chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4873 Location: Swansea (Sunny Penllergaer) Wales UK
Posted: Fri Sep 21, 2007 3:23 pm Post subject: 1970 Floor Pan |
Bought this on eBay for £25.00 its a 1970 Beetle Cabriolette Floor pan on an A-Plate originally LHD but you would never tell as it is now a RHD.
Brought it home stripped it shot blasted it, welded all the holes up & had it Hot galvanised. Now I have a 25 year guarantee on it even if I don't paint it. I have painted it so it will last forever. I haven't decided if it is going on my 1971 Baja or my 1965 Herbie project.
As it was when I bought it
Back from the Benetts after shot blasting. Peugeots have their uses!
Almost ready for Galvanizing. Black circles are where welding is needed
Nice & shiny from Cardiff Galv
Etch priming
Almost ready
Just needs putting back together now _________________ http://www.vintagevwweddings.co.uk/contact.html |
coW Samba Member
Joined: September 21, 2004 Posts: 2096 Location: New England
Posted: Fri Sep 21, 2007 4:10 pm Post subject: |
Looks great! |
Daddylolo Samba Member
Joined: June 05, 2007 Posts: 253 Location: Sintra, Portugal
Posted: Fri Sep 21, 2007 5:03 pm Post subject: |
Perfect job! Congratulations! I will link it to Portuguese VW forum. _________________ '70 hot rod bug
'77 hawaiian bay van
'46 Buick Eight
'67 Ghia |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5225 Location: Richmond, VA
Posted: Sat Sep 22, 2007 6:16 am Post subject: |
That is cool! Just think how much work would have been saved if VW had galvanized tha chassis! _________________ Ghia Owner Emeritus |
The Pirate Samba Member
Joined: August 09, 2006 Posts: 310 Location: Austin Tx.
Posted: Sat Sep 22, 2007 8:56 am Post subject: |
A few questions about the galvanization.
Did you plug the fuel lines or plug the threaded areas like for the tranny mount and excet ?
If you did not have you had to run a tap through the threaded areas?
If I remember correctly some of the later VW hard fuel lines were an aluminum steel or stainless steel alloy. I was under the impression that galvanizing these metal alloys reacted badly and would cause them to corrode. Or perhaps I have had a stroke…. _________________ 74 super beetle AKA The Pirate.
We are currently offering a rebuild service for Beetle rack and pinion steering units. PM for details.
Service with a Yahhrrr. |
Posted: Sun Sep 23, 2007 12:15 pm Post subject: |
Hi all, when galvanizing, you must make sure that all of the rubber, underseal, paint & rust is removed otherwise the Zinc won't stick, all of the threads had to be re-tapped, this is easy because the metal is soft. some of the pipes in the chasis were blocked at the end so I just put a blow lamp on them & rodded them with some stiff wire. you cann't galvanize any part that has a sealed end otherwise the galv will explode inside the void & spit the part, luckily the VW floorpan has no sealed areas. _________________ http://www.vintagevwweddings.co.uk/contact.html |
Goranothos Samba Member
Joined: September 04, 2005 Posts: 413 Location: East Tennessee
Posted: Mon Sep 24, 2007 4:18 am Post subject: |
For some reason I was thinking that paint would not stick to galvanized metal. |
Posted: Mon Sep 24, 2007 5:11 am Post subject: |
If you put paint straight on it wont, if you wipe it over with thinners to get the salt off & then etch primer it it will take any paint after that.  _________________ http://www.vintagevwweddings.co.uk/contact.html |
tundrawolf Samba Member
Joined: February 24, 2009 Posts: 1384 Location: RIP Mishomi my friend. I will always love you.
