Saguache Samba Member
Joined: December 28, 2009 Posts: 360 Location: Gunnison, CO
Posted: Thu Jan 26, 2012 6:14 am Post subject: Lifted Van, Cargo Space Below |
As soon as my Burley A-arms come in, I'm lifting Zeno. For a 2WD van he's going to stand a bit taller than normal (not that he doesn't already) and this is going to make a bit of space down below. I'm thinking about the possibility of adding some additional stowage there, like the cargo boxes you see on this LT35. Has anyone else done something like this? Photos (the images on this LT were taken at night)?
_________________ Matt Thyer
http://zenoswagen.wordpress.com/ |
wyomingriviera Samba Member
Joined: October 04, 2006 Posts: 384 Location: Vee-Tee
Posted: Thu Jan 26, 2012 6:56 am Post subject: |
Are you lifting it because you want ground clearance? or are you lifting it to make storage room under it? _________________ '77 Rivi 2.0 T2 GD
"I tell you, we are here on Earth to fart around, and don't let anybody tell you different."- Kurt Vonnegut |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 920 Location: Sammamish, WA
Posted: Thu Jan 26, 2012 6:58 am Post subject: |
Das Mule (Dasmule.com) will soon begin offering their cargo cages that are located in the same spot. I saw an earlier version installed in a Syncro that shiped to South America and they are very nice.
They are a little bit shallower than the boxes in your picture (sit flush with the rails) but for a Syncro that's great because you don't loose ground clearance, _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Thu Jan 26, 2012 8:42 am Post subject: lift |
wyomingriviera wrote: |
Are you lifting it because you want ground clearance? or are you lifting it to make storage room under it? |
WHY! I like the rack on the roof . More storage less cost and by far more ground clearance . Even 2wd are great off road why would you want less clearance! _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
vw7266 Samba Member
Joined: April 28, 2004 Posts: 3038 Location: the point, ohio
Posted: Thu Jan 26, 2012 9:04 am Post subject: |
How much crap do you want to carry that you actually need a storage space underneath...
I alway revel in the fact that I dont need tons of stuff thats why I own a vanagon and not a huge RV |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Thu Jan 26, 2012 10:13 am Post subject: |
I understand the uniqueness of stowing that way - including the lower center of gravity of a vehicle you are lifting and thus making more dangerous in emergency handling. But it just seems like hard-fought storage that could be easily accomplished elsewhere. The container will need to be seriously dust and water proof, and whenever you are accessing it, the box will be coated with road grime. In an offroad situation, it is a serious loss of ground clearance - far more than the height gained in a mild lift. Finally, it will be expensive storage because it will be virtually custom made.
By contrast, roof storage is removable when not needed, above the road grime zone, cheap, easily accessed, won't affect ground clearance, and provides many more configuration options.
I know that wasn't the question, but just throwing it out there. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu Jan 26, 2012 11:06 am Post subject: |
Semantics aside, there was a guy either here or on the Vanagon List a few years back put a welded a metal box in that spot underneath the sliding door.
It was secured with bolts and grommets through the floor I think. It was only about three inches deep as I recall, but probably 1' by 3'. He used it for tools. I haven't been able to find a photo of it, but it was cool and appeared to have very little effect on ground clearance.
ETA: I realized that it was the "A Vanagon For All Seasons" website, one of the greatest ever, and it's GONE! What a drag! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Thu Jan 26, 2012 11:54 am Post subject: |
Yeah, I loved that storage box, too. My reaction to it would be a place to keep things you're not going to need except for a situation. Such as a spare part, etc. If you're loaded to the gills and heading out on a trip and out of storage, then you've likely got the floor busy already. So accessing under floor stuff means moving things to get to it. But I thought it was a terrific idea and solves my issues above regarding ground clearance loss, and dirt since you access it from the van.
Good call pointing it out, but bummer it is gone. This underfloor location was also used on that amazing Syncro thread where they installed a reinforced roof rack that electrically raised and lowered so the poptop was usable even with hundreds of pounds were up there.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Thu Jan 26, 2012 12:18 pm Post subject: |
joetiger wrote: |
ETA: I realized that it was the "A Vanagon For All Seasons" website, one of the greatest ever, and it's GONE! What a drag! |
My primary motivation is to build external storage for my rolling tool set and spare parts I might need to carry. I saw the stowage on that LT35 (which I have been drooling over since it was posted) and thought that its actually kind of a nice idea. Plus if you limit the box depth and width to fit in the area below the slider and to not exceed the frame you don't lose much in the way of clearance. Would be even cooler if the door opened on the stowage and then a tray with all my tools rolled out, but that's just me dreaming.
We've got a lot of snow on the ground right now otherwise I'd take my tool kit and lay it out next to the van to see how well it might fit, as-is. Sure would be nice to get some of this stuff out of the cabin and living space. Ever had a can of WD-40 spring a leak in your cabinets? I'd even be willing to give up a little clearance if I could keep that smell out of the wood and carpet.
