DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1400 Location: North Carolina
Posted: Fri Oct 14, 2011 11:06 am Post subject: Understanding headflow numbers?? |
I was comparing the flow numbers between the DRD L6 and the CB Perf wedgeports, both are within $50.00 of each but one is using at 25" of water and the other is at 28". Which is the better head....what other factors should be considered?
DRD L6. $849.99 at .550" lift flow at 203.9 @ 28" of water
CB Perf wedgeport at .550" lift flow at 198 @ 25" of water
Both are intake rates at one given lift an the wedgeports is a 44mm intake verse a 42mm intake for the L6.
Thanks |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Fri Oct 14, 2011 11:22 am Post subject: |
there is a conversion for that. Ill see if I can find my superflow manual for it. |
Posted: Fri Oct 14, 2011 11:45 am Post subject: |
that was an easy find.the conversion factor for those flows are
have flow @ 25" x1.06 =28"flow witch would be 209.88 cfm.
And if you want the other way around it would be,
have flow at 28"x.945 =25" flow ## witch would be 192.68 cfm.
that make it hard to compare heads because some times the flow rate isant stated.it make it easy to "fudge"on the ###'s but still be accurate.if you cant make them flow as much as somebody elses just flow them at a higher flow rate(test pressure)and then you have more.but not realy, but some heads need to be flowed at a defferent rate.but I doubt there is a vw head out there that does.possiably the new cb elemnators.(on a small flow bench that cant pull enough air to reach the 25" test pressure you would use the next lower test pressure that will work&then convert it.if the flow bench cant pull enough to reach the 25"the head is flowing better than the head that reaches the 25"and that is a good thing.
as for the heads I would use the cb heads as they flow more,but pull them appart,do a valve job(lightly do the seats)and any clean up work needed in the seat bowel aera. but depending on how big your motor is you may need to see what the runner cc's are on the heads. the cb mini wedge port has a smaller runner than the wedgeport but still flows more than the drd head you listed.and it has the 42 mm intake valve also. do your home work. under 2200 cc runner size can be importaint on a street car.my 2028 had a slight sag in power midrange,hopefuly the taller better desigined big beef cb intakes will elimnate it.my 2332 with the same cam,cb tall intakes &lower cr had no problem at all. |
Pat D Samba Member
Posted: Fri Oct 14, 2011 11:56 am Post subject: Re: Understanding headflow numbers?? |
DerrickfromNC1 wrote: |
Thanks |
Look into our new Super pro 044. Flows better than the wedgeport with a 6cc smaller intake port volume. Air speed is 30 ft per/sec greater also. It's a killer port. |
vince1 Samba Member
Joined: December 14, 2003 Posts: 836 Location: Burgundy, France
craigman Samba Member
Posted: Fri Oct 14, 2011 12:37 pm Post subject: |
Max head flow #'s don't mean $hit...
Are you going to drive your car around at 7K rpm all the time? If you are, then max #'s might mean something.
It's all about port velocity...
Don't know about the DRD heads, but most CB heads are based on their own head castings. Not stock casting like most heads out there. |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Fri Oct 14, 2011 12:54 pm Post subject: |
I won't say flow numbers are not important for performance but no one talks about them with respect to why they may or may not be important at different times for different applications. There is much more interest now in port volume which is correct thinking for sure but you should see that a port with the same flow numbers at full lift have fatter flow numbers in the low to mid lift region that a higher volume port. That is a winner of a head. At very low lift, just off the seat, you will see that the numbers change very little from head to head for a given valve size because it's ruled by the valve seat prep. In a street engine that is throttled a lot those mid/low to mid lift numbers are the key to sharp throttle response and good economy with power and torque right here and right now.
When you move into the higher sustained RPM's the mid numbers are less important than the total flow and volume as the flow regime has changed and the timing events, on a relative scale, have become much shorter due to RPM and the effect of piston movement becomes more influential than in a lower RPM street engine. What I'm talking about is relative piston velocity vs time allotted to get the air in the cylinder. Piston velocities are rising while time is shrinking so the pressure drop thru the port is rising. Raw volume becomes more important in this region and also why cam timing has to increase as has always been understood. In this situation VE can go very high with careful intake setup.
Don't bother to point out some of the issues I purposely left out to try to keep this simple. It's almost impossible to put into 2 dimensional words something happening dynamically in 3 dimensions. It would take pages and pages and be more confusing than enlightening.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Posted: Fri Oct 14, 2011 1:51 pm Post subject: |
craigman wrote: |
did you understand what pat said?would yourather have a head that flows 60 cfm at all ranges??above .200" lift?with a monsterious port? a proper smaller port can out preform/flow a bad biger port.Thats makes power&torque& driveabilty. |
Pat D Samba Member
Posted: Fri Oct 14, 2011 2:00 pm Post subject: |
The super pro is a smaller port than the wedgeport. It flows from 3-8 cfm more starting at .300 lift than the wedgeport. The port volume is 6cc less then the wedgeport. Any time you can achieve more flow with a smaller port, you have a more efficient better performing head. The decrease in port volume increased port velocity by about 30 ft per/sec. A win win situation. Flow numbers are just as important as velocity numbers. They need to go hand in hand with eachother. Too much air speed= sonic choke. Sonic Choke is directly related too the Cross section of the port. There is no way too fix it other than making the crossection bigger. You have too lower the air speed.
Not enough air speed or too large of a port = port will not recover at lower rpm's and will have poor performace.
