69bajaguy Samba Member
Posted: Wed Nov 23, 2011 9:47 pm Post subject: 1915 build. Advice needed! |
Hey guys. Ya'll might have seen me around asking ignorant questions about different aspects of motors so i figured I would go ahead and start a thread for my own motor build It will be a 1915 and it is going in a baja with a bus tranny. As of right now I just have a pile of parts and I still need to order more. I have surpassed my original budget but that's okay.
This is what I have now:
-AA 1915 rebuild kit (94 P&Cs, 69mm counterweighted crank, rods, gasket set, bearings, Maybe more but I can't remember off the top of my head)
-Dual Italian Weber 40s with crossbar linkage
-Engle FK41 cam
-Berg Hemi cut heads (cut for 94s) with stock size valves and high rev springs
-Alternator
-Coil (not sure what it is but it's German??)
-Bosch 009 Distributer
-Push rods and tubes
-Cooling tin
Still on the list:
-019 distributer (someone suggested this I think but I'm not sure what distributer would be best)
-Single HD valve springs (once again these were suggested but I'm not sure of the difference between these and the high rev)
-5lb pulley (why 5lb? It too was a suggestion)
-1700 clutch and disc (http://vwparts.aircooled.net/200mm-Kennedy-Engineering-Racing-Pressure-Plates-p/4090.htm)
-1.5 qt oil sump (a 3 qt deep one was suggested but I don't know what the real difference in performance would be)
-Oil pump with filter
-Valve covers (Right now I have some crappy ones that just leak. I was thinking about bolt on. Any suggestions?)
-I still need to get the case bored.
-And the eternally impending question of exhaust! I need something good for offroad and I also would like for it to accept heater boxes.
Also, what do I need to know about deck height and compression? And anything else important about building a motor!
Any advice or help about anything (parts, assembly, etc.) is greatly appreciated! And keep in mind that I do not want to spend too much more! |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Wed Nov 23, 2011 10:01 pm Post subject: |
You'll need a set of 1.4:1 ratio rockers to use with the FK-41 cam.
Personally, I'd use dual valve springs even though the 41 is a mild cam duration wise it does lift to 0.510". You'll need duals if you want decent life from the valve train. Singles won't cut it.
Get a good set of stock valve covers, unless you want to spend more cash on bolt ons.
Keep your deck height as tight as possible, with hemi heads I'd even go 0.040", even though there really is nothing for the piston to hit except at the far outer edge of the combustion chamber.
Watch out, all the hemi haterz will come out of the woodwork here.
What cc are your combustion chambers?
Do you know how to tune an engine with hemi heads? It normally requires more timing advance than conventional heads.
Forget the 5 lb pulley, your motor doesn't need it.
A 1.5 qt sump will be fine for this application.
I'd also forget the pump/filter combo and get the case full flowed when you get it bored. Use an o-ringed 26mm pump from RC Enterprises and a remote mount oil filter.
I was going to suggest a 12 lb flywheel if you are doing mostly street driving but if it's for mostly off road stay with the stock 16 lb flywheel.
My thoughts...so far. _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
Posted: Wed Nov 23, 2011 10:26 pm Post subject: |
Are you sure about the 1.4:1 rockers? The engle website says either works (i think) http://www.englecams.com/downloads/2010_engle_catalog.pdf and i already have the 1.25's!
So you think the dual valve springs over the high rev ones?
I'm not sure about the cc of the combustion chambers.
I don't really know a lot about tuning. Sorry i'm a noob!
What does it mean to get the case full flowed?
Thanks a lot for all the suggestions so far! |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4263 Location: Aumsville, Oregon
Posted: Wed Nov 23, 2011 10:33 pm Post subject: |
| 69bajaguy wrote: |
The 1.25's will work you just won't get all the lift and performance the cam was designed for.......those spin on filter pumps are not a good idea....some say they are fine, I say bullshit......full flowing the case involves drilling and tapping for a port to run an oil line to.....do a search and you'll see _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Posted: Wed Nov 23, 2011 10:47 pm Post subject: |
Actually with the stock size valves in your heads it's all academic, with 1.4's and 0.510" lift or 1.25's and 0.455" lift the heads (valves) will be a major restriction. Bad combo. Either get bigger valves or different cam.
You need to find out the chamber cc's in order to calculate your CR. _________________
| Mitey62 wrote: |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Thu Nov 24, 2011 1:18 am Post subject: |
1.25's will work fine with the 41 cam but you still need dual springs. It IS a questionable choice for a cam with stock valves but will be a torque monster until you hit the flow limit.
Don't like the Hemi heads but hey, whatever, if you all ready own them. They work.
