Engine blueprinting worksheets
Page: 1, 2, 3  Next
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Dec 27, 2011 12:28 pm    Post subject: Engine blueprinting worksheets Reply with quote
Since i always just scribble notes on small sheets of paper just to loose them and remeasure, I decided to make some worksheets that I can keep for future reference and to give to customers when I complete a build.
There are a few things that I remembered I left out and have added in to the original document but I would like feedback for more stuff I forgot or things I should remove (retainer weight??). Think if you were to have someone build you an engine, what info would you like to see?
Thanks
Update - This is now on the site in PDF Format.
Link:
http://www.thesamba.com/vw/archives/info/blueprinting_worksheet.php
baked beetle
baked beetle is offline
PostPosted: Tue Dec 27, 2011 12:58 pm    Post subject: Reply with quote
That is a wonderful list, thanks for spending the time on it Smile
These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE)
craigman
craigman is offline
PostPosted: Tue Dec 27, 2011 1:23 pm    Post subject: Reply with quote
Very nice!
Anyone who assembles an engine should have one of these.
Definately beats the binder paper i've been using!
Thanks!
slalombuggy
slalombuggy is offline
PostPosted: Tue Dec 27, 2011 1:31 pm    Post subject: Reply with quote
craigman wrote:
Very nice!
Thanks!
Actually, anyone who BUILDS an engine should use these. Engine assemblers don't really care to get this detailed Laughing
Thanks for working at making this list Applause Applause , I'll be printing them off
brad
craigman
craigman is offline
PostPosted: Tue Dec 27, 2011 1:40 pm    Post subject: Reply with quote
Well i consider myself a "assembler". I've assembled many engines with great sucess, but I definately don't have the smarts of Raby, Chico, ect. I consider those guys builders!
But i still take the time to measure everything (as should anyone assembling a engine) and write it down.
But derluftwagen did an excellent job with his spreadsheet! I know it will make it easier for me now! Cool
AlteWagen
Troll
PostPosted: Tue Dec 27, 2011 2:13 pm    Post subject: Reply with quote
I am waiting for more feedback to finalize the sheets. Once completed I will send them to EB to post as a PDF or what ever format he recommends.
There are a few things not on these JPEGs like:
Quick summary
Installed deck height/head cc/shim stack/copper gasket table
Final end play shim stack measurement
Quick reference torque table
Solid rocker shaft shim measurements
Rocker stand shim measurments
Actual valve lift measurement (installed specs for rocker arms (true ratio))
Sand seal type check boxes
Flywheel dowell pin size/lenth
Gland nut type/size and final torque
Pushrod tube type/size/seals
etc...
Im sure there are other things Ive forgotten so I need some "builders" to chime in.
Thanks again!!!
Jake Raby
Jake Raby is offline
PostPosted: Tue Dec 27, 2011 2:31 pm    Post subject: Reply with quote
I have some almost exactly like these for TIV based engines.. Looks really good.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
mark tucker
mark tucker is offline
too much writen fer me.but nice work, as some realy need that kind of stuff and some want that kind of stuff, then there is the ones who,have to have that kind of stuff(ocd, witch I have but not that bad).I do how ever have stack sheets that take the big part of guess work out of figuring the stack& what will be needed in theroy for each combo,just add it up.(I havent checked the AA cylinders&pistons for the sizes I only have 1 set of 92b's from them)
AlteWagen
Troll
PostPosted: Tue Dec 27, 2011 2:40 pm    Post subject: Reply with quote
I guess I am ocd when it comes to putting together an engine for a customer that will drive their car daily to work!!! Even stock builds need some added attention as the cores are 40 years old and have been through hell not to mention china parts.
That and the fact that most machine shops are using 50+ year old machines that MAY get calibrated every 20 years or so. By taking measurements before any assembly you can tell if the line bore is crooked or the crank is warped.
Another reason I put these together is for the novice builder. Even if they do not know everything (who does) it will help them learn what to look for. How many posts do you read about seized rebuilds or junkyard builds that are all mis matched? If you want to use used parts just measure the parts, and 90% of the worry is gone!