The Super pro is a great head for the money. |
modok Samba Member
Joined: October 30, 2009 Posts: 27651 Location: Colorado Springs
Posted: Fri Oct 14, 2011 5:28 pm Post subject: |
All the newer CB heads, the super-pro, the mini wedge and los panchito
Look friggin awesome
Headflow at 25" is hp potential, choose the one that fits your goals and the rest of your engine |
ralf Samba Member
Posted: Fri Oct 14, 2011 5:37 pm Post subject: |
and this is why... some.. will say only the flow bench can tell (if ur doing it right or wrong.. or its the only way? LOL)
but airspeed, and depression says alot more than flow..
just like a dyno ...peak numbers open eyes, but e.t. and our lap times differ greatly on how the "curve" on the dyno is...
plotting numbers by cfm ' cb's have fat curves that lets u use all of the heads potential
looks like the new offerings from CB are like wat modok says, AWESOME!
now i wonder how my friend's 2176 would run with the super pro when it already has good top end with the cnc wedge's
 _________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
Hotrodvw Samba Member
Posted: Sat Oct 15, 2011 6:31 pm Post subject: |
I was just looking at the super pros. They look really good! Very attractive for my up and coming head purchase. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5066 Location: Madisonville, La
Posted: Sat Oct 15, 2011 8:50 pm Post subject: |
Pat D wrote: |
Pat, can you order matching IDF manifolds for this head?? _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Sun Oct 16, 2011 9:44 am Post subject: |
I think they have cnc ported intakes for all thier stuff,get the tall big beef intakes there about the best intake out there,nice &slim helps keep velostcity up ,not just a set of flanges with a big hole leading to a small hole.I have them on both of my motors.+they look good.(wish they would widen them up a bit),but plenty of room for just about any size &shape port you might want or have. |
wicked1lbc Samba Member
Posted: Mon Oct 24, 2011 7:39 am Post subject: |
I've been saving for about a month for the SuperPro's and talking with Pat about my 2276T I'm Building. (Hoping for about 275ish HP low-boost street/daily driver... impossible??? ... we'll see i guess) Got the cam he recommended and finally was about to call this a.m. to order the heads with the valve spring upgrades and to my dismay... CB is closed on Monday's FML...LOL... _________________ http://www.facebook.com/pages/Vintage-VDubz/158714140852567
64 Bug -- http://www.thesamba.com/vw/forum/viewtopic.php?t=446680
2276cc Turbo
Freeway Flyer Tranny
Matte Black with Spikes |
Posted: Mon Oct 24, 2011 8:25 am Post subject: |
wicked1lbc wrote: |
I've been saving for about a month for the SuperPro's and talking with Pat about my 2276T I'm Building. (Hoping for about 275ish HP low-boost street/daily driver... impossible??? ... we'll see i guess) Got the cam he recommended and finally was about to call this a.m. to order the heads with the valve spring upgrades and to my dismay... CB is closed on Monday's FML...LOL... |
Very doable......good heads just make the Turbo's job easier and the cam can approach closer to a normal street grind for good bottom end. People think that just because they are going Turbo that the heads become unimportant.....not at all true. They are just as important as any other application. The advantage to VW heads is they are all ready oversized on the exhaust side even the big valve 40x35.5 or 42x37.5 but you can even go further on the exhaust for your turbo. Big power with lower boost ensues or even bigger power with moderate boost.
Posted: Mon Oct 24, 2011 9:47 am Post subject: |
RockCrusher wrote: |
wicked1lbc wrote: |
Very doable......good heads just make the Turbo's job easier and the came can approach closer to a normal street grind for good bottom end. People think that just because they are going Turbo that the heads become unimportant.....not at all true. They are just as important as any other application. The advantage to VW heads is they are all ready oversized on the exhaust side even the big valve 40x35.5 or 42x37.5 but you can even go further on the exhaust for your turbo. Big power with lower boost ensues or even bigger power with moderate boost.
RC |
Exactly how I understood it looks like all the research i did is paying off. I just can't wait to see what kind of numbers i make and feel the power when I need it. To be honest I'm going for a highway cruiser with power when i need it. my next investment will be a new tranny from rancho with a 3.88r/p and a .82 4th. Depending on the rpm drop from 3rd to 4th will tell me what size tires ill run. I'd like to run the tallest possible without dropping below the power range if I shift at 4500-5k rpms. It would be perfect if i can get 28" tires under my widened fenders. That would put my cuising speed for 3rd gear at 52mph@ 3000 rpms and 80mph/3000 rpm's/ 4th gear... even with 4th and final gears being so long with the taller tires it will still be fun enough to poke at the honda kids every once in a while. i may even play with a pony or two  _________________ http://www.facebook.com/pages/Vintage-VDubz/158714140852567
2276cc Turbo
Posted: Mon Oct 24, 2011 9:59 am Post subject: |
I did not like the .082 in mine, with 33x19.5 street tires,to much between 3&4 for around town(rpm drop in 4th to low and 3rd to high, well not to high but more than I want around town.but the 093 was much better so it dont take much,and I did not notice any thing on the highway just cruzze at 75-80 and dont worry about it. |
Posted: Mon Oct 24, 2011 10:02 am Post subject: |
mark tucker wrote: |
33" tall? wow urs must be lifted rat rodded or something because as far as i know those wont fit very well under fender _________________ http://www.facebook.com/pages/Vintage-VDubz/158714140852567
2276cc Turbo
Posted: Mon Oct 24, 2011 10:08 am Post subject: |
if ur riding 33's on a .93 4th, ur actually just a lil longer geared than i would be if I rode 28's on a .82 4rth
if you were running 33's on a .82 i can see how it would be an extremely large rpm drop from 3rth to 4th _________________ http://www.facebook.com/pages/Vintage-VDubz/158714140852567
2276cc Turbo