Posted: Sun Jan 08, 2012 9:57 am Post subject: |
That's beautiful... I am using an angle grinder to get all of my rust off. It's very time consuming, and I am having to rewind the field coil in my angle grinder today because it is almost burned up! It's a lot of work. How much did the shot peening cost, and how much was the galvanizing? |
Posted: Sun Jan 08, 2012 3:09 pm Post subject: |
tundrawolf wrote: |
The whole effort cost me about £450
Good luck with yours M8 _________________ http://www.vintagevwweddings.co.uk/contact.html |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17586 Location: Left coast, Canada
Posted: Sun Jan 08, 2012 4:35 pm Post subject: |
Chris, I was reading up on galvanizing last night, and it seems that the method they use to hang it is important to venting and draining. Do you know how they hung yours? Did they hang it from one side of the floor pan, or did they hang it from the frame horns?
Did they have to drill extra venting/drain holes? _________________
Posted: Sun Jan 08, 2012 6:13 pm Post subject: |
Bruce wrote: |
Did they have to drill extra venting/drain holes? |
They put it in flat then spun it around & let the excess run out. No drilling or venting was needed.  _________________ http://www.vintagevwweddings.co.uk/contact.html |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Mon Jan 09, 2012 12:42 am Post subject: |
I didn't want to bump the old thread just to say THATS BAD ASS!!!!!!!! but now that some one else has dun it there you go!! I would love to do the same thing! but I dont see it happening any time soun cents I dont have A garage to do the work in,, I dont even have A drive way so most of the stuff I do needs to be fast! cents my cars parked on the street..
I had started A thread about galvanizing some parts, and the link to your thread was posted(I started drooling ) From what I have found there are no tanks loco that would be able to lay A full pan down like you say thy did yours, It would need to stand on its side.. but I was only looking at doing miscellanies parts any way  _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Bruce Samba Member
Posted: Mon Jan 09, 2012 1:42 am Post subject: |
From the other topic:
Galvanizing...
rhoads2 wrote: |
is not nice looking doesn't really lay down smooth it doesn't really work for parts that move wont flex and looks like crap if you try to paint over it. |
Chris, what do you think of the look after painting? _________________
Posted: Mon Jan 09, 2012 3:35 am Post subject: |
vw_hank wrote: |
I had started A thread about galvanizing some parts, and the link to your thread was posted(I started drooling ) From what I have found there are no tanks loco that would be able to lay A full pan down like you say thy did yours, It would need to stand on its side.. but I was only looking at doing miscellanies parts any way  |
In the UK there are loads of Galvanising factories, the tanks are normal very big to take large gates & railings.  _________________ http://www.vintagevwweddings.co.uk/contact.html |
Posted: Mon Jan 09, 2012 3:36 am Post subject: |
Bruce wrote: |
Galvanizing...
rhoads2 wrote: |
Chris, what do you think of the look after painting? |
If I done it again I would leave it unpainted or get it powder coated.  _________________ http://www.vintagevwweddings.co.uk/contact.html |
Posted: Mon Jan 09, 2012 4:15 am Post subject: |
chrisradioman wrote: |
vw_hank wrote: |
In the UK there are loads of Galvanising factories, the tanks are normal very big to take large gates & railings.  |
I found 5 that are within about 20 miles of me, and It looks like this one has the biggest tank,, but I'm not planing to do A hole pan like you so I dont need them to have A huge tank
Single-dip dimensions of 22' (length) x 5.6' (width) x 6.6' (depth).
We are capable of galvanizing material up to 38’ in length or up to 12’ in height. (Double-Dip method)
Unless the VW pan is under 5 1/2 feet wide??
I seen pics of there work, thy do A lot of out door decorative stuff. and say It has A life of 50+ years _________________ 1302s sunroof..
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Mon Jan 09, 2012 5:31 am Post subject: |
Goranothos wrote: |
White vinegar works well to prepare the freshly galvanized surface for paint adhesion. |
'69Custom Samba Member
Joined: September 16, 2008 Posts: 2497 Location: Ventura, California
Posted: Tue Jan 10, 2012 1:25 pm Post subject: |
69 Jim wrote: |
Goranothos wrote: |
Ive been told that as well. Unfortunately I've never been able to make it a reality through several attempts. I think I'd stick with the method Chris detailed in this thread. _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote: |
Why tune a big round again and again????? For me.... 1 hour will solve the case |
www.endlesscustomz.com |
