cheeseisgood Samba Member
Posted: Thu Sep 15, 2011 1:15 pm Post subject: Heater fan stopped working/blowing fuses |
So my fan would not work yesterday morning. I changed the burnt fuse, but when I turn it on nothing happens except the fuse blows if I leave it on. It worked fine the day before other than the chirping that has been there since I got the van. Are there any relays or easily accessible things to check or do I need to pull the dash and check the blower? _________________ 1987 Westy |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18760 Location: Retired South Florida
Californio Samba Member
Posted: Thu Sep 15, 2011 1:37 pm Post subject: |
It's most likely a bad blower motor. However, make sure to use a 20A fuse. Some use 15A (even Bentley makes this mistake, 97.102, cf 97.116) and they will blow whatever state your motor is in. |
Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1140 Location: S.E. Connetitcut
Posted: Thu Sep 15, 2011 3:34 pm Post subject: |
It's shot, change it before you melt you fuse box, and Ignition switch. |
heidi85ho Samba Member
Joined: October 17, 2009 Posts: 301 Location: Williamsburg,Virginia
Posted: Fri Sep 16, 2011 6:42 am Post subject: |
Bassyaks x2
Mine was shot, before I could change it, a traveling friend turned on the fan for heat while I was in 7/11 getting coffee. When I came out with my coffee, my friend was out of the van and smoke was rolling out of the heater vents. Got it turned off in time, no other damage, thankfully. Changed out the blower motor the next weekend! |
Multimann Samba Member
Joined: August 23, 2010 Posts: 34 Location: Mountainview, CA
Posted: Sat Sep 17, 2011 10:17 am Post subject: |
Same happened to my blower motor this week after a history of squeaking. Now the fuse blows and I guess I need to replace the blower motor.
Does this motor happen to be the same motor as the one under the rear bench? I'm asking because I have removed the whole heater unit - perhaps I can reuse the motor for the front heater unit. Thanks |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10374 Location: Orbiting San Diego
Posted: Sat Sep 17, 2011 10:40 am Post subject: |
No, the dash fan is different than the rear under seat heater fan. The good news is that the dash fan is a common VW part used in many years and models so they don't cost that much to replace. The 86+ passenger vans with A/C have the same fan in the rear ceiling A/C unit. The wire ends vary slightly at times but the fan assemblies interchange pretty easily anyway.
Mark
Multimann wrote: |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10224 Location: Mt Lemmon, AZ
Posted: Sat Sep 17, 2011 11:02 am Post subject: |
FWIW - my fan would not run & and would blow the fuse if I turned the switch to '1' or '2'. If I flipped it directly to '3' it would start & run and continue to run even if I lowered it to '1'.
I reasoned that it was seized -- but not by much.
Did the 'Mullendore Port' treatment noted in the above links and now it works fine at all speeds.
Not a fix for a blower that is well & truly knackered, but if it is just a bit bound up (and the problem is the rear bearing) that M-Port might spare you some owrk now and let you address it sometime in the future, perhaps when the dash is out for something else (or perhaps never). |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Sat Sep 17, 2011 12:28 pm Post subject: |
My blower does not work. After plodding thru the two mentionned links, I think I'll wait until I take the dash apart. Currently run a 2 speed 12 V fan across the windshield. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Sat Oct 01, 2011 8:25 pm Post subject: |
I just replaced mine. It really wasn't that hard. I just used the Bentley and Ben's web site. There is one diagram (in the Bentley)that says to remove screws above the glove compartment and I simply could not find the screws it was referring to. _________________ 1987 Westy |
