would like to replace with the rubber rather then a hard plastic.
reluctantartist
PostPosted: Sun Sep 11, 2011 6:34 pm    Post subject: Reply with quote
Non of those listed will work.
Which bushings are you looking for (Use the letters in the image)?
WAgrower
WAgrower is offline
PostPosted: Mon Sep 12, 2011 12:41 pm    Post subject: Reply with quote
I'm looking for "J" and would imagine that's what others are looking for. It's a urethane bushing that lives right above the fuel tank.
I'm in the process of machining one from UHMW bar stock (and by process I mean trying to find the time..)
It drives ok without it, just sounds like hell with the metal on metal vibration and dragging sound. Also makes it hard to find 1st and 3rd...
I'll take pics so if it works out well I can post a how-to.
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Sep 12, 2011 1:42 pm    Post subject: Reply with quote
What is the diameter of the rod that goes through bushing J?
reluctantartist
PostPosted: Mon Sep 12, 2011 7:31 pm    Post subject: Reply with quote
I'll try and post the measurements of the actual bushing, yes I have a NOS one and the substitue from germany...the wbxr bushings are different and are installed differently.
reluctantartist
PostPosted: Tue Sep 13, 2011 8:28 am    Post subject: Reply with quote
Here is a drawing of the bushing:
Here is what it looks like NOS:
reluctantartist
PostPosted: Fri Sep 16, 2011 6:07 pm    Post subject: Reply with quote
I have an extra NSU bushing that we group ordered for replacement bushings. One of the guys never responded when they came in. PM me if you want it.
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Sep 16, 2011 6:53 pm    Post subject: Reply with quote
I saw several PVC grommets that looked a lot like that at a FLAPS recently.
Or you could make something out of irrigation pipe too, I think.
Just an idea.
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Sep 16, 2011 8:10 pm    Post subject: Reply with quote
There has been a post on the samba http://www.thesamba.com/vw/forum/viewtopic.php?t=385306&start=60
that I dug for a french member a couple months ago,the part is still available from a NSU.
http://www.nsu-autoteile.de/advanced_search_result...=0&y=0 the clear one.
Just make a group buy Wink That's what we did in France.
Bye!
dawna82
dawna82 is offline
PostPosted: Mon Feb 20, 2012 11:59 am    Post subject: Center Shift rod bushing needed!! Reply with quote
Hello,
I am new here to posting.. i read around sometimes, but now I am in need of some HELP. I have a 1982 Westfalia sitting in the driveway in need of some shift rod bushings... I think i have figured out all the ones that I will need. And the main one seems to be NLA. You have posted here about the Center Shift Rod bushing being avail. somewhere in germany... but I dont have that tyoe of $$. Any new information on where I can find this bushing without giving an arm and a leg?
Thanks for the help in advance. i know I will have plenty more questions/concerns as I am super new to this. I am hoping to eventually work on her myself, but with the shift rod thing, i am not yet comfortable getting underneath the vehicle.. because what if i have jacked it up incorrectly? you catch my drift. anyway, lots of help will be needed with the frigde/stove/propane/etc parts of my lovely dented slice of heaven.
I need to get on the road with her!! I cant wait any longer.
thanks,
dawna
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Feb 20, 2012 12:58 pm    Post subject: Reply with quote
Welcome to the herd.
The below URL from above points to the part in question and it is only like Euro 8.
Even with shipping that seems cheap to me.
ALIKA T3 wrote:
http://www.nsu-autoteile.de/advanced_search_result...=0&y=0 the clear one.!
dawna82
dawna82 is offline
PostPosted: Wed Feb 22, 2012 3:58 pm    Post subject: Reply with quote
Seems cheap to me, also. I thought i read somewhere that it was way more than that, thats why they were doing a group buy. Anyway, the link mentions that it's "the clear one".. yet I only see a grey and and a yellow/orange.
Thanks for the help
