Blankity blankin' fuel pump.
Banjoben
Banjoben is offline
PostPosted: Wed Nov 16, 2011 4:23 pm    Post subject: Blankity blankin' fuel pump. Reply with quote
I got to drive the fastback to work the other day, but noticed a heavy smell of gas when I pulled in. Further investigation showed a steady drip from the 3-port bosch fuel pump while running. it's coming from right around the electrical connector. Brand new pump..... Jeesh. The guy I got it from installed it trying to get it running, but never had it working ( I found other issues to fix it) so, I'm the first to actually use it.
I tried putting the old pump back in. it does not want to work, AND it's seeping from the same spot!!!!
I think it will get replaced by some universal type. Any recommendations for a reasonably priced pump? I'm assuming if I put in a 2 port pump I can just run the return line straight to the tank and eliminate the "T" that goes to the old pump without any issues.
1974 VW Westfailia Campmobile Deluxe (Clementine)
1970 VW Type 3 fastback. (Abby Normal )
2008 Passat Turbo Wagon Lux
ASE Certified Advanced Level Master Tec / Toyota Master Diagnostic Tec.
Head Boffin of the legendary(does it really exist?) Stray Cat Vintage and Custom Garage. Home of "The Bomber Squadron"
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Wed Nov 16, 2011 4:28 pm    Post subject: Re: Blankity blankin' fuel pump. Reply with quote
do a quick search on the Ford Ranger fuel pump that Russ Wolfe used/advocated....
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Banjoben
Banjoben is offline
PostPosted: Wed Nov 16, 2011 5:41 pm    Post subject: Reply with quote
Saw that thread. The 90 Ranger comes up as using an airtex E2002 in-tank pump. The one A saw spec'd out/ told to use here on Samba is an Airtex E2000 (But that thread said that was from the 90 Ranger). I can get that locally for about $90. Looks like the E2000 is the one I want. Not sure what it fits.
Maybe I'll be able to get it this weekend.
Napa showed a pump available for a Type 3.. for a mere $625!!!!!!!
avesondm
avesondm is offline
PostPosted: Wed Nov 16, 2011 6:52 pm    Post subject: Reply with quote
The Airtex E2000 works fine. I'm running one and yes, just remove the tee and go straight back in to the tank.
71 Squareback FI "TC"
Fat chicks need love too and I have more frunk space than you.
Banjoben
Banjoben is offline
PostPosted: Wed Nov 16, 2011 7:01 pm    Post subject: Reply with quote
Excellent. Did it effect your fuel pressure in the system? Just wondering if I'll have to readjust the regulator. It doesn't seem like it would.
Bobnotch
Bobnotch is offline
PostPosted: Thu Nov 17, 2011 5:43 am    Post subject: Reply with quote
I'm using the Airtex E2000 pump as well (on 2 T-3s). I didn't have to change the fuel pressure regulator or anything like that. You might have to cycle the key a couple of times (to build pressure in the fuel ring) before starting the engine, as the new pump doesn't have a check valve. On my 71 Notch, the fuel pressure would hold for a very long time after shut down, and even have a couple of psi on it in the morning still. According to Ray, that's the sign of a good pressure regulator (it holding pressure after shut down).
By the way, the E2000 pump is for an 85 Ranger. This is the frame rail pump.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Root_Werks
Root_Werks is offline
PostPosted: Thu Nov 17, 2011 11:37 am    Post subject: Reply with quote
3 port pumps are a waste of time on D-Jet cars unless you are bent on being original.
Get a later inline pump from any L-Jet VW from the 70's or 80's. Update your fuel line routing to the later system. It's simpler and the pumps are far more stable than the 3 port pumps.
When I set my timing, why do I flush, then take a pee?
avesondm
avesondm is offline
PostPosted: Thu Nov 17, 2011 12:43 pm    Post subject: Reply with quote
You should check the fuel pressure regardless. Don't just assume it is good.
Banjoben
Banjoben is offline
PostPosted: Thu Nov 17, 2011 7:48 pm    Post subject: Reply with quote
Yup. I'll plan on it. I hope to stop in to my FLAPS tomorrow and pick up the pump. Get that put in, check the fuel pressure, and it'll be back on the road. Next "issue" is getting warm air to come out the defrosters. We got a dusting of snow today.
supaninja
supaninja is offline
PostPosted: Fri Nov 18, 2011 6:58 am    Post subject: Reply with quote
I don't think anyone has made a DIY for installing a ranger pump, maybe you could snap a few pic's and put a simple one together, I'm sure Everett would add it to the reference thread. This topic does come up once in a while.
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
FergU
FergU is offline
PostPosted: Fri Nov 18, 2011 8:35 am    Post subject: Reply with quote
Yes! Please.
1962 Type 1
1963 Type 14 - Karmann Ghia "Sadie" (Restoration progress - http://vwsexysadie.wordpress.com)
1972 Type 3 - Squareback "Joseph" (Restoration Progress - http://jpdproject.wordpress.com/)
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Fri Nov 18, 2011 4:12 pm    Post subject: Reply with quote
1991 ford ranger
its the fuel pump on the rail under the driver seat
i got mine out of a pic-n-pull for $20
i had it on my 71 411 (altho didnt prime ...it just continuously ran)
make sure you take the foam around it aswell
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
Banjoben
Banjoben is offline
PostPosted: Fri Nov 18, 2011 4:54 pm    Post subject: Reply with quote
Stopped in at my FLAPS today after work and got the pump. $90 plus tax! yikes. and that was at the "auto tec"rate. it listed for $145.