W1K1
W1K1 is offline
PostPosted: Tue Dec 27, 2011 3:20 pm    Post subject: Reply with quote
It would be nice if it was a word file or something you can add the numbers to.
I find when I do a paper print out of something like this it either ends up with assembly oil, or sealant,or lunch on it so it would be nice to print out a copy with the info entered and readable.
Like this one I have been using:
http://www.aircooledtech.com/parts_list/
only trouble is if you scroll down to the total when the wife is looking over your shoulder........ d'oh!
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
wompninja
wompninja is offline
PostPosted: Tue Dec 27, 2011 3:59 pm    Post subject: Reply with quote
If you send me the file I'll make it a fillable PDF for you.
Pics of my 1970 Satin Black Type 1 build
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
Altema
Altema is offline
PostPosted: Tue Dec 27, 2011 4:31 pm    Post subject: Reply with quote
Looks good, nice job. I have a spreadsheet I put together for mine, but yours looks more professional. Only thing that might be nice is a before/after weight on pistons and rods. Mine were all over the map (401 to 406 grams!), and some people might want to know how close or far off they were.
Paul
mark tucker
PostPosted: Tue Dec 27, 2011 7:18 pm    Post subject: Reply with quote
[quote="W1K1"]It would be nice if it was a word file or something you can add the numbers to.
Like this one I have been using: hey hes talknig about me !! great for some just not me.did it years ago or tried any way, but great for some.
Rome
Rome is offline
PostPosted: Tue Dec 27, 2011 10:26 pm    Post subject: Reply with quote
Excellent list; significantly more detailed than the log sheets I devised 10-15 years ago. How about a space for each major component, as to its origin/where you bought it? This was significant for me, being a home hobby builder and finding parts at swapmeets or buying them new.
After posting my response and viewing the lists again, I realized you do have several lines' space at end of each section for such "notes'. Smile
Also, how about
- in which car was the engine installed (customer name, or type of VW and when)?
- The case sealant (to monitor if the engine leaks soon or not),
- initial carburetion,
- exhaust system?
ViLL
ViLL is offline
PostPosted: Wed Dec 28, 2011 12:00 am    Post subject: Reply with quote
I remember these sheets when I raced 1/8th scale R/C buggies...tedious work getting shit dialed then simply refering to your tweak sheet for various settings/adjustments. There was even an empty block for our nitro engines...shims, glowplug heat range, pipe, exhaust manifold, clutch springs, clutch shoes.....it was insane!!!! Laughing
'10 Audi A4 Avant Premium Plus S-Line w/ 19"sport pkg
Dale M.
Dale M. is offline
PostPosted: Wed Dec 28, 2011 10:28 am    Post subject: Reply with quote
Word or EXCEL document would be awesome then people can print them out as need be.... OR modify for special circumstance...
IF you make a Word or Excel file I can host them for download on my site, on "Technical Links" page
http://www.mydune-buggy.com/
Would also host PDF version if it were available....
Dale
yamaducci
yamaducci is offline
PostPosted: Wed Dec 28, 2011 11:24 am    Post subject: Reply with quote
It's too bad I can't see photobucket images from work but I have my own sheet in Excel. Derluftwagen, any Chance you want to host your on thesamba instead of photobucket?
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
Almost Alive
Almost Alive is offline
PostPosted: Wed Dec 28, 2011 12:23 pm    Post subject: Reply with quote
Wow, this is terrific. Do you happen to have it in an excel sheet?
AlteWagen
Troll
PostPosted: Wed Dec 28, 2011 3:08 pm    Post subject: Reply with quote
like I posted earlier, still working on the final version and when complete I will make it a PDF and post it here for all to use.
Currently it is in a word doc and is in a fillable form and will offer it in both versions if possible.
Almost Alive
PostPosted: Wed Dec 28, 2011 3:09 pm    Post subject: Reply with quote
Oh cool, sorry. I obviously missed that part. Anxiously awaiting it!
Page: 1, 2, 3  Next
