The "Breadbox" Build
Page: 1, 2, 3 ... 15, 16, 17  Next
badassdubs
badassdubs is offline
PostPosted: Thu Dec 22, 2011 11:49 pm    Post subject: The "Breadbox" Build Reply with quote
My first build thread on the Samba. So let me intoduce myself. I have been building cars for myself for years. Owned over a 100 so I have been busy. I'm sure some of you have seen them, maybe not. I do everything myself. So here are a few and then we will get started with my build.
In Progress.
There are more but this is enough.
This '80 vanagon I have had for 10+ years. It has been a good storage shed. I bought it for $150 from a guy that just needed it gone. Ran but had 40psi on one bank and 100psi on the other. Difficult to start. So it sat.
Fast forward to this summer. Time to get it going. Wanted something different so I opted for a vortec 4.3 V6. I found a motor with 73K on it. Also picked up the harness and ecu for a total of $225 out the door. Purchased a KEP adapter and a IMI hi-torque starter. I already had a set of Sanderson street rod headers so those went on also. I built my own powder coat oven years ago, so most everything gets it.
I modified the original harness myself, saving $500. And it runs.
Suspension time
What a nasty mess. Hours of sand blasting. Then into the oven and then installed with all new parts. Koni adjustables and CIP 2" lowering springs.
The front header was not repairable so I decided to change it out and also put in a new windshield. Still working on it.
I have always hated the bumpy brown dash so that was stripped and powder coated. A 12 volt outlet also installed.
These came a few weeks ago from treadepot.com.
I powder coated these tonight. Still needs an orange pinstripe.
And last but not least. I am also putting a porsche 996 gauge cluster in.
I have managed to get the speedo, volts and water temp working but still struggling with the fuel gauge. I will be putting in a classic instruments gps speedometer sender so that the gauge will be dead on.
Still a long ways to go. Decided to put rear discs on so that is one more thing to do.
syncrodoka
syncrodoka is offline
PostPosted: Thu Dec 22, 2011 11:55 pm    Post subject: Reply with quote
Very impressive build, thanks for sharing. Applause
dobryan
dobryan is offline
PostPosted: Fri Dec 23, 2011 7:54 am    Post subject: Reply with quote
Love the 996 gauge cluster! (And the rest of the build). Very Happy Exclamation
Dave O
The Western Syncro build
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Dec 23, 2011 8:06 am    Post subject: Reply with quote
mad skillz
Casey--
'01 Weekender --> full camper
y u rune klassik?
vspecter
vspecter is offline
PostPosted: Fri Dec 23, 2011 7:22 pm    Post subject: Reply with quote
We will need more pictures of your ride!! Awesome machine!
Westfalia 1985
Doka 1985 Sold
Roadtrip to from Québec to Utah: http://www.youtube.com/watch?v=DqCpcA7NLdE
purplepeopleeater
purplepeopleeater is offline
PostPosted: Fri Dec 23, 2011 7:26 pm    Post subject: Reply with quote
Nice, you don't mess around on projects.
Where in washington are you?
dubbified
dubbified is offline
PostPosted: Fri Dec 23, 2011 7:32 pm    Post subject: Reply with quote
oh man.. bawsssss! yea.. that's very.... Shocked
rubbachicken
rubbachicken is offline
PostPosted: Fri Dec 23, 2011 8:37 pm    Post subject: Reply with quote
very nice Cool
lucy our westy
lucy's BIG adventure
meet 'burni'
Syncroincity
Syncroincity is offline
PostPosted: Fri Dec 23, 2011 8:51 pm    Post subject: Reply with quote
Wow, excellent stuff! We need more madman-artisan input... Keep 'em coming! Smile
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
Crankey
Crankey is offline
PostPosted: Fri Dec 23, 2011 11:02 pm    Post subject: Reply with quote
looks like you'll have some bread in that box ! Laughing
sweet work man, you in Wa. too, cool !
badassdubs
PostPosted: Fri Dec 23, 2011 11:31 pm    Post subject: Reply with quote
Thanks guys. Far be it from me to do anything normal. Very Happy I'll try to keep you entertained as much as I possibly can. Have been learning alot about the vanagon. This is my first one. Lots of good info here. The suspension was a PITA, but you guys already know that. Wink
Made a simple special tool for putting in the f & r lower suspension bushings. I get a pic up tomorrow. Here is the best way to get a ball joint out when you can't get to it with a press. Gotta be careful though. Finish it off with a die grinder on one side and it pops right out.