Anyhow, It's supposed to get kinda warm tomorrow, so I'm planning on installing it then. I'll do my best to take some pics and post the "play-by-play". It looks pretty straight forward. Biggest thing for me will be scrounging a fuel pressure gauge to check that when I'm done.
Bobnotch
Bobnotch is offline
PostPosted: Fri Nov 18, 2011 6:15 pm    Post subject: Reply with quote
Just a little heads up. Re-use the old pump bracket (it fits the new pump), and move it and the new pump to the center of the front beam. This will give you nice lazy bends for the pump and fuel filter combination. I only say that, because the new pump is longer than the compact arrangement of the stock pump. You might need some longer hoses though, so keep this in mind. A couple of us who are using this pump are doing the same thing (moving it to the center of the beam). By doing this, you avoid kinks in the supply hose, that can burn up the new pump. If you're using the Airtex pump, the output end is the end with the wire connectors. The left connector is + while the right is - (looking head on at the outlet). I only mention this, because the installation instructions that come with these pumps don't tell you this, and you can actually run the pump backwards. Shocked By the way, I got both of my pumps from Autozone for 92 bucks out the door. Had I shopped around, I could have gotten them cheaper (someone sent me a link for them at 55 each a couple of years ago Shocked), but I needed the pump now, not in 4 days. Wink
I hope this helps.
Edit, I just checked the link I was given, and their price went up (no surprise).
Tram wrote:
Tram wrote:
sharkskinman
Lateral Lunatic
PostPosted: Sat Nov 19, 2011 9:43 am    Post subject: Reply with quote
http://www.shepherdautoparts.com/autoparts/fuel_pu...PDk8OR.htm
$20
http://www.carparts.com/details/Ford/Ranger/Replac...5021671818
44$
or go to a salvage yard or call one and just tell them you need one off the drivers frame rail
like 20$ or so
PS4 "NKOGNEATO"
Banjoben
Banjoben is offline
PostPosted: Sat Nov 19, 2011 12:09 pm    Post subject: Reply with quote
Be careful guys. the 90-91 ranger pump is not the right one. That is an in-tank style. It will not work on the VW. the inlet connection is for the press-on sock filter, not a hose ,and it does not come with the noise insulating foam rubber around the housing
The one we need is for 88 and older Rangers. it's, like you said, the one on the frame rail.
89-97 Rangers take the E2002. 85-88 take the E2000.
http://www.shepherdautoparts.com/fuel_pump/ford/ranger/1988.html
looks like I still could have ordered it for around $20... Grrrrrrrr.
sharkskinman
Lateral Lunatic
PostPosted: Sat Nov 19, 2011 3:54 pm    Post subject: Reply with quote
90-91 for ranger have 2 pumps
the one in the tank is more like a prime pump
I Took mine off of the rail 1991 ford ranger
PS4 "NKOGNEATO"
Banjoben
Banjoben is offline
PostPosted: Sat Nov 19, 2011 5:30 pm    Post subject: Reply with quote
OK I stand corrected about the 91 Ranger. But I will say if you look up the 85-88 there's no chance you'll get the wrong one. hehehehehe.
Drove Abby over to 5-Guys on a "bomber run" Got some greasy burgers, and came home.
the only major glitch was the battery shifted on a hard right turn, and pulled the ignition wire to the starter loose. I had to reach under, and pop it back on to start it up to get home. There currently is no battery hold down as it's all rotted away. So rectifying that issue just moved wayyyy up the list.
The new pump seems to work good. My pics came out terrible, so they probably won't work well for a tec article.
Tomorrow I gotta find a fuel pressure gauge. I noticed a bit of chugging under acceleration that was not there before. I'm bettin' it's a touch low.
So I'll keep workin' out the bugs and pretty soon we'll be doing fine.
Mike Fisher
Mike Fisher is offline
PostPosted: Sun Nov 20, 2011 10:35 am    Post subject: Reply with quote
I bought a cheap 0-100lb water pressure gauge from Home Depot to test mine.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Banjoben
Banjoben is offline
PostPosted: Sun Nov 20, 2011 3:04 pm    Post subject: Reply with quote
Well, I spent the morning tweaking. I set the valves (All to .006) then tweaked the fuel. It was at about 28. I set it to just on the bottom of the line of 30. I sprung for a fuel pressure gauge set. It's one of those tools I always meant to get, but never did. Now I have one.
The afternoon was spent bombing around to see how it was. Not bad. All seems in order, but there is a "rapping" in the engine at mid RPM range after the engine warms up. Sounds like a noisy valve, but I just adjusted them. It's not very noticeable at idle, and does not get any worse under acceleration. it's also not very noticeable at highway speeds. I'm hoping it's just there. Oil light is not on or flashing. oil is full and fresh. 10W30 Timing had been set to 0 at 650 rpm with the vacuum line off. the engine seems to be running wonderfully, so I'm not overly concerned. but its in the back of my head.
The only thing I can think of is that I set the valves cold. is the .006 setting for a warm engine? the manual I have didn't say.
Page 1 of 8