Lower center of gravity and distribution of weight (left and right) are also nice benefits to doing it this way.
To answer the couple of questions about the pending lift, I'm lifting Zeno because a) the springs and shocks I have on there now are shot and need to be replaced and b) because the additional clearance will be welcome considering some of the places I like to go. Plus the slightly taller vanagon looks pretty damn cool in my opinion. _________________ Matt Thyer
buildyourown Samba Member
Posted: Thu Jan 26, 2012 1:03 pm Post subject: |
I intend to build an underfloor box in Das Mule doesn't come thru with an affordabel option I like. I think it's the perfect place for heavy tools, spares and recovery gear. It's low, it's centered on the vehicle, and it offsets the driver's side weight of a westy. |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Thu Jan 26, 2012 4:08 pm Post subject: |
What are the dimensions of that space? How about a long ammo can (already watertight) that snaps up there? Something like this?
http://www.ebay.com/itm/1-120-MM-Mortar-Military-S...4ab1396c9d
held up with some lockable tension latches?
_________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
Posted: Thu Jan 26, 2012 4:20 pm Post subject: |
Steelhead wrote: |
Awesome idea, I've already been looking for smaller boxes for the bumpers, but if I can find a long box that is oriented correctly I might have a cheap, bolt on solution. _________________ Matt Thyer
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Thu Jan 26, 2012 5:42 pm Post subject: |
Steelhead wrote: |
What are the dimensions of that space? How about a long ammo can (already watertight) that snaps up there? Something like this? |
Done and done, my van had one under the slider, virtually undetectable to all but the most discerning vanagon eye if it is painted black. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Posted: Thu Jan 26, 2012 5:56 pm Post subject: |
That is a superb idea. Would be great to know what size/model ammo can fit so nicely up there so someone wanting to do the same could find on on eBay or similar and know it's the right one.
Mounting it on those scissers arms would be SO cool. You could release it and pull it straight down for easier access.
Great thinking, JB! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
GrindGarage Samba Member
Joined: October 14, 2008 Posts: 710 Location: Ocean City, NJ
Posted: Thu Jan 26, 2012 6:38 pm Post subject: |
jackbombay wrote: |
Steelhead wrote: |
Done and done, my van had one under the slider, virtually undetectable to all but the most discerning vanagon eye if it is painted black. |
Come on no pics???? _________________ -cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com |
Posted: Thu Jan 26, 2012 7:51 pm Post subject: |
jackbombay wrote: |
Steelhead wrote: |
Pictures senior, we require the photographs. _________________ Matt Thyer
Posted: Thu Jan 26, 2012 7:53 pm Post subject: |
jackbombay wrote: |
Steelhead wrote: |
Mark- Not surprised you figured that out already. Of course, not all of us have the world's greatest army surplus store nearby (like that warehouse you've got in idaho falls). _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
Posted: Fri Jan 27, 2012 12:08 am Post subject: |
The ammo box was actually the work of the previous owner, 2 metal straps and bolts held it up in place, not bad to remove, but I actually never used it as we just didn't need that space.
The ammo can that steelhead posted a pic of looks like the one, but as I don't own the van anymore I can confirm the dimensions right now, but I did send the current owner an e-mail asking for the dimensions so I will post up when I hear from him.
The ammo can really did fit the space just right, it hung down ~1.5" below the rocker on that side of the van, but the propane tank hung down further on the drivers side so there was not really any loss of ground clearance. _________________
Samba ad here.
XXX/Rx/RnR Samba Member
Joined: March 01, 2008 Posts: 405 Location: valley of the sun
Posted: Fri Jan 27, 2012 12:31 am Post subject: |
I've got a hydro-flame furnace mounted up in under there on my bay. Don't use it much in this neck of the woods though. Might remove it and put in a row or deep cells. We all need more space for bolt ons and options. Beware of exceding the angle of your cv's doing your lift. I had to up to 930's. _________________ 78' westy, 2.4 195hp ecotec, audi turbo a/t, a\c, 2 1/2" lift spindles, index rear, 930 cv's & axles, 225x65x17 BFGs ## 77' hardtop 2.0 T-4 duel 44 weber's, 225x50x17s ## 74' baha bug |
DASMULE Samba Member
Joined: November 10, 2011 Posts: 42 Location: Seattle, WA
Posted: Sat Jan 28, 2012 9:00 am Post subject: |
We are fine tuning the CAD models for our under van storage NOW. It sounds like most people are interested in using them primarily for tools. We are also considering a water storage container as an accessory that would fit in the exact space.
Interested to know what all of you would love to be able to use these under van storage spaces for -- the idea is to make a product that people actually want and will use! _________________ MULE Expedition Outfitters
Specializing in Overland Equipment & Accessories
www.dasmule.com |
