009 or 010 dist
Sonny
Sonny is offline
PostPosted: Thu Nov 18, 2004 11:12 am    Post subject: 009 or 010 dist Reply with quote
I found a new 010 yes new in a barn.I have 009 on now its a 1776with 110 cam 041 heads.What gains will I get from the 010.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Nov 18, 2004 11:18 am    Post subject: Reply with quote
Faster advance curve and more stable/steady advance through the range.
The 010 is far superior in quality to the 009, even the german made 009
Glenn I'm sure will fill you in on more details, he is the 010 guru! Very Happy
stevemariott
stevemariott is offline
PostPosted: Thu Nov 18, 2004 1:31 pm    Post subject: Reply with quote
If it's *new* (and looks it), sell it to a vintage collector who will pay the bucks for a mint badge and other pieces. Then buy a modern distributor with the ca$h. That's what I would do.
1963 Manx copy
1968 Bus
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Nov 18, 2004 1:41 pm    Post subject: Reply with quote
The 010 is superior to the 009. It has a more agressive advance and they run smoother. The new 009s have some serious quality control issues.
It doesn't matter if it's new or used... use it. You should take it apart, clean and lubricate it. I have seem distriutors that have been sitting for years that have some corosion.
You can tell if it's truely new by the o-ring. The original o-rings were tan in color and the new ones are black. The condensor should have a yellow wire and the cap should be dark brown.
Here's my NOS Bosch 010.
And here's what the original tuenup parts look like compared to the current parts.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Thu Nov 18, 2004 1:46 pm    Post subject: Reply with quote
damn glenn, the badge on that nos 010 is making me drool... I am still searching for a perfect 010 badge and am willing to trade 2 010 cores for one, just to get a perfect one.
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
Mr. 010
Glenn is offline
PostPosted: Thu Nov 18, 2004 1:52 pm    Post subject: Reply with quote
Then this will make you wet your pants.....
Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Thu Nov 18, 2004 2:02 pm    Post subject: Reply with quote
nah, I already got some of those:
and some spares
Cool
keifernet
PostPosted: Thu Nov 18, 2004 2:09 pm    Post subject: Reply with quote
Okay Kids, quit showing off! Razz Laughing Wink
TimGud
TimGud is offline
PostPosted: Thu Nov 18, 2004 3:28 pm    Post subject: Reply with quote
Don't you sell rebuilt 010's Glenn?
Mr. 010
Glenn is offline
PostPosted: Thu Nov 18, 2004 3:33 pm    Post subject: Reply with quote
Yes I do.... http://www.glenn-ring.com/4sale
I rebuild all of the old Bosch cast iron mechanical advance distributors.
Bosch "383", VJ4BR8, VJ4BR18, VJ4BR25, 231 129 010, 231 129 019 and 231 129 022.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
flatfour
flatfour is offline
PostPosted: Thu Nov 18, 2004 5:05 pm    Post subject: Reply with quote
The 010 all the way. I love mine that I got from Glenn.
vrsechslvr
vrsechslvr is offline
PostPosted: Thu Nov 18, 2004 6:54 pm    Post subject: Reply with quote
As we all know by know the 009's have serious quality control problems. I can account for that first hand. I'm on my second 009 and I'm not impressed.
Glenn, this question goes out to you.
Would you recommend a 010 or a 019 for a stock 1600dp? And what is the price from you?
I need a dizzy that I can use now and take to my new motor.
Gotta Luv the Dub!
65bug
65bug is offline
PostPosted: Thu Nov 18, 2004 7:03 pm    Post subject: Reply with quote
Question for you guys,
Can you actually feel a difference in the way the motor runs between a new 009 and one of Glenn's 010????
Crap, I just bought a new 009 for my car from Berg. 56.00 too! Dam, I want one of those for my new motor Glenn!
Mr. 010
Glenn is offline
PostPosted: Thu Nov 18, 2004 8:31 pm    Post subject: Reply with quote
For a bone stock, the 019 is probibly best. It has a similar advance curve to the 009. It also works well with a mild performance engine.
The 010 works well with mild to high performance.
Can you feel the difference?
I sure did. I replaced the German 009 I had in my 1904cc with Berg HEI ignition with a 010 and noticed the improvement the first time i stepped on the gas. After a week I reinstalled the 009. The performance was a serious drop and I put the 010 back in.
I will rebuild your distributor and sell you one outright.
http://www.glenn-ring.com/4sale or contact me privately.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jardindelalma
jardindelalma is offline
PostPosted: Fri Nov 19, 2004 9:31 am    Post subject: Reply with quote
where could one get the parts needed to do the rebuild themselves?
lookin at an 019 that needs rebuild and love to tinker! Laughing
hows about for an 010 as well....
thanks folks!
Mr. 010
Glenn is offline
PostPosted: Fri Nov 19, 2004 10:48 am    Post subject: Reply with quote
thanks folks!
Email me. I can supply you with a Bosch shim kit and insulator kit. I also have access to some of the other parts. But not all are available.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jardindelalma
PostPosted: Mon Nov 22, 2004 5:40 pm    Post subject: Reply with quote
thanks glenn...i will contact you as soon as i get the core to work with...
while i am deciding...
we have spoke about the 009..... 010 ......and 019
whats the story with the vjr4 br8????
Mr. 010
Glenn is offline
PostPosted: Mon Nov 22, 2004 6:32 pm    Post subject: Reply with quote
The BR8 and BR25 are early versions that became the 019 and 010.
The BR8 has the same weights and curve as the 019.
Thr BR25 has the same weights and curve as the 010.
The newer 019 and 010 have a design change where the shafts spin in brass bushings while the older BR8 and BR25 spin in the cast iron body without bushings.
I do sell them outright and currently have a 010 in stock.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Mon Nov 22, 2004 7:04 pm    Post subject: Reply with quote
Glenn: do you work on 050's as well?
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Mr. 010
Glenn is offline
PostPosted: Mon Nov 22, 2004 7:11 pm    Post subject: Reply with quote
Not yet.
I haven't bothered to work on 009 since they are cheapr to buy new than to rebuild. I haven't had the oppertunity to work on a 050. The parts i get are "generic" Bosch kits and fit many different models.
If you want to send me a 050, i'll be happy to take a look at it and if I can fix it, i'll do it for the cost of parts and shipping. But only on the 1st one I get. Kind of a R&D discount.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