Of course I have to agree with the O-ring pump suggestion....
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
nsracing Samba Member
Posted: Thu Nov 24, 2011 7:28 am Post subject: |
Well whatever you do, don't throw those lovely expensive parts in some bastard cut case machined w/ a drill press. Get it done right and blueprinted quality.
Cleanliness is key in the build so have the case jetwashed.
Do balancing. Well worth the money.
Goodluck on the build. Look forward to the details. |
Posted: Thu Nov 24, 2011 7:42 am Post subject: |
| Thanks a lot guys. What would ya'll suggest for valve size? And what do people not like about hemi heads? |
Posted: Thu Nov 24, 2011 8:02 am Post subject: |
| 69bajaguy wrote: |
40 x 35.5 valves would be the best overall choice for you. Hemi heads have poor flame propagation characteristics and no "squish" or quench pads to assist in detonation suppression. They were a nice idea from a brilliant guy years ago for the changing gas quality on stocker type engines that were intended to last 100k miles but the idea is well past it's time and just won't die.
Posted: Thu Nov 24, 2011 8:09 am Post subject: |
| Well darn. It looks like i'll be up-ing the valves! Any suggestions about the distributer? Is the 009 okay or should I get a 019? |
the2ndcashboy Samba Member
Posted: Thu Nov 24, 2011 9:14 am Post subject: |
For the amount of money you'll spend to get your old, inefficient heads reworked for larger valves, you'd probably be halfway to paying for a new set of heads with better chambers and larger valves already installed.
Of course then you might feel like you're wasting the potential of your new heads by running a stock stroke crank, so then it will be time for a stroker. And then H-beam rods. And B pistons. Then you'll need to get bigger carbs to match. Etc, etc, etc. Careful, its a slippery slope  _________________
| SRP1 wrote: |
| You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones. |
| modok wrote: |
| If anything comes out perfect it just means your measuring tools are substandard. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15605 Location: Deep in the 405
Posted: Thu Nov 24, 2011 9:28 am Post subject: |
I disagree that there is anything wrong with hemi cut heads. VW heads have not changed in 40 years and there is no new technology. Too many people read a Chevy book and try to build a VW engine.
For your 1915cc if you keep the stock heads with single HD springs I would suggest changing to a Engle W-100 cam with your 1.25 rockers. If you have the money to upgrade to new heads I would suggest DRD 35.5x32 valve heads https://www.drdracingheads.com/xcart/DRD-35.5X32mm-Performance-head.html to use with the FK-41 cam and 1.25 rockers. The 5 lbs pulley is always a good idea on any engine. It has proven to add life to the bearings when all the reciprocating parts have been balanced. The 1.5 qt sump is all you need on that size engine with a 5000 RPM range cams. The bolt on filter pump would also be fine for your small engine combo. Stock valve covers and bails is all you need. Don't go any larger then 1 1/2" exhaust.
As far as distributor, the Bosch 009 would work OK, but in my opinion the best choice with dual Webers that have ported vacuum would be an SVDA from aircooled.net. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Nov 24, 2011 10:21 pm Post subject: |
| About how much might it cost to rework the heads and get new valves? And what would the difference in performance be if I just went with the W100 instead of doing the heads? The cam would be about $80 and I could also sell the other. |
Posted: Fri Nov 25, 2011 9:24 pm Post subject: |
| RC, what's your website? |
Posted: Fri Nov 25, 2011 9:40 pm Post subject: |
| 69bajaguy wrote: |
http://www.rcaircooledvw.com/ Wait for it!  _________________
| Mitey62 wrote: |
Posted: Fri Nov 25, 2011 10:18 pm Post subject: |
Darth is right....site not up yet. Email or give a call.
Posted: Sat Nov 26, 2011 2:49 pm Post subject: |
| I just looked at my case and it turns out that its an as-21 and the engine code is AJ051014. So i looked them up and apparently the as-21 cases are the strongest and the AJ's are between '75 and '79 so i guess that means it's dual relief? Good case? |
Posted: Sat Nov 26, 2011 3:05 pm Post subject: |
Yes.
Yes. _________________
| Mitey62 wrote: |
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Sat Nov 26, 2011 3:44 pm Post subject: |
The CB Performance filter pumps are fine. My family has used them for years and years without trouble. Papaw started using them practically from the moment they became available. The 2110 in Dad's drag Bug used one and it was run up to 8600 RPM many times. My 2276 runs one, Dad's 2386 has one, the 1600 SP in his DD has one.
I feel they are a great way to get a real oil filter if you don't want to go full flow. The main issue with them is that it may interfere with your header. Make sure before you buy. _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
