Bus Front Brakes: Safety Bulletin
LHG
LHG is offline
PostPosted: Wed Jan 18, 2012 8:06 pm    Post subject: Bus Front Brakes: Safety Bulletin Reply with quote
This is the metal brake line between the two front wheel cylinders off a 67 bus. The inner part of the brake drum that holds the grease seal was rubbing on it. I'm glad I examined it closely, it was very close to failure.
This is the area where wear is likely. This is good installation with the brake line very close to the cylinder. If it is up off the cylinder, it can rub on the drum.
Brian O'Kelly
Central Coast Chapter, CA - Vintage Volkswagen Club of America
www.centralcoastvwclub.com
www.facebook.com/groups/vintagevwclub/
durfeec
durfeec is offline
PostPosted: Wed Jan 18, 2012 8:28 pm    Post subject: Reply with quote
that line blew for the same reason on my first long trip on my bus. happened to be right next to a cop. she saw the whole thing. i went up and over the curb into an empty parking lot. smashed my brand new muffler.
she came over and asked what happened. i was like i have no idea. they just went out. everything was new. soft lines, hard lines, all new wheel cylinders, pads. i had no idea it was rubbing.
got a ticket for unable to stop in a sure safe distance. 2 points on my license. i went to fight it and because i had done the work and it was an old bus they didnt care it was because of a hole in my brake line. even though i missed everything and everyone.
1960 Bus Panel/Camper
LHG
LHG is offline
PostPosted: Wed Jan 18, 2012 9:17 pm    Post subject: Reply with quote
Here is a photo I found in the gallery.
The line here bows up a bit right where the drum is. I would like to see it contour down here closer to the cylinder.
Brian O'Kelly
mcarls
mcarls is offline
PostPosted: Wed Jan 18, 2012 10:39 pm    Post subject: Reply with quote
I had the same issue with my '63 after I replaced all the lines. Good thing my parking brake kind of worked! I'll always make sure to hug the wheel cyliner with that line and keep it as far away from the hub as possible in the future. Good idea to post this!!
kombisutra
kombisutra is offline
PostPosted: Thu Jan 19, 2012 2:42 am    Post subject: Reply with quote
Great head's up. I've done a lot of brakes and have never had this happen. One would think the conscientious mechanic would both hear and feel the interference before the shoes were set to the drums, but therein, lies the rub... Wink I will look closer at these lines in the future having seen your post here. Thanks.
cdennisg
cdennisg is offline
PostPosted: Thu Jan 19, 2012 10:14 am    Post subject: Reply with quote
Good Catch. Thanks for the heads up. I am doing front brakes on my 57 right now, I'll be sure to double check that line.
chrisflstf
chrisflstf is offline
PostPosted: Thu Jan 19, 2012 10:27 am    Post subject: Reply with quote
Need to watch the end where it comes out of the wheel cylinder also. It can be very close to the edge of the shoe. Needs a little bend there - but not much
mcarls
mcarls is offline
PostPosted: Fri Jan 20, 2012 2:19 pm    Post subject: Reply with quote
I didn't notice that anything felt odd while putting together the brakes on my '63, but it was the first time I had made the cylinder connecting lines myself, and I wasn't being careful enough. I assumed (due to lack of experience) that if I ran the line a bit away from the hub I'd be ok, not realizing the seal/drum hub is quite a bit larger in diameter and there needs to be lots of room. Stupid oversight on my part. Fortunately nobody got killed...! After I took it apart I was surprised that I hadn't noticed while I was putting it together the first time. And I've always wondered if others have made this same mistake.
sventinker
sventinker is offline
PostPosted: Fri Jan 20, 2012 2:54 pm    Post subject: Reply with quote
I'll be checking mine before I put her to the road again I just did my brakes and bent my own lines.
April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote:
Perfection only comes with delusion.
http://www.oacdp.org/
LHG
LHG is offline
PostPosted: Fri Jan 20, 2012 3:24 pm    Post subject: Reply with quote
To Summarize: Areas of Concern
#1 Make sure the bend over wheel cylinder is tight and clears brake drum hub.
#2 & 3 Clearance behind the springs needs to be checked.
#4 Top bend needs to clear brake shoe.
This example appears marginal in all areas from the photo although in person might be OK.
Brian O'Kelly
hazetguy
hazetguy is offline
PostPosted: Fri Jan 20, 2012 3:43 pm    Post subject: Reply with quote
whoever bent the line in the above picture should not be doing brakes. the factory lines have numerous distinct bends so that they clear EVERYTHING (shoes, springs, wheel cylinders), and so they follow the stamping in the backing plate. these bends can be made by hand to factory standards. the one above is, to be polite, pathetic, not to mention unsafe. that's just bending so it fits inside the drum, and nothing more.
here is one i did, next to a factory original line:
notice how it follows a distinct path and is close to the backing plate when installed.
the springs should not rub on the brake lines, period. although i have never personally experienced the springs cutting a metal line, i guess it is possible if the line was not installed properly, or bent during installation at some time in the past.
cdennisg
cdennisg is offline
PostPosted: Fri Jan 20, 2012 3:50 pm    Post subject: Reply with quote
What is the exact length of a straight piece of hard line before bending for this area?
jtauxe Premium Member
jtauxe is offline
PostPosted: Fri Jan 20, 2012 4:02 pm    Post subject: Reply with quote
And your emergency brake was... non-functional?
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Culito
11010101
Culito is offline
PostPosted: Fri Jan 20, 2012 4:29 pm    Post subject: Reply with quote
When I re-did the brakes getting my SC running, I bought a kit (CIP1, maybe?) that had all the lines in it.
The lines between the wheel cylinders were too short, so they didn't clear everything. As soon as I torqued the bearings down and spun the drum, I knew something wasn't right.
I had to order those two lines from WW.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
PostPosted: Fri Jan 20, 2012 4:37 pm    Post subject: Reply with quote
Just curious if you did all those bends without any sort of tool at all?
If not, what sort of "tools" did you use?
Harleyelf
Harleyelf is offline
PostPosted: Fri Jan 20, 2012 6:20 pm    Post subject: Reply with quote
I use a piece of pipe with a 1" diameter to set the radius on my bends.
tyzel
tyzel is offline
PostPosted: Fri Jan 20, 2012 7:58 pm    Post subject: Reply with quote
Are the ones from wolfs west (WW) pre-bent?
LHG
LHG is offline
PostPosted: Fri Jan 20, 2012 8:10 pm    Post subject: Reply with quote
Everything you buy is straight. It's not hard to bend them, you just have to follow the correct path.
Brian O'Kelly
tyzel
tyzel is offline
PostPosted: Fri Jan 20, 2012 8:19 pm    Post subject: Reply with quote
That's what I thought, thanks!
and glad you caught that before it turned into a bad situation.
hazetguy
hazetguy is offline
PostPosted: Fri Jan 20, 2012 9:04 pm    Post subject: Reply with quote
i used similar things. smaller diameter round stock (sockets) for the tighter bends, round stock and/or bare hands for the more gradual bends. the key is to go slowly and not crush the tubing.
also, the tubing work hardens when bent, so i try to bend to the "just before it's right" angle and make minor adjustments as necessary. it's really difficult to fix a mess up and the chances of the tubing cracking or breaking increase if you try to straighten out an error.
in the past i have only used the WW kits, and perhaps a kit from Ronnie. the front brake lines were the proper length.