The 996 cluster was given to me 8+ years ago. You can see it only has 12K on it. It is a canadian cluster, was changed out for a U.S. cluster when it was brought into the states. If you turn the right knob at the top of the cluster and hold it for 5 seconds it will automatcally switch the readout to MPH from KPH. How cool is that!!! I have a cordless drill hooked up to it in that pic spinning the sending unit as fast as it can. Yup 8 mph. I noticed that the analog speedo to the left is at 8 mph also. If my thinking is correct the analog also changes to MPH and I will have a 300 MPH speedo. Cool I just might need that. Laughing Yes I am in WA. I live in Monroe about 25 minutes N of Seattle.
Crankey
Crankey is offline
PostPosted: Sat Dec 24, 2011 1:00 am    Post subject: Reply with quote
very cool man. always good to learn of creative people nearby.
welcome here, hope you stick around.
skinny66
skinny66 is offline
PostPosted: Sat Dec 24, 2011 1:24 am    Post subject: Reply with quote
That will be one trick ride !!
Keep us posted.
skinny
shadetreetim
shadetreetim is offline
PostPosted: Sat Dec 24, 2011 1:32 am    Post subject: Reply with quote
Sweet. Waiting for more pics.
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5
xoo00oox
xoo00oox is offline
PostPosted: Sat Dec 24, 2011 4:40 am    Post subject: Reply with quote
You've got a great combination of skills, imagination, and energy. Looking forward to watching your build.
Andrew-
Mark
Mark is offline
PostPosted: Sat Dec 24, 2011 3:46 pm    Post subject: Reply with quote
Updates, keep them coming. Applause
badassdubs
PostPosted: Tue Dec 27, 2011 6:02 pm    Post subject: Reply with quote
Thanks again. Here is a simple tool I made to put in the front or rear control arm bushings. Be sure to use lots of spray silicone. For the front I was able to use my press but the rear doesn't have enough depth to use a press so I used a C-clamp. Start with a 2" O.D. piece of pipe. Then take a socket with a taper on it and pound it into the pipe with a BFH, creating a flare. Once that is done I took my cutoff wheel, you could use a hacksaw also, and cut a bunch of slots so that you can clamp it down with a hose clamp to meet the same dimensions as the control arm. I used a craftsman 1 7/16 3/4 drive socket for the taper. When using the C-clamp you can't get it all the way through because of the plate. Just take a bolt, run a nut up to the end of the threads. put it in the bushing. Hold the bolt with some vise grips and thump away. Don't be shy with the silicone.
For the front lower ball joint I use a long extension with a 36mm K-D socket. Run the extension through the upper ball joint hole and put the socket on top of the ball joint and press it in. Make sure that you put a socket under the ball joint so that it can pressed all the way in.Worked for me.
One question. Years ago I pulled all of the heater related items so that I could convert over to water cooled. I also pulled this vent that directs heated air back to the rear. I have never seen one in another van. Is this not so common a part? Does it work well? If not I will put in the rear heater instead.
back to the rear
SteelB12
SteelB12 is offline
PostPosted: Tue Dec 27, 2011 8:34 pm    Post subject: Reply with quote
That suspension looks sweet!
1987 Westy
levi
levi is offline
PostPosted: Tue Dec 27, 2011 9:25 pm    Post subject: Reply with quote
All of the diesels I see in Europe have that raised center.
Was your van originally diesel?
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
badassdubs
PostPosted: Tue Dec 27, 2011 9:50 pm    Post subject: Reply with quote
Mine was originally air cooled. I can't remember what engine the van had that I pulled this from. It was about 10 years ago.
A couple of shots of the fubar'd header panel. And the new one is in. Welding tomorrow.
Page 1 of 17
